Thorfun
Everything posted by Thorfun
thanks. I'm looking at B&W speakers as well as my brother-in-law works for them and I'm trying to get a deal! for 1st floor speakers I can get access from the loft and add MDF backboxes but for the ground floor I'll need to cut a big square in the ceiling to add MDF backboxes and then patch up the repair. a pain but I didn't think of this early enough in the build when I was running the speaker cable. interesting that you're only running a single speaker in the bedroom, I'm struggling to come to terms with running only a single speaker and not a stereo-in-a-single-speaker in the bathrooms! it's just too many channels and too high a cost to justify stereo in the bathrooms. but I think in the bedroom it's worth it. I have a Unifi network so hopefully I won't have any issues with the audio server over that and I might simply run a 2.5mm cable from the PSUB to the network cabinet for reduced cost but I'll have a think about it.
our lot just angled the banks back to a suitable angle. not sure how much science was involved in the angle but we didn't have any bank collapses. they did put plastic sheeting over it though to reduce the risk of rain causing soil slippage.
hey @Kelvin! i'm starting to think about adding my audioserver to my setup. Can i ask what in-ceiling speakers you used? And also what PSU are you using to power the audioserver and stereo extensions? and a generic question to any knowledgable Loxone folk about Tree turbo. The audioserver datasheet says that Tree Turbo and Tree are not compatible. so i presume that the AudioServer doesn't connect to the miniserver by tree but accesses it via the network? the datasheet also says to use 1.5mm cable for the power for the audioserver/Tree turbo. but running the power and 24V through a cable size calculator it looks like 1mm would suffice. i have an audioserver and 4 stereo extensions but will probably add another couple of extensions to make it 6 in total. i can easily have a spare power outlet from my Powersupply and backup unit so that would be able to supply 240W of power but my audioserver will be in my network rack which will result in about a 5m length of wire from PSUB to the audioserver so i'm thinking about getting a standalone PSU just for the audio server and adding it to the DIN rail in the network cab as over 5m i'd need a 2.5mm cable. still doable though!
i think we'll have plenty other options, don't worry.
Architect and builders... where to start?
Thorfun replied to Jack757's topic in New House & Self Build Design
Find the architect you want to work with not one the builder uses. It’s your dream home not the builders! -
Boiling water tap - Quooker alternatives
Thorfun replied to canalsiderenovation's topic in General Plumbing
My Quooker boiling tank stopped working. Support said it was scale buildup and sent me a free kit to descale it. Was pretty simple to do and has been fine since. I’m sure I’ll need to do it again in the future but they can just send a new free kit again! -
Can you contact LuxPower to ask them if their BMS can handle different manufacturers of batteries?
AC can be for downstairs too! Many times this year while working from home have I used the AC in my study.
We missed with screws through battens and 80mm PIR in to 38mm wide studs often. Just slapped some airtight tape over the hole and move on! I also told every trade who came on site about our airtightness requirements and said if you make a hole to let me know and we’ll seal it. In the end had to do that pretty infrequently as they all seemed to get what we were trying to do.
Why don’t you just use optimisers to get over the shading issue?
i had a countersink bit with the drill bit in it already so did both in one go. 😉
don't know. i've not tried since as i'm happy with single phase for now. if i ever need to start using 3-phases i'll look in to it then! hopefully the OP has considered this though.
this is the key point! how many suppliers offer a modern smart 3-phase meter that actually does net metering? when i had my meter installed a couple of years ago getting a 3-phase smart meter was next to impossible.
