Thorfun
    36
Everything posted by Thorfun
  1. thanks. next saturday when I'm doing the job I'll see if I can figure it out!
  2. Not sure I understand what you mean. 😢
  3. it's not the size, it's how you use it. at least that's what @Pocster says.
  4. but the z-shaped purple line under the stairs' perimeter channel will be pointing at an angle down unless I can cut a piece of wood at the right angle to make the channel sit at 90deg?
  5. sure. no issues fixing the top wall channel to the top hat and that was what I figured would happen for the wall. but where do I fix the MF6 perimeter channel to (coloured green in the photo)?
  6. hmm....I guess I could cut a piece of wood with an angle and attach to the boarding under the stairs to give a 90deg angle for the perimeter channel to attach to? but sounds fraught with risk that the angle won't be accurate enough.
  7. but the wood still wouldn't have anything "solid" to fix to above for the walls? an I still need a perimeter channel for the ceiling to fix to something?
  8. afternoon all. firstly I've put this in the general joinery section as we don't have a metal frame section on the forum I could see! I know metal framing isn't joinery but I couldn't think of a better place to put it. anyway, winter is coming and I'm hanging up my golf clubs to do some more work on the basement. the room I'm working on has the under-the-stairs bit and I want to frame it out to make a cupboard. no big deal I think. but I am also needing to drop the ceiling by about 500mm so I can cover the soil pipe (the picture below tells the story). my concern is that the walls where I've coloured the lines orange won't have anything to fix to apart from a ceiling top-hat (in light blue). is that sufficient? also where do I attach the ceiling perimeter channel coloured green that will take the top hats to? I'm struggling to envision how it all works and if it will all be sturdy enough! we want to eventually hang a TV off the cupboard wall. can anyone put my mind at ease and tell me it'll be fine? also any advice for doing this sort of "free-standing"-ish wall and ceiling? I
  9. I don’t know the official answer but we used galvanised rings everywhere iirc. They’re a bugger to remove when you make a mistake but for me that was a good thing as they’re not going anywhere! make sure you get one of these https://www.screwfix.com/p/dewalt-dwht0-55524-claw-bar-10-/156ky?ref=SFAppShare I used mine a lot!!
  10. welcome. sounds like exactly what we did! our blog is on here somewhere that documents some of our journey. and don't worry i think i've already asked all the stupid questions. 🤣
  11. ended up purchasing from Ruby (https://www.ruby-group.co.uk/). I'll report back on what they're like for future readers.
  12. i was told by Graf UK sales that the max distance between tank and pump is 20m. i did consider running the pump in the plant room but i would've exceeded that distance so i have my pump in the outdoor box next to the tank. it's so far from the house that i don't hear it. i have heard it a few times as i've come back with the dog after a walk but it wasn't excessively loud for me. horror stories? not as such but my pump failed after about 1yr of use but it was sitting around unused for a couple of years before that. Graf UK were very helpful and had to go back to Germany to request a replacement as it was "out of warranty" by a short period of time despite only being in use for just over a year due to the delay in installing and commissioning it. it took so long for Germany to respond due to holidays and i guess more important things that the UK support just replaced it for free for me in the end. so i can't grumble at that! i'm hoping that my original pump was just an anomaly and the new pump lasts longer than a year!
  13. give the tech support department a call?
  14. My DeWalt ones are fine for me. They came from Screwfix so easily returned if you don’t like them.
  15. just be careful disregarding the Loxone RGBW spots as i found it very hard to find non-loxone RGBW spots much cheaper and so i actually used the Loxone ones for them in one room. so don't discount ALL loxone stuff. 😉 not sure on the answer to this one although i guess the obvious answer is using the tree bus. in the one room where i have the RGBW spots from Loxone controlling them was a simple 1.5mm T&E radial for power and a single Cat6a cable. using Whitewing for that would've meant using up more "space" in the cab or using drivers closer to the spots? maybe another benefit is the simplicity of the tree bus and the hardware just works. i'm not saying that DMX controlled controllers are a pain but there's a few extra hoops to go through setting up the channel numbers etc. Mike from Whitewing is very responsive to questions and i've got nothing but good things to say about the customer support and you can see earlier in this thread where i was trying to figure out how the RGBW led dimmer would work and a few back and forths with Mike and i got all the information i wanted. i've not had to speak to Loxone so i can't comment on their customer support. i fully understand the anxiety of diverging from the Loxone equipment as there's the voice in the back of your head saying "What if". but i've been very happy with Whitewing equipment and just wish he'd done relays when i was purchasing as i'd have definitely used them.
  16. i do have to say though that the Loxone stuff looks really nice in the cabinet lined up. but it was a high price to pay to satisfy my OCD. 🤣
  17. i have a Whitewing mains dimmer (https://www.whitewing.co.uk/acdim.html) and 24v RGBW dimmer (https://www.whitewing.co.uk/rgbdim48.html) and think they're both great. and sooooo much cheaper even when factoring in the DMX extension. and if you swapped out some or all of your Loxone relays for Whitewing ones (https://www.whitewing.co.uk/dmxrelay.html) you'd save a small fortune! i see now he does a small 4 channel LED driver for £18+VAT each! https://www.whitewing.co.uk/tinydmx.html . should be able to replace those expensive Loxone ones (https://shop.loxone.com/enuk/product/100325-rgbw-24v-compact-dimmer-tree) at £78+VAT each! i have more lighting to do in the basement and i think i've found my new LED drivers.
  18. i need 2 x 2.6m (ish) 5 bar gates for a back driveway. there seem to be loads online. any one got any supplier recommendations or are they all pretty much the same thing?
  19. he also does DMX relays now as well. if i need more relays i think i'm definitely going to use Whitewing over buying new Loxone relays.
  20. i drew mine out on a spreadsheet (in this thread somewhere i think!) also, that's a lot of Loxone dimmers and relays which are expensive. have you had a look at Whitewing? you'd need a DMX extension though. plus the Loxone tree LED strips are expensive compared to others in my opinion. i used a Whitewing device and normal led strips. but i do understand keeping it all under one roof so feel free to ignore me!
  21. Just make sure you only need the 5! I wish I’d gone for the 6 now as things take more space than you think. Plus I’m rubbish at planning stuff. 🤦‍♂️
  22. why do you need internal drainage/waterproofing system? we had an external membrane and waterproof concrete. we'd rather keep the water out that deal with it on the inside. @Pocster used the internal system so might have more insight in to what is being proposed for you. with regards to UFH i don't think we've ever really used it in the basement as it's a pretty constant temperature down there most of the time. i would've attached it to the rebar in the slab though if i'd had more time but the second layer of rebar was put on and i couldn't thread the pipes through it and there wasn't enough cover over it to allow us to attach the ufh pipes to the top of the rebar. so we just put it in the screed.
  23. aren't they just flexible hoses? definitely don't look insulated already so i would suggest that insulation should be added to them. but i am no expert! maybe @Nickfromwales can chime in?
  24. You only get reply notifications if someone replies/quotes your message. You can follow a topic to get notified if anyone posts in it though.
  25. Well that’s a decision only you can make! They are quality but if you can find a compliant cheaper alternative then you can add that to the mix.
