Thorfun
    36
Everything posted by Thorfun
  1. Ok. That makes sense.
  2. I’m confused. If you’re getting a 5kWp array why would you need an 8kW inverter?
  3. We try not to laugh at people on here. Well, except for @Pocster . We laugh at him all the time.
  4. Welcome @Raphael Andreas . Might be best to start a thread under the relevant forum as questions like those could easily end up being long threads! best of luck. Self building is stressful but so worth it to build what you actually want to live in.
  5. Never mind. Found the answer.
  6. Can someone explain how to test the calibration? Surely to measure at both ends you have to be certain what you’re measuring against is perfectly true?
  7. Sure. It’s still possible though and if the seller pays for the indemnity (which they should) then the OP is quids in with peace of mind.
  8. ultimately it is up to you and if your lender is happy to proceed without the warranty and your survey comes back clean then i'd say you're in an ok spot. as was said above after 7 more years the warranty doesn't matter anyway. tbh, i'd have been a lot cheekier with the reduction than 20k. but it's a hard game to play if you really love the place and are worried they'll just pull out and not entertain further offers.
  9. wow! they didn't offer any potential solutions? you could request an indemnity that WOULD cover structural defects. anything is possible and i'm surprised your solicitor didn't suggest anything at all.
  10. what does your solicitor advise? not trying to be funny but if the building had structural issues and needed to be rebuilt then i would suggest the rebuild costs be knocked off the asking price. obviously the seller will reject this but if you think of worst case scenario that a structural warranty will give you then that's the cost you'd incur without one. if it's a semi detached though if one side has a warranty then i can't understand why the other side wouldn't? if structural issues happen on one side then won't that also affect the other side? tbh, i don't have a clue what to advise here apart from speak to your solicitor! maybe others will be along to offer something else.
  11. We have a poured lintel in our basement designed by the SE. it came out a bit rough but we weren’t going for aesthetics! i’m sure if you tried with decent formwork and the right concrete you could make it look nice.
  12. the OP mentioned TRVs early on in the thread so i would presume it's radiators.
  13. This is a top tip that I followed. And not only for the reason you say, it also saves a lot of cable by not going up and down to the ceiling every time!
  14. I don’t think it’s as black and white as this. For a well insulated airtight house there’s no need for high flow temps and using underlay suitable for ufh in areas with engineered timber flooring will work. Even if it did reduce the temperature a bit the whole house would have the same temperature and so other areas would compensate. we have underlay with our engineered flooring in some rooms and tiles elsewhere and our house is not cold. we also have decoupling membrane under our porcelain tiles and can feel the tiles are warm when the heating is on and the flow temperature is high enough. Our current flow temperature is 26 deg C and the house is maintaining 22 deg C but the tiles aren’t warm. They’re just not cold. It’s very easy to overthink things! I’m an expert at it.
  15. None of the touch buttons depress. You can literally just put your palm over the central area and it will activate the switch. Double and triple taps are a doddle too
  16. No complaints about the retro touch switches. But then I rarely use them! Light come on automatically when I enter those rooms. I’ve mostly Loxone Touch Tree switches around the place for the 5 touch points as we have external blinds in most rooms and will eventually get the audio server going so they will do that. Also I use the temperature measurements the touch switches give as well. anywhere we don’t need a touch we have single retro touches. Just for manual turning on and off if ever required. I couldn’t justify the cost of the Touch Pures as much as I’d have liked them.
  17. We have some retrotouch switches and I don’t recall seeing the led light up. tbh I also can’t remember how I wired them up! they’re nice though albeit a bit clicky but I’ve yet to find a quiet retractive switch.
  18. i agree. i just use them for the underlying broadband. i have individual subscriptions for the streaming services i want.
  19. hang in there! make a complaint to your provider and ask them to escalate it in Openreach. then ask them about the compensation (i think it's about £6/day of delay). it will get sorted eventually i'm sure and it'll all be worthwhile. Starlink is expensive when i looked in to it and the 4G signal by us was just about usable but not for a permanent solution so we stuck it out and am happy now, plus i have about 2yrs free broadband from the compensation payment.
  20. we had issues as well but persevered and eventually got it all sorted for free and got about £700 in compensation as it took so long! not going to lie though it was a very frustrating process
  21. you can get underlay suitable for ufh and wooden flooring. as above to drying times....is it cemfloor or anhydrate liquid screed? i think 1mm per day is excessive for liquid screed. i know that's the value for dry screeding but i thought liquid was quicker? luckily for us we're really slow at everything and our screed was down for a long time before we covered with tiles and wood! 🤣
  22. I didn’t know about this cable. It’s still expensive though! I have some leftover 14AWG purple speaker cable and green Cat6a cable so thinking I can run the 2 cables as it’s no big deal for me.
  23. we just put electric towel radiators and ufh in our upstairs bathrooms. i thought it a massive faff to mess about with multiple circuits off the ASHP and to run all the pipework upstairs just to run the towel rads for an hour a day and the ufh for a few hours a day.
  24. i'd be concerned about how having so much EWI will affect the condensation risk and any sort of airtight membrane internally? unfortunately i'm not clever enough to know the answers to that! 🤣
  25. yeah, maybe with a sloping basement like yours the best route would be all internal insulation providing you can maintain the thermal bridge as @JohnMo said.
