Thorfun
Everything posted by Thorfun
Can you do a contemporary self-build on a budget?
Thorfun replied to flanagaj's topic in New House & Self Build Design
Time, quality, cost. you can have two of the three. So costs can be low and assuming you don’t want to compromise on quality it’ll just take you a long time to do! @nod is your man for self-building for low prices but he is in the trade. -
Evening all, we have a double garage that connects to our house with a room above it. I am aware that we need fire rated plasterboard on the ceiling on the garage but the BCO attended today and said we need it on all the walls as well. that's the wall that adjoins the house and all the other external wall too. this is news to me! anyone else had to do this? I'll go through the building regs later when I have more time to see if I can find any information to refute this one but thought I'd ask on here first.
Simple DIN rail x 4 enclosure for Loxone etc
Thorfun replied to Alex Fossa's topic in Networks, AV, Security & Automation
Make sure you only need the LXN4! I thought I’d only need the LXN5 but seriously regret not getting the LXN6 as I ran out of room and will have to put my audio server in the network cabinet -
I’ve been looking for filters for my Zhender unit recently. I came across activated carbon filters that fit in the machine. https://cleanfilter.eu/en/product/wernig-comfort-vent-q-350-600-filters/?attribute_filter-set-comfoair-q-350-450-600=Multipack+10xG4&wmc-currency=GBP&gad_source=1&gclid=EAIaIQobChMIhomg2e_bhgMVc5RQBh18ogEhEAQYAyABEgJfavD_BwE&v=79cba1185463 I’m surprised there isn’t anything similar for yours. NB: I have not bought them nor ever purchased from the company. It was just a Google search.
backhanders? 🤷♂️
Balcony leading to flat roof....does it need fall protection?
Thorfun replied to Thorfun's topic in Flat Roofs
thanks Gus. all seems to make sense, kind of! and it's good to know that it is possible. it is a balancing act of aesthetics, cost and risk and we need to decide which route we want to go. -
we used these https://www.retrotouch.co.uk/crystal-pulse-retractive-switches/crystal-pg-retractivepulse-light-switch-1-gang-black.html but in white to match our touch switches. reasonably quiet and look really nice. come in multiple gangs too. bought from these guys which were the best price i could find. https://www.ashdownhomestore.co.uk/retrotouch-switch-range-181-c.asp edit: sorry just realised you said that worked with the round back boxes. sadly these use the square backbox.
thanks @George. As an SE can you answer my question i posed above to Gus as to whether it's possible to design a balustrade to withstand the forces for fall protection where the posts do not fix to the parapet? happy to fix to the house where the parapet meets the house though as we won't have to penetrate the waterproofing there. if that's not even possible we can move on to find another solution and i won't spend any more time on it! -
absolutely. and also all relative to your risk appetite. tbh, if i had enough land and there was unobstructed sunlight to it i probably would've gone for ground mount but i want to use our remaining land for a garden and we have trees around us so with the panels being on the roof they should get a bit more sunlight.
i don't think it's off-topic and is good discussion 🙂
there's nothing un-aesthetic about the GSE panels in my opinion. people come to our place and say things like "i didn't know you had PV. i couldn't see the panels". it's not like everyone walks around looking up at the roof! i can see how that would put you off but it has to be the exception. there are always stories of bad experiences of everything and if you let them affect you you'd never do anything!
there are systems for flat roofs but most seem to need to be fixed before waterproofing. yeah. probably deemed temporary. I was thinking that we could attach to the house wall where I have put noggins in place to accept the first and last post and balustrade and then have some form of U-shaped bracket sitting over the parapet that the other posts will fit to without having to fix but I don't know if that will work or be strong enough. it's why we're considering approaching a structural engineer to do the calculations. but I just don't know how much that will cost us! I'm wondering if it will be cheaper to fix through the waterproofing and then have the roofer back in to apply another layer of the waterproof membrane where appropriate. -
Sadly we have waterproofing on both sides of the fascia for one side. -
Good point. Thank you. Think I’ll ask if he can come and have a chat about it. Maybe while he’s here checking other stuff for sign off. -
Yeah. Definitely too late for us for that!! 😢 -
@Gus Potter quick question and out of interest.....is it possible for an SE to design a balcony that could resist the forces required to pass building regulations WITHOUT having fixings on the long side of the balcony? as said we can fix to the outside of short sides through the cladding and in to the timber of the balcony. if it is possible are you able to give a rough estimate as to how much a design like that might cost in SE England? I don't want to waste a local SE's time with an enquiry if it's going to be £££ as we'd just be better off face fixing and filling with and fitting on to loads of CT1! we could then potentially get the roofer back to cover the fixings with the same waterproof membrane. -
don't get me wrong. I want to stop people climbing on to the flat roof but fall protection needs to be able to withstand specific forces etc and I was wondering if a simple barrier would suffice as if it did ever fall over due to excessive force then no one is going to fall as the flat roof is above the level of the balcony! -
yes. but that's from floor level, right? so as the tiles are about 400mm below the parapet we would only need to put a 700mm balustrade on it. the problem we have is we don't want to penetrate the waterproofing system with screws to hold down the balustrade. so we're trying to come up with a way to not have to do that and to also get it past building control. the side balustrades can attach to the outside of the balcony but the front edge has nowhere to be fixed to without penetrating the waterproofing. just another example of not knowing what we were doing at the time as if we did we would've fitted the fixing plates before waterproofing. but we are where we're at and need to find a solution. -
hello. trying to figure something out before I approach building control. we have a balcony that leads on to a flat roof. as there's no "fall" per-se on to the roof does it need fall protection or simply a barrier of some kind to stop some muppet walking on the flat roof and then falling off that? here's a photo of said balcony -> flat roof obviously the sides of the balcony will need fall protection and the balustrades will be designed as such but I fail to see why the edge leading on to the flat roof would need to resist a force that would result in a fall as there's nowhere to actually fall and maybe a simply rail will do the job of stopping someone walking out on to the roof. anyone know the nuances in the building regs on this one? cheers.
there are many knowledgeable folk on here but @ProDave is the resident sparky. 😉
might not be financially feasible but can you put an application in to demolish the bungalow and build 2 x 2 story houses orienting them to suit? could be a nice profit in it? otherwise maybe a planning consultant could help? our case officer was against our development. we got a planning consultant involved to fight our case and we got an approval. sometimes it's worth the money to pay someone to fight for you!
Finishing basement (screed + UFH) - advice needed.
Thorfun replied to Paene Finitur's topic in General Flooring
You’re worried about UFH with underlay but do you actually need the heating on in the basement? Especially in a gym! Would’ve thought you want to keep the gym cool for exercising in personally.
