Thorfun
Everything posted by Thorfun
Sign off what’s the prize ?
Thorfun replied to Pocster's topic in General Self Build & DIY Discussion
ours wasn't commissioned at the time so we just blocked off the external incoming/outgoing vents. we taped airtight membrane to them. i wouldn't bother with closing off all internal vents tbh. just block the route to the outside and job done. also need to block off soil vent pipe and any bathroom fixtures that haven't got water in the trap. basically any hole that leads to outside. -
if all you want to do is pass then i think the value might still be 10ACH? (someone can correct me if i'm wrong) as building regulations suck. i believe that anything below 5 requires MVHR so anything above that then you've wasted your money on MVHR. the lower it is the better it is. your place is a concrete box, right? so should be pretty low. good luck! -
as low as possible? if you're not fussed (and have MVHR) then below 2ACH? my target was 1ACH so knowing your competitive nature i'm guessing you'll want to get below that. 😉 -
depends on the results. ours took a couple of hours as we didn't hit our target initially so went around finding and fixing holes to bring the result down to our target value. -
Does this help?
thanks for the notification @garrymartin. we do indeed have Norrsken windows/doors and couldn't be happier. @eros_poli here's our blog post with the window install and a quick search of the site for posts with Norrsken from me will yield a lot of what i have to say on the subject. 🙂 https://forum.buildhub.org.uk/search/?&q=norrsken&quick=1&author=Thorfun&search_and_or=and&sortby=relevancy
55W is not much. the calculator i use says that 1.5mm is fine so you should be ok with 2.5mm. BUT......i am not an electrician and am not responsible should that be incorrect. there are electricians on this forum ( @ProDave for one) so they might be able to advise better.
Floor outlets required....can I use standard backboxes?
Thorfun replied to Thorfun's topic in Electrics - Other
Thanks all. -
yeah. this is what I would consider a "normal" floor box. https://www.tlc-direct.co.uk/Products/UVCSM3N.html even the 1 compartment floor boxes are too wide for me. https://www.cef.co.uk/catalogue/products/1662319-218x150mm-1-compartment-floor-box -
it all depends on the power requirements and length of cable afaik. so without that information no one can determine if the calculator you used is correct. what does your sparky say?
I need to fit 2 x double sockets in a floor in my wife's studio. they will be under her desk. the problem I have is that the joists are 300mm centres (and the posi-joists are 147mm wide so I have a 153mm gap) and so there isn't enough space for the normal floor box type fixture. so can I simply use standard metal back boxes fixed in place and then put something like this on top? https://www.tlc-direct.co.uk/Products/FP9UBCW.html?source=adwords&ad_position=&ad_id=&placement=&kw=&network=x&matchtype=&ad_type=pla&product_id=FP9UBCW&product_partition_id=&campaign=shopping&version=finalurl_v3&gad_source=1&gbraid=0AAAAAD-6GhmCN-K7_n0EaBtlr027vsR5-&gclid=EAIaIQobChMI-d-G8JSdiQMVlZlQBh3iWylpEAQYBCABEgKie_D_BwE wondering if there are any regulations against that.
+1 for this! i spent so many evenings reading this forum and what i learnt i took back to the architect and taught them some things along the way. it seems a real waste/shame to build your own house and just go for the standard spec a builder wants to do.
as above....sounds like general "standard" builder as that's "how they've always done it" 🙄 if the build is to sell on then i get that but if you plan on living there for any length of time then maybe plan to build in a way that makes it a better house. e.g. insulation levels, airtightness, solar pv etc. some people out there call that an "eco-home" but on here we just call it common sense! 😉 personally i wanted to build a house where i didn't want to spend my pension heating it
afaik class Q should be zero rated for VAT so i'd look in to that first as that's a massive saving!
Is a 44mm hockey stick enough for a 35mm2 cable?
Thorfun replied to saveasteading's topic in Electrics - Other
I fitted our EV charger to the old property but running electrics from the new property so I could charge from the solar PV on the new house. I ran 2 x ducts buried in the ground and then fed an SWA cable and a bury-able Cat5e cable. hopefully you can see them coming out of the ducts. eventually those ducts and SWA were supposed to feed a new chicken house but those plans have been knocked on the head so I'll probably just end up burying the ducts and pulling the cables back through for use elsewhere. The Cat5e cable is connected to a CT clamp that tells my charger when enough solar is being exported and then sent the excess to the car. the charger also has a max current limit so that if the total draw of the house and car ever got above a certain amount the charger would throttle the charge to avoid tripping the main fuse. some chargers have wireless CT clamps though so you can get around it but for the cost of a network cable just run one (or two) or a duct so you can pull as many as you need at a later date. -
A CT clamp measures the current running through a cable and smart things do stuff with that information. That cable doesn’t really have a cat5 cable as it has only a single twisted pair. Probably good for installers as it reduces the number of cables to run. A Cat5e cable will have 4 twisted pairs so if you only need one pair for comms and one pair for a CT clamp then maybe a single Cat5e cable will be enough. or maybe the "comms" that your charger is talking about is actually just for a CT clamp? I might suggest much more research to decide what you need. But cat5e cable is cheap so might be better to just run separate cables as it could be cheaper than that all-in-one cable. The choice is yours. -
Fair enough. We ran ducts and pulled cables through later. Only issue we had is I forgot to remove the draw string that came with the duct and that made it tricky to pull through. I won’t make that mistake again! -
You’ll need a cable for a CT clamp as well possibly. Our EV charger monitors energy production and usage in the house via a CT clamp. So I’d run 2 x cat5 cables just in case! -
Can you not just run a duct and pull it through when required? -
just checked my quote and our slider was around £5k+VAT (front door £2.5k+VAT) so sounds like they're taking you for a ride. shop around. we got quotes from 6 different companies before whittling them down and making a final decision.
Our 5m triple glazed slider came in 2 panes. Don’t remember how much it was but it was nowhere near £27k. All our windows and sliders came from Norrsken.
Speedfit pipes. What do I need to know?
Thorfun replied to saveasteading's topic in General Plumbing
Yes, straight. So as the come out of the wall I convert to copper so it looks nice and need under sinks etc. but each to their own. @Pocster has Hep2o all the way to the outlet. -
ps. it doesn't need to be ugly. but as @Nickfromwales says, I used copper for the most part as it comes out of the wall to the outlet as copper does look better on show. but copper fits straight in to the push fit fittings and so a couple of lengths of 15mm copper pipe is all you really need and zero soldering skills. -
All you need to know is that if I can do all my plumbing with Hep2o then anyone can! 😉 -
12V batteries for Loxone Power Supply and Backup
Thorfun replied to Thorfun's topic in Networks, AV, Security & Automation
batteries installed and 42Ah backup available. I like the reporting capabilities of the Power Supply and Backup on top of the whole 7 x PSUs in one unit. nice bit of kit. expensive, but nice! I'll test the battery backup during the day when the family aren't using their lights. 😉 Current usage is 93W so even if we maintained that in a power cut that would give us over 10hrs of 24V backup lighting. more than enough I think. what the reporting also shows is that we have loads of headroom on the PSUs. the ones with 10A fuses in them can take 240W so I could actually amalgamate some of the lights if I need more than the one spare output I have left.
