Everything posted by Onoff
My dad, a British Gas pensioner always swore by their service back in the day. He had an oil boiler fitted to an old system that originally had a coal boiler. In the last few years it developed multiple issues, required loads of new parts etc. They tried making it a sealed system etc. At one point they even removed the mag filter that they had originally fitted. Utter farce.
Make sure you get boom swing if you get one.
I have spoken a couple of times to Darren down there. Kept trying to tie up to get down there but it never happened. They've had displays on at for instance The Kent Show, Edenbridge & Oxted too I think. Seem open and honest. I was at the same time looking at buying a Rippa direct from China, door to door with all duties etc came out circa £1000-1500 less than Buffalo. However as I was about to press the button Rippa's rep turned into a high pressure, bunny boiler esque deal trying to guilt me into buying. I ceased all contact. A bit light on the old readies front at the moment so it's on the back burner. Managed to get my BiL to do my recent digging. Tbh I don't really fancy going down there for someone else. I'll just rub in that I can't buy one! 😢
Any good? Supplier local 'ish to me in Maidstone. I was looking to get the 1.2T version but circumstances have changed: https://buffalomachines.co.uk/products/buffalo-b1800-mini-digger
Sum it up in one sentence then... Go on.
Onoff replied to ToughButterCup's topic in General Self Build & DIY Discussion
"With hindsight I'd have knocked it down and started again". -
Not what the OP is talking about as he's confirmed above. Again an aside to the thread but on the subject of back box earth terminals, where I've come across the odd one that's damaged I've drilled and fitted a Rivnut and ring crimp Broken screw: Rivnut tool: New earth termination vs old: Rivnut shown here on a loose back box just for clarity:
Advice please: cutting metal down pipe.... without
Onoff replied to ToughButterCup's topic in Rainwater, Guttering & SuDS
I think when zinc coated steel is cut, zinc oxide forms. This acts as a protective layer. Only really works on thin sheet edges. Same with a light scratch. Won't work on say the cut end of a galvanised RSJ. Best thing for that is a Zilt stick applied with a porta pack. Most now use so called "cold galv" out of a rattle can. Zinga is very good. -
Roll a thin bit of card around the pipe and mark with a Sharpie. That'll give you a dead square cut line. Then use the hacksaw to follow the pen line, rotating the tube as you go. As in you're almost scoring it. Take it easy and the saw will follow the groove when you finally cut the tube. -
I've used Illbrück expanding tape instead of Compriband. Seems good.
So the tanking appears to have worked?
I've got a 10mm² SWA running to the charger point. Then a 20mm flexible duct cable tied to the SWA with a Cat-6e in.
Any post tanking update?
You would be amazed / shocked at the shoddy installs by "double glazing" fitters. A lot of the surveyors would under measure the gap so the install flew in. No chasing out etc. Ours got put in with damn great perimeter gaps that weren't foamed or expanding taped. They simply super glued trim over the gap and siliconed. Gradually redoing mine. Where the window is in situ I use Illbrück FM330 expanding foam. Trim removed and gap visible: Finger size gaps: Note no cavity closer either: Lots of little things you can do and it all adds up.
Soil stack to male stub - double femal connector OK?
Onoff replied to Dunc's topic in Waste & Sewerage
Yep, dry fit any solvent weld assembly first and put an alignment mark on adjoining fittings with a Sharpie. Slap on the solvent weld and as quick as you can fit together and align the marks. Nothing so complex needed here. -
I think you're mistaken 😂 -
Air monitoring thingamajig
Onoff replied to Russell griffiths's topic in General Self Build & DIY Discussion
Nice and cheap and has a phone app: I just found this on AliExpress: £24.98 | Tuya WiFi 15 in 1 Air Quality Detector CO/CO2/HCHO/TVOC/AQI/PM0.3/PM1.0/PM2.5/PM10/Temperature/Humidity/AQI Air Quality Monitor https://a.aliexpress.com/_EHYJGnQ -
To me the photos look like you already have a "double female" connector in place on each soil stub coming up. You can see there's a little internal stop that the pipe inserts as far as. In your case, more importantly it stops the connector slipping down. Each appears to then be capped with one of these. These can be simple removed by getting a flat blade screwdriver under the lip and levering up. As an aside I always use a silicone spray or smear of silicone/plumbers grease when assembling this stuff: -
Mine in the picture above is old colours, red, yellow,blue,black 10mm². Red sleeved with brown, blue as is, yellow sleeved with green/yellow and black left spare. I'm coming in through the back of the EV charger as coming up into the bottom is just plain fugly imho.
Garden Office - External stud wall on subfloor or joist ring?
Onoff replied to Dunksyo's topic in Garages & Workshops
Well worth a a watch:
You might also consider running your SWA in oversize ducting. You can then run Cat-5/6 cables etc in smaller ducting within.
