Everything posted by Onoff
3D surface modelling of randomly expanded foam to gauge the volume of filler required... Even I'll pass thanks! (Laser scanning would be the way to go I reckon...)
Low exp. foam first?
Are they accurate enough? Not sure what the tolerance is on them..... Swap 'em round on the TS and see if the same top/bottom oddity? I just use mine as a rough indicator. How many did you buy?
Are they the cheapo thermometers @newhome said about getting? Edit: Crossed posts!
I've always been told to be very careful cutting "roots" as they can take up small stones as they grow and bugger your chain.
Joking aside it's great this is getting done.
Not forgetting the cans for breakfast!
Seriously, drill holes in it with a spade bit, fill with petrol and allow to soak in then get burning! Lot of practical tip vids on YouTube.
Peter not drinking then?
It was a DWD-G1441S I believe... http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3369-generic-daewoo-washing-machine-and-washer-dryer-fault-codes LE: Washing machine door opening error The washing machine or washer dryer door has been detected as open or unlocked. Close the door! Check the door lock switch Check the door latch Check PCB & elsewhere: Message = LE Error = DOOR OPEN ERROR Cause & Solution = The Start/Hold button is pressed while the door is opened. Close the door. The switch door lock is an inferior product. Change the switch door lock. The PCB ASS’Y does not check the door lock. Change the PCB ASS’Y.
Stage 1 Is Very Nearly Complete :)
Onoff replied to Construction Channel's topic in General Self Build & DIY Discussion
Looks great! I'm sold on screeding to "rails" after doing my bathroom with them. My lounge /diner is a long and thin room like that or will be when I knock it thru. That'll get the same treatment! Mine has a change in level that I'll do away with though. What mix was that? I've never used pumped concrete, it looks very "runny". -
Possibly the best idea Iv ever had
Getting you in the mood with a bit of Dirty Dutch, CHOOOOON! -
Trying to figure this corner out. I've found some seemingly decent 18mm ply although not marine, that I can rip to do the full height, something like this on plan: What thickness do I allow for tile adhesive, which I've not accounted for? As in if I use a 6mm notched trowel does it squash down to 3, 4, 5??? Cheers -
It'll take them a while to shave YOU! -
Of course the one your mates get you will be pretending to be an Essex girl: -
My temporary fix on mine doesn't work! Done the whole roof now in weighted down blue DPM!
@reddal, did I send you info on the fabrication of steel staircases? If not pm me your email address. Cheers.
Shmoke and a pancake? -
First pumped concrete now assisted heavy lifting. Looks like those extra few pounds ain't gonna shift any time soon! -
The body dryer is magic. SWMBO gets underneath and at the press of a button comes out looking like the bird in the video! Didn't see a mute button on it though!
What finish are you going for on the rest of the sockets etc?
I reckon the new fitters have got a job lined up for that lot!
I'm going to raise the whole floor area I think. Just thought of a use for some junk I've been trying to find a use for!
