Everything posted by joe90
Wow, looking forward to questions and progress on your project.
Yes my BCO was a great chap, down to earth and accepting of new build methods 👍
When I moved into my latest cottage the lounge had a newfangled touch dimmer switch and it would randomly turn the light on or off, I changed it to a “normal” switch 😎
@saveasteading what are you looking to connect the mdpe too?
https://www.youtube.com any good?
https://www.toolstation.com/universal-adaptor-kit/p74886 This adaptor enables the connection of 25mm MDPE pipe to 22mm copper and push fit plastic pipes.
That’s a good start. Yes, what is the roofs comprised of? (Felt, GRP, membrane)
How well do you get on with your neighbour?
Drying and re-insulating a 2.5 year old damp cavity wall
joe90 replied to Adsibob's topic in Heat Insulation
Time to chill a little if you can, do you have a cross section drawing of that wall etc, it’s difficult to visualise what we are dealing with here.- 44 replies
- damp
- cavity wall
Collapsing small wall - can it be saved?
joe90 replied to johnannik's topic in Landscaping, Decking & Patios
Yes if the mortar is not too hard to clean off. -
Nor did mine (and that was Torridge in Devon) going to appeal I got exactly what I wanted and it was not as difficult as I thought, I did my own 🤷♂️
Apart from wall ties I can’t see why anything else should be in a cavity,!- 44 replies
- damp
- cavity wall
Yes I used dritherm and although the outside wall got wet the insulation did not absorb the water 👍. If the insulation has sagged due to water absorption and it looks like you are going to remove the capping can you not drag what insulation you can from above (long stick with a nail in it?).- 44 replies
- damp
- cavity wall
And if they do you can appeal, I did and won and it’s not difficult.
How much technical detail should a construction drawing show?
joe90 replied to Adsibob's topic in Damp & DPCs
Well that I think is good news in that you have identified a problem and you can move forward. Did you engage an architect? Did he specify this crap capping? If the detailing is poor is it worth going after your builder.? I get it if you just want to resolve this yourself without involving those in your build. Perhaps ask here for recommendations of products to cap that wall 🤷♂️. Onwards and upwards eh! -
I considered a ground array, was going to make it adjustable (from scaffold poles) to max out summer/winter gain .
Being a DIY fanatic and the little it will cost for a bit of plastic I would wrap the parapet up and try to see if that stops the leak. If it’s not conclusive then get experts in. 🤷♂️ it would still help if you had a sectional drawing of that wall makeup. -
Hi and welcome, looking forward to hearing your problems and helping to find some answers for you 👍
As you know @SteamyTea I am in favour of kiss plus I started doing this before remote units were available. It all started when I was quite young, watching a film where someone entered a room and switched several table lamps on from the wall switch, it’s all about choice.
That’s not what I said, That is what I said, I like to be able to switch standard and table lights from the door and if you fit several sockets you can move lights and furniture around and still control then from the door, usually only fitted in a lounge.
