Our water is so hard you get a scuddy line in the toilet bowl.
No they do a sort of re jig, blast themselves out, it can be noisy and can also deplete water pressure im told. im not worried about noise, so I want to be able to alter the time it does it.
Looking for recommendations on a quality water softener. things it must have. Hi- flow ability to time the re -gen cycles I don’t want it kicking in randomly when I’m in the shower and stealing my water. quality more important than cheap n cheerful. what we saying people.
Depends how poor the finish is on the original concrete. you can use 25mm of polystyrene insulation on top of the concrete and below the damp proof membrane to take out any lump n bumps or sharp areas. if it’s really bad a few bags of cheap self leveling compound to take out the worst bits.
@Big G get that changed that outer detail is horrible. @smurph306, yes it’s up, yes they made a YouTube video of it, but is it good construction with good methods used. then I would say no. If you want to chuck up a quick extension then do what they did, if you want it better, with less problems then ask some more questions on here. there’s a lot of talk on here recently of small timberframe extensions and BC being happy with them, I’m wondering how long it’s going to be before they start rotting out at the sole plate, due to poor details and poor maintenance.
Smooth Finish Composite External Door?
Russell griffiths replied to lpear's topic in Doors & Door Frames
a very dirty norrsken door, it is timber, they do do aluminium clad timber as well. I think that was £1800 with the sidelight. -
What’s your budget ?. ours came from norrsken, proper bit of kit, but will be £1500 ish. -
Week 1 - Finally clearing the site
Russell griffiths replied to AppleDown's topic in General Self Build & DIY Discussion
Get some 3x2 timber, make a cross brace inside the playhouse to brace it up and lift it with the digger, two large straps around it. -
Why the compression wall plate, end feed and solder it. then straight coupler.
Best way to shorten a joist?
Russell griffiths replied to Sparrowhawk's topic in General Construction Issues
If it’s one duct then why not just drill the hole and put it through the joist. appropriate reinforcement to the joist will be needed. presuming 90mm duct. -
Floor outlets required....can I use standard backboxes?
Russell griffiths replied to Thorfun's topic in Electrics - Other
I’ve got a standard metal back box under my wife’s sewing table, takes a two gang face plate with cover flap thing. -
Disclaimer. This is a bodge up, but will get you a few years before you need to look at it again. Did the same job this weekend on a building that will be demolished in a couple of years. strip off 1400 x 1400 area back to the boards rip up the soft boards back to the joists cut a patch of new plywood or osb to fill the hole. cut felt and stick down to match height of existing roof, or higher.NOT LOWER. fill all gaps and joins with a roofing type sticky something clean an are far larger than patch 2mx2m cover entire area with a fibre reinforced coating. BOSTIK FLEXACRYL is what I used, very impressed but not cheap.
I think you need to re think this whole operation. you started off with saying you where getting a 3 tonne machine with a pecker, how has this jumped to a 7 tonner and a pecker, it could be that’s what you can get locally. if you get a bigger machine you certainly don’t need the pecker. just pick the slab up at the corner and drop it a couple of times. if you purposely want little bits of concrete then get a smaller machine 2-3 tonne and a pecker. look up the specs of the machines, as you are finding out a 7 tonner is significantly bigger than a 2-3 so far more likely to be able to get into the danger zone of working near cables. stop and re think this job, you will end up using a big hammer to crack an egg. big machines are brilliant at getting lots done, but for an amateur you can make a lot of mess and a lot of damage very quickly. 3 tonner for a weekend will see all that concrete gone. picture is an 8 tonne machine.
TBH whoever is laying your LVT should do the leveling, it’s not as easy as it looks, and is easy to cock up.
More context needed. Why are you pouring in one room and not the other do you have different floor finishes at different thickness so need to raise one more than the other.
Get down on your hands and knees, and get the hoover hose, scratch away at the insulation and hoover at the same time, don’t use anything to damage the pipes. put conduit around the pipes and make sure you have 20 mm deep clearance below finished floor level. then use a high build floor leveling compound, pour it in and crack open a bottle as you admire your masterpiece.
Plant hire insurance
Russell griffiths replied to flanagaj's topic in General Self Build & DIY Discussion
Lots of nice machines around for £12000 ish. after 3 years you will get £10000 back on it. -
Add it to your self build policy. it’s far too expensive to get it separately. have you thought of buying your own machine. -
I think it’s hard to answer this without being in the room. I would get your props in place, get the steel in position, knock the old wall out, cut out for padstones, lift up steel, put jacks under steel and wind up tight, then have a good look. does it fit tight to all the joists, can you even out the level by bumping up one end 5mm. have a play I think you will get a better feel for it when the steel is in position.
75mm keep it for the floors, double it up to 150, stagger the joins.
you need a floor leveling compound that is designed as the finished floor there are lots available do not use the cheap shite it will just wear away. you will need to hoover the floor spotless and soak it in primer, you will then need to prime it before the leveller goes on. read instructions on leveller and buy the appropriate primer. do you want it flat and level and smooth or shit but painted a nice colour. wont be cheap going to cost you£3-400. no miracle paint or surface hardener will get rid of the crap surface, they will just stop it dusting up.
