Russdl
Everything posted by Russdl
Octopus say you can. I’ll see if I can dig out their words later on.
Wasn’t it just. What an amazing place this is.
ridge tiles Does this make sense?
Russdl replied to Confused123's topic in Roofing, Tiling & Slating
I guess it was always that high as it’s just been resurfaced but what a state. The flashing looks diabolical along with everything else. -
Wife has decided we need cooling next year
Russdl replied to JohnMo's topic in Air Source Heat Pumps (ASHP)
Or you could always go for trees… -
Horses for courses but I think that looks great!
It’s 45 days since I cleaned the MVHR filters and whilst I’ve not had a ‘message’ telling me to clean them the MVHR did seem a bit noisier, nothing excessive but as it’s normally pretty much inaudible the fact that I could hear it sent me to the loft to investigate. The intake filter is quite bogging after a month and a half, the extract is not too bad at all considering doors and windows have been opened as required to off load unwanted heat. The pre-filter seems to be doing its job, this was a brand new pair of tights a month and a half ago! I wonder if the pre filter housing is actually enticing critters in? Again, this was cleaned out a month and a half ago. The coarse mesh of the intake grill is covered in cobwebs, as is the duct into the house though they don’t show up too well in the photos. the joys of living in the countryside, spitting distance to the wheat field that was just recently harvested I suppose. I opted to replace the intake filter as vacuuming it achieved the square root of bugger all. I didn’t think to check the MVHR fan speeds before and after the service but it seems quieter again so I’m assuming the crud was restricting the airflow enough to cause the fan speeds to increase to maintain the selected airflow.
- 100 replies
- mvhr vents
- filter
Keeping a passive house cool
Russdl replied to Russdl's topic in Energy Efficient & Sustainable Design Concepts
@Ferdinand it’s very manual (so not very passive) and relies completely on my unhealthy obsession with the outside air temperature. The blinds and MVHR could be automated I suspect but not the door/window opening.- 30 replies
- passivhaus
- overheating
(and 2 more)
To highlight that point, our neighbours have just returned from a weekend away, probably to a hot house, and they have now opened all the windows. It’s lovely and breezy out there, but it’s also 30 degrees out there so they will be filling they’re house with 30 degree air which probably isn’t for the best. I could go and tell them but as they don’t speak to us since the slab was power floated, I won’t bother. 😁- 30 replies
- 2
- passivhaus
- overheating
(and 2 more)
We clearly have similar tastes 👍- 30 replies
- passivhaus
- overheating
(and 2 more)
Good point. Ours provide plenty of privacy by day - you can’t see in at all - but by night (when they’re usually up anyway) they may as well not be there. A bit like the net curtains of old.- 30 replies
- passivhaus
- overheating
(and 2 more)
😃 I wish!! But they do work well on smaller hoses as well.- 30 replies
- passivhaus
- overheating
(and 2 more)
Clearly the best and easiest solution if you have the space to do it, and you can do it without killing the PV at the same time.- 30 replies
- passivhaus
- overheating
(and 2 more)
I think you'll find you're right 👍- 30 replies
- passivhaus
- overheating
(and 2 more)
And in case anyone is interested in the blinds, it's these.- 30 replies
- passivhaus
- overheating
(and 2 more)
- 30 replies
- passivhaus
- overheating
(and 2 more)
Russdl posted a topic in Energy Efficient & Sustainable Design Concepts
We learnt how to keep our house cool this summer and thought we'd share what we've learnt in case its of use to others. We're in a timber frame building built to the Passivhaus standard but not certified. We don't have an ASHP, so no slab cooling for us but without a doubt our (not so secret) weapon are the external blinds. All our east and south facing windows (with the exception of 3 east facing windows - more on them later) have external blinds and as predicted by the PHPP these are the game changer. Our secret weapon is the little personal weather station (PWS) in the garden and with it's help this is how we've kept the house cool: In the evening when the outside temperature according to the PWS is below our target internal temperature of 21 degrees all doors and windows are opened and the MVHR ramped up. Overnight all the inward tilting windows are left open with the MVHR staying at a higher level and it stays like this until the PWS shows that the external temperature is rising towards our target 21 degrees - that happened at 07:50 this morning. As soon as the exterior temperature reaches our target then all doors and windows are closed and the MVHR is reduced to its lowest setting, we monitor the air quality with a couple of CO2 monitors as recommended by @Adrian Walker and increase the MVHR speed as required to keep good air quality. All sun facing windows have the blinds down, we have the mesh style blinds that don't block off the light but stop lots of UV. With this technique our hallway temperature has peaked in the early evening at around 21-22 degrees and the kitchen/dining room which has lots of east and south facing glazing has stayed below 24 degrees. As soon as we open up we get rid of most of that unwanted heat. The hallway starts in the mornings around 19-20 degrees. The reason I think the PWS is a secret weapon is as far as I'm concerned you need to accurately know the exterior temperature and when to let it in and when to keep it out. On a windy day, 26 degrees can feel cooler than 21 degrees but if you let that stuff in the house you're gonna regret it. If you don't have a PWS you'll probably be able to find one situated close to you on the Weather Underground website. Oh, and the 3 problem east facing windows without external blinds: 1 is the utility room. That has an internal blind and as it's the utility room the internal door to the rest of the house is kept closed. That room gets warm 25-27 degrees but the heat stays in that room which of course has an MVHR extract so the heat is slowly being pumped out of the house until it's door/window opening time then we throw the heat away with vigour. 2 is the ensuite which we deal with in exactly the same way as the utility. 3 is the main bedroom which has a great big window and curtains. The curtains remain closed while the sun is coming in that window but the doors are open so as that room warms up its heat is not being contained in that room. As the sun moves round and that window is no longer in direct sun the curtains are opened and a big old chunk of hot air falls out to be slowly extracted until window opening time. To me, its like the house taking a long overnight gulp of cold air and then holds its breath throughout the day until the temperature is 'just right' again.- 30 replies
- 8
- passivhaus
- overheating
(and 2 more)
Anything but (in our case at least). Right now nearly every window is tilted open and will stay that way until morning whilst the house takes a big long breath of cool air. In the morning when the outside temperature gets to that of the inside temperature then everything will be closed up and the house will keep its cool until tomorrow night when we will rinse and repeat. We also turn the MVHR down to its lowest setting when it’s properly hot so that it’s not breathing in more hot air than absolutely necessary. It’s worked a treat - no overheating at all.
MVHR cooker hood idea
Russdl replied to woodman's topic in Mechanical Ventilation with Heat Recovery (MVHR)
We have a recirculating extractor which vents down by the kick board a few feet away from the hob (after going through grease and charcoal filters) in line with an MVHR vent in the ceiling above. The extractor does its own thing regarding speeds, run on time etc. We never boost the MVHR. It all works very well. -
Silicone render at night with lights on. Is this normal?
Russdl replied to Piggybagpop's topic in Plastering & Rendering
That’s got to be a ‘no’. Down-lights do highlight the imperfections but that is extreme to put it mildly. An expert will be along soon to help, I’m sure. -
Have you looked at wood plastic composite cladding (WPC)? It’s reassuringly expensive but won’t change colour apart from fading a bit over the years. We’ve used the dark grey which has moved a bit in this recent heat on the eastern elevation, aside from that we’re very happy with it. Here’s a screen grab from the envirobuild website, other WPC is available.
It used to be that you had to be on the Agile Incoming Tariff to get the ‘Outgoing’ tariff. Has that changed? The half hourly changing Incoming Tariff can be brutal, I was on it over the last winter (when, of course, there was very little ‘outgoing’)
I had too much time on my hands, so I watched the video. Utterly brilliant.
There is no FIT anymore. If you have the space for more PV I’d say “go for it” regardless of what other decisions you make.
