Hastings
Everything posted by Hastings
MVHR commission template / cert
Hastings replied to Oz07's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Anyone come across PEATA (Professional Extraction Airflow Testers Alliance) here? For £80/yr and 1 hr online training - it's not clear if there is another charge for this - you become a qualified tester/commissioner and get one free meter hire. -
Understanding building regs about stoves (Scotland)
Hastings replied to ProDave's topic in Stoves, Fires & Fireplaces
Thank you @ProDave I just received this from my BCO: "Building Standard surveyors are not registered to sign off Hetas registered installations. Please submit an installation certificate" Not clear if that means I can only have it done by a HETAS contractor? Nearest HETAS person is a long way and would need overnight expenses and a lot of mileage costs etc. Some people say that in Scotland you can self install a wood stove and BC will sign it off if it complies. Does it just depend on which council area your are in? They each make up their own rules? Can BCOs keep insisting on additional installation certificates, not included in the warrant, for various things in addition to the gas and electrics? It's adding £1000s I hadn't budgeted for and I don't know where it will end. -
Great topic full of very useful info. Reviving it due to specific Scotland requirements. @ProDave @Crofter Did you need to get HETAS certificates for completion/sign-off with BC? -
Totally agree. Why private houses have to be built for public use is baffling.
Be aware that the regulations are designed and applied to the house not just to suit the first or current owner. I found this out the hard way when, after getting through planning and getting a building warrant to start work I was informed by Public Health that even though I had no baths or flushing toilets in the property I would still need to be able to provide enough water (no mains is available) for 150L/day per person (=900L/day for my 3 bedrooms) "in case a future owner wanted them installed." So my rainwater storage system plan was ditched - it needed to be so large it would have cost almost the same or possibly even more than a borehole (my only other option). Another blow to the poor old environment.
How to fit acoustic insulation to Posi joists
Hastings replied to Hilldes's topic in Sound Insulation
I must be being stupid, but could you confirm that you really mean use 600 wide stuff for 400 joist centres? Only, the gap between the posi joists chords is only 300. Never used it before but it seems like squeezing 600 stuff into a 300 gap would be hard and would also reduce the effect of it due to too much compression? I am about to insulate mine and I had planned to use 100mm thick acoustic roll and use the ready cut 400 widths to push up there (and not bother getting inside the joist voids too much). Is that a bad way to go? Thanks. -
My understanding is that this might not be ok because standard wallboard like Gyproc wallboard even at 15mm is only 9.8kg/m3 according to British-Gypsum's data sheet for it. The Scottish Building Standards minimum is 10kg/m3 - eg. 12.5mm Gyproc Soundbloc or Wallboard Ten. Please correct me if I am wrong - it will save me loads of money.
This might be England regs? In Scotland it is different and the exemption stated is: So, unless I have missed something, you need to waste some money and speed up wrecking of the planet upgrading walls with doors in them too.
Not me, did you mean someone else? -
I have been told by my BCO "installation and commissioning certificate is required" because it is "an integral component of your dwelling". When asked what qualifications of a suitable contractor I would need to hire for a valid certificate there was no relevant answer other than recommending an HVAC installer 4hrs travel time away from me. I will be going the self-certification route at completion next year. I won't ask for approval beforehand. (I am an expert in airflow after several decades professional experience in close up bird flight photography :) Could some kind person please point me to info on hiring/buying meter like a Testo 405i to take the measurements? -
@HilldesI'm just going by the official Posi installation pdf from their website that I used to install mine. Yours might well have different specs and method etc. -
Isn't there a section of 2x4 strongback missing in the last photo? All the joists should be cross-connected to each other I think? -
To loft or not to loft?
Hastings replied to Barnacles's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Did you find out about this? I hadn't come across it and am about to start my MVHR installation. Had been worrying a bit whether burying the ducting under the loft insulation was going to be very effective, especially as it has to cross over some of the roof trusses. Was planning to lay 100mm insulation first, then the ducts, then 200mm more and hope the ducting doesn't prevent the insulation from fitting together snugly. -
Steico Flex wood fibre in short supply - what's the alternative
Hastings replied to Adsibob's topic in Heat Insulation
There is Pavatex/Pavaflex wood fibre insulation. Made in the same factory as Steicoflex. Both are breathable and wick moisture so check your design doesn't rely on that. They are generally used in combo with a techno VCL or none at all too. PIR if you use it best fitted with Gapotape otherwise is unlikely to insulate very well.- 16 replies
Fresh air is about 20% oxygen, a tiny fraction of a percent is CO2. It takes days in a sealed room for O2 levels to get low enough to affect you badly but rises in CO2, even though very small, affect us quite quickly. I think that's why there's little interest in measuring O2 levels - it's very hard to run short of it simply from breathing, even in a highly airtight house.
@saveasteading There isn't a requirement for an alarm, only a visible display, of CO2 level. I am fairly sure that is because you cannot normally die in your sleep from high CO2 levels. CO is the cause of that danger as we don't have a natural body alarm for it. A normal healthy person automatically wakes up if O2 and CO2 levels are reaching seriously bad levels. Hence no need for an alarm in every bedroom. I am no expert so please anyone correct me if I am wrong.
Regs state: 3.14.2 Ventilation awareness in dwellings: " CO2 monitoring equipment should be provided in the apartment expected to be the main or principal bedroom in a dwelling where infiltrating air rates are less than 15m3/hr/ m2 @ 50 Pa. " Is it required for a newbuild airtight build with MVHR system, for when there is a power cut?
Thanks but no, I think that refers more specifically to moisture within the actual building materials. This is a bit different.
It much more than annoys me - I may start a public campaign against it. It is an unfair stealth tax that few people except commercial developers even know about. In Scotland (and probably the other nations also) If they discover something they like the look of and want to document, record and/or take away there is no cap or limit on the costs you are liable for, whether you have £5 to your name or £50m. Any artifacts found do not belong to you. The only slight saving grace is that the archaeologist cannot instruct the digger to dig beyond what is required to complete your works. They can only tell them to stop, apart from if human remains are found and then police are called and it all changes. The Argyll & Bute pre-application process (designed to save you wasting your and their time on a full planning application) is designed to prevent unwanted surprises by warning of issues that might arise. The paperwork even mentions archaeology specifically as one of the possible issues. But then the smallprint says the council has no liability and you have zero come-back if something gets missed in their report. This enables an archaeology order to be placed on your project later and without warning and as a condition of your full planning permission if the local council archaeologist decides on it based on other data in the vicinity. The reason for the surprise ambush is presumably to try and stop developers burying or destroying archaeology on the quiet in advance. This based on personal experience. I was lucky (most people are) to get sign-off on site in a day with nothing found and an archaeologist's bill of £1000, of which £134 was a fee to the council archaeology department.
One of my roofs was in a similar state of repair to yours, it sounds like, and I really wanted to avoid total replacement but was advised that a new roof would not be much more expensive than repairs followed by regular ongoing repairs. When I added on the peace of mind factor (lying awake at night listening to the wind) and personal time and 'cost' of dealing with ongoing repairs I felt that argument was right for us. But we are exposed coastal. No trees for miles. New trusses also provided the basis for the upper floor ceiling thus helping with the new internal timber frame walls build. Mine is a 2 storey building which makes the argument for spending more on the roof stronger than if it was a single or half storey like yours. Greater costs for me were in repairing the chimney breasts (you have none) and two of their flues, replacing all stone lintels (mostly all cracked) and timber lintels with concrete ones (4 or 5 per opening). My roof turned out quite inexpensive but it has no hips, valleys or dormers or lights. With your steading, if you keep the floor, raising the level with insulation, you might need to raise the door/window lintels too? Some look very near to eaves wall plate height already. If you do a new roof you have the opportunity to perhaps raise the walls and roof a little.
Forgot to mention in earlier long post that in my case this still left not enough height left to include UFH.
There's an official technical term for it I can't recall, so it must be true. Something to do with build up of moisture in the space in summer. @scottishjohn They have to go through total wall and the old walls are 600 thick so air bricks would be difficult except the odd place like under some of the windows which are like mini bays on the inside. The vents are only at the wall base, 300 off ground level. Building control insisted on it, it was not in the original submission. Yes, top of walls left open to a cold roof space. There are no soffits. Roof is self-ventilated through the gaps in sarking boards, the roof membrane and gaps between slates.
New Washing Machine v. New Generator - not working
Hastings replied to MrsMozart's topic in General Alternative Energy Issues
I have a Victron EasySolar inverter/charger wired to a battery bank to power an off-grid house. The 5kVA model was specified specifically to deal with the demands of a clothes washing machine in the house. Otherwise I would have got a smaller model. The 5kVA model can handle brief peaks of more than 5kW which I understand is not unusual with washing machines when the drum motor starts up. The EasySolar has a 'PowerAssist' function. This is when the battery bank automatically supplies the extra power needed when a generator connected cannot manage the demand. Many of the other Victron products have this same feature I think. If you want expert advice on generators I can recommend petepowerblog.wordpress.com wholeheartedly. He helped me a lot and for no charge with my small petrol generator problems before we got the PV and Victron system up and running. Somewhere on his website I think he warns against damage to motors in machines when the generator is not plenty powerful enough due to the repeated slow run up time causing over-heating in the windings (but don't quote me on this).
