Hastings
Everything posted by Hastings
  1. Where you successful in your VAT claim re. the stove @joe90 @nod ?
  2. I had a long talk with one MVHR supplier based in Scotland specifically about moisture as I wanted clarity on whether MVHR did or did not act as a dehumidifier. I never really understood the reasoning for his answer "yes, under all circumstances". This topic opens up the same question, I think. For the house I am on the cusp of fitting a new MVHR system into, in a generally high humidity (all year round) climate of seaside west Scotland, I want the driest possible air entering the house, so definitely no enthalpy type exchanger required. But I was also under the impression that the condensate created by a standard MVHR heat exchanger was moisture coming out of the exhaust air (inevitably as the result of cooling) and that the incoming air was simply always carrying the same moisture level as air outside the house. So how is very moist air entering the MVHR on a rainy day in summer going to be able to leave the house carrying more moisture than it entered with, assuming the temperature inside and outside the house are pretty much the same (and that nobody is at home producing extra water vapour)?
  3. Where did you locate the two vents on the house? Asking because I am about to install MVHR in a house also very windy and exposed. 50-60mph days are common and we are miles from nearest tree or hill. Because house has 600-700mm stone rubble walls (cladding a 150mm inner airtight timber frame) fitting ducts in walls is far more difficult than going through roof but I worry that the roof location will be severely affected by strong wind.
  4. I can't get hold of my engineer to check if clipped head nails are okay for the structural frame and sheathing (a Scotland build). Anyone know for certain or where I can find out? Building control officer doesn't communicate so not an option to ask them.
  5. Universities Federation for Animal Welfare: “Release of an animal elsewhere is not necessarily a humane thing to do – translocated animals may fail to adapt to or integrate into new territory and may suffer and die as a result (Mason and Littin, 2003). Killing is much less likely to carry a risk of causing suffering than release in an unfamiliar area…” Humane Society International: “Treating the symptom by eliminating a single rat/mouse — or even an entire colony — is ultimately futile unless the conditions that encouraged them to take up residence in the first place are addressed. Over time, others will simply move in to the vacated territory.” “Captured mice should be released in the garden in dense vegetation (such as a hedge) or, even better, near a shed under which they can shelter, as far from the house as possible.” The reference to Mason and Littin 2003 is a study by Oxford University dept of Zoology “The Humaneness of Rodent Pest Control” that puts catch and release lower in the humaneness score than killing. With small mammals, checking a live trap once a day isn't frequent enough.
  6. I would definitely not release mice any further away from where nearby resident ones will already be living, probably just a matter of a few metres from your garage. Finding any suitable but also unoccupied territory at any distance away is practically impossible, and the further away you take them the greater the stress and likelihood of death you cause them.
  7. In this day and age and the Animal Welfare Act (2006) legislation http://www.legislation.gov.uk/ukpga/2006/45/contents , I personally wouldn't take the risk of publicly suggesting something that might be illegal, which deliberate drowning of a rodent almost certainly would be. The law is complex, often quite surprising and little known about by the general public. Certainly there is no particular right in the UK to choose any method we like to kill an animal. Relocating and releasing a live-trapped vertebrate is possibly unlawful in the case of mice, definitely unlawful in the case of certain specific species (and not just pest species like grey squirrel or signal crayfish).
  8. Mice are good swimmers and not afraid of water. Be aware of UK law when it comes to dispatching them https://www.gov.uk/pest-control-on-your-property
  9. There is a Hikoki gas version at £290 - the gasless one is £440 (with batteries) and although I doubt I will get enough use out of it to benefit from the lower running cost, after re-sale it's not going to be an issue.
  10. Thanks Russell. I'm drawn to the Hikoki - almost half the price of Paslode. Any problems with the gas (pressure?) in the +5 to +15C range I'm likely to be working in? Is it like with Propane vs Butane in lower temperatures?
  11. Working on my own and on a steep learning curve I won't be firing 1000s of nails a day, so lower battery capacity caused by temps is not likely to worry me. Running out of gas canisters would be a bigger issue as everything like that comes via ferry so I would need to over buy on gas to prevent that. Modern Li-Ion batts are so much better in cold compared to the Ni-Cads I was using in the 90s (when I had to get by with them on a cine camera in -40C). Anyone know about the Dewalt or other battery-only first fix nailers?
  12. Good point. This project is off grid and whilst we will have 240V from sun and wind to batteries at some point, for the moment a small petrol genny is our power - makes running an electric compressor not a sensible option I think. It's an island site too so transporting compressor will add cost again.
  13. Just for the record regarding screws for framing, since nobody has mentioned them yet, I was looking at these kind made specifically for timber framing (Simpson do something similar) :
  14. My roofers used a gas canister Paslode and I didn't notice they had any issues with it but then I was paying for all materials including gas. There are about 5000 of 63mm nails needed just to fix 11mm OSB sheathing to all the walls and to the upstairs ceiling. That'll be getting on for £100 in gas plus I'll be working in cool weather (7-11C range). Wouldn't I be better using a battery only gun like the Dewalt? I will build the walls in sections then fix in place, therefore will be switching between 2 or 3 different nails (90mm, 75mm, 63mm) - how much an issue is that in practice? I've never used one.
  15. Thanks for the replies. Very useful to hear viewpoints from outside the box. I hadn't thought about the added cost of 1,000s of screws vs nails. I'll go with nails and can stop worrying about the structural implications of not using them.
  16. 90mm Round Wire and 75mm Ring Shanked x3.1mm Paslode nails are specified in the engineer's drawings. I think it is pretty standard for 2"x4" structural framing sheathed with 11mm OSB. Did your engineer approve the screws instead?
  17. Are screws an acceptable alternative to using nails in a timber frame structure or are nails the only fixing flexible enough for the task? I want to avoid the cost of a nail gun but also having just demolished the ptevious timber frame build I'd like to make the new frame easier to demolish without damage to the material when it's time is up. The build is inside an existing stone building on two levels and will not be supporting the roof.
  18. Thanks for the help and ideas everybody, I've now headed over to the Timber Frame forum here to learn more.
  19. Yes, that's the current plan but I'd like to improve on the design details ie. get the upper floor joists to be contained within/inside thermal envelope and sole plate insulated from foundations concrete. I don't feel like I have the best stick frame design details in place. Is there somewhere online I can refer to for current best practice?
  20. Thanks for that very clear explanation. I now realise that what I was thinking of is not really SIP but perhaps semi-SIP, where two OSB layers are seperated by timber framing and then insulation blown in on site after construction. Posi joists barely penetrate the walls at all. I've noticed this from several Passivhaus new builds (e.g.. @JSHarris's very helpful draw gs) I will need metal web floor joists to facilitate air ducting.
  21. Useful suggestions Thank you. Will look the GBS project up. Who is MBC? I'm aiming at adding only 150mm to the existing 500-700mm walls so not that much impact on floor space. In fact I look at the reduction as a positive, being a fan of less is more. I would go further but for the not so positive 'tunnel' effect on window openings (even with their angled reveals). The current design has Simpson L brackets fixed to ring beam and to external wall just to tie in walls as well as maintain 25mm air gap and maintain air flow up to roof space. Compacfoam is interesting - will have a look at that. Having the upper floor resting on the stone walls instead of on the stud frame would allow a reduction in the framing and therefore more insulation in place it.
  22. I can't imagine any new refit of today not becoming very obsolete within a very short time compared to the overall life of the building (approx 150 yrs to date) - say 30-50 yrs tops? Never heard of foam as best way to waterproof rubble walls.
  23. Yes roof is fitted. I would assemble the panels inside the house, in sections and stand them up into position, yes, the same as the with a stud frame design. It sounds as if I need to understand more what a SIP actually consists of.
  24. This is more farmhouse than croft so two full storeys and the roof space will not be used for living space. The new roof trusses tie the wall heads together. I hope the old rotten mid floor was no longer providing any structural help because it was removed a few weeks ago in preparation for the new internal concrete floor - footings for the timber frame build. I will not use any foams or foam, spray or board based, when it can be avoided as I can't imagine how it will be disposed of at end of life. I've also seen how boards like Celotex can distort and shrink after storing a leftover sheet loose in my garage. I will be using wood fibre insulation. The air gap between the new stud frame and the old stone wall has to be lightly ventilated with small holes in the stone wall 300mm above ground level every 1.5m and open at the top to the roof space. I would rather not ventilate that much but Building control insisted.
  25. The project is an internally insulated airtight/MVHR refurb of an old rectangular stone house on two levels. A standard way to do an internal insulation refurb of an old solid stone walled house in Scotland is to build a new internal timber stud wall, set 25mm back from the outer wall. In my case the wall is proposed as 11mm OSB, 95mm timber stud infilled with insulation, 20mm insulation board, plasterboard and skim. This seems a sensible option if the existing old upper floor(s) structures are to remain. But what if, as in my case, the upper floor is condemned due to woodworm, wet and dry rot and has to be entirely replaced with new floor? Basically the whole house is now stripped out and new roof fitted, leaving a 'barn' like single interior space. In this case, is there not an opportunity for a thermally more efficient SIP (structural insulated panels) type inner rebuild? In the timber stud wall design I have for my project the engineer has specified a new upper floor structure made up as a stressed deck (plywood screwed to 445x45 joists) that spans the entire open plan ground floor 10mx5.5m kitchen/living space, supported only around the 4 wall edges. What I don’t like about this is that the floor joists extend all the way across the top of the ground floor stud walls, in the form of a double joist ring-beam going around the entire perimeter, thus interrupting the thermal continuity between ground floor walls and upper floor walls. I would much prefer that the whole floor deck hangs off the inside face of the new timber wall without obstructing the thermal envelope, as I understand to be the case with SIP construction. SIP construction of course is in its element when it comes to new build but is there any reason why the design is not also very suitable for putting together from scratch on site in a major internal refurb of an old house?
