Hastings
Everything posted by Hastings
From the clever folk (I have no connection with them) who created the embodied carbon database for the Royal Institute of Chartered Surveyors. Worth a look if you care about your carbon emissions/footprint when you buy the cheapest PV. Good summary at the bottom of the page. https://circularecology.com/solar-pv-embodied-carbon.html
Minor update: The pump IS after all running up to almost full power consumption 1.1kW, not just up to 600W as I posted earlier, which was what I recorded in response to a short toilet flush. However, it does so for a much much shorter time and starts slowing down towards a stop once the demand ends, far sooner than before. So quite a bit less power is being consumed per litre pumped than previously.
BINGO! Swopping over black and brown seems to have fixed things entirely. Can now set the static pressure up to 2.5 bar (haven't tried higher yet as I haven't got time right now to check for leaks in the house) and the pump now draws up to only 600W or so. I can't tell you how happy I am and how grateful I am for everyone's help. Max cudos and thanks to @sharpener of course for taking quite so much trouble.
Ah, you are correct, thank you. My pump is a speed controlled version - has a separate box/inverter with it to control speed and set the switching pressure - the graph I posted above must be for the pump alone. It has been disconnected for shipping back to the supplier (the pump and controller units in separate boxes) and then back to me. Maybe they wired it differently for their tests. The wiring I have used is according to a colour diagram label on the pump body but the electrician gave me a different mapping over the phone (he didn't sound too sure and so I chose the former). I don't recall if I checked this with Tom at 3PTechnik. Perhaps the one on the pump is for Italy 3-phase and different to UK 3-phase . Wiring for my pump (Output:grey, brown, black green/yellow. Input 240V) within the controller:
I had forgotten that the pump does indeed have 4 wires which are for 3-phase connection. Is it possible that I wired it up wrong? I assume that if I had wired it wrongly then it would not run at all or run in reverse or something else other than pumping poorly. Correct, I have been reporting only static pressure against a closed stop tap, not dynamic pressure. I am also baffled as to why adding the pressure vessel (and a little more piping) resulted in a better static pressure result. I noticed, only now, from the manufacturer's data sheet power curve that power consumption is a pretty constant 1.2kW at all flow rates. That is a surprise (and a disappointment) but at least it indicates that the pump is behaving normally in that regard and not necessarily 'struggling' as I had assumed. I bought the pump from 3PTechnik and have had much correspondence with Tom and his colleague who carried out the testing.
Tested the pump and controller on a neighbour's house single-phase mains supply yesterday and there was only a very a small improvement in maximum static pressure achievable: 2.0 bar, instead of 1.8 bar I get at my house. I was not able to measure the power drawn but it appeared to get up to pressure faster and without reaching full rpm. What was interesting was that when I first tried the test I did not include the pressure vessel in the output and the pump could only achieve 1.2 bar.
Yes, 1.3m annual, Met Office data. Low lying islands are quite a bit dryer than mainland A&Bute. Rainwater will be used in the kitchen, basins, shower. Just trying to point out in this discussion that any roof design for water collection can only, for the vast majority of UK housing, be a partial solution and therefore unlikely to be cost effective. Unless the law is updated to allow householders to use much less if they want.
Pretty sure that rainfall is not sufficient in UK to supply toilet flushing needs in most houses occupied by more than perhaps one person, even if you have sufficient storage to catch every drop. My house with adjoining garage in Argyll & Bute has a big 160sqm roof and receives twice the annual rainfall than eg. Oxford yet is considered by the local authority to be insufficient for more than 2 people.
Pressure relief drain for heat pump heating circuit.
Hastings replied to sharpener's topic in General Plumbing
I believe it is acceptable in Scotland building regs to plumb this to a drain stack rather than directly to outside but I may be wrong. The main issue though is how to prevent gases from the soil pipe entering the house - normally a u-bend trap is fitted but this will dry out and fail without regular topping up - a dry trap, fitted vertically, is better. -
How acid is your rainwater? Does it matter?
Hastings replied to sharpener's topic in Rainwater, Guttering & SuDS
We regularly get some salt from the sea sometimes but it's probably not enough to raise the pH of the rainwater in our 10,000L collection tank. Proximity to urban centers, where more SO2 is emitted, is the main factor. https://naei.beis.gov.uk/data/map-uk-das?pollutant_id=8 Acid gas and aerosol monitoring sites: https://uk-air.defra.gov.uk/interactive-map?network=aganet -
Southern inner Hebrides. Local contractor suggested and supplied Juraperle pH correction, remotely. Surely only a rough and easy solution, given the variable flow rate expected. I am back on sit 16th July. -
Our slate roof collected rainwater measures 6.6 pH by a council approved lab, which is just inside the permitted lower limit 6.5. We have been prescribed Juraperle granules to put in a standard clear 10" long filter housing, a few handfuls to start with, to add to as required to get up to at least neutral pH 7.2. I don't have any pH testing means. Did you try the electronic pen type pH meter? Quite expensive but maybe a good investment if it means preventing plumbing parts like springs inside pressure reducers being damaged. -
@sharpener Wow. I am grateful, somewhat lost for words and humbled by the expertise, time and effort you have put in to this. Thank you. I had already been thinking about the logistics of taking the equipment to a friend or neighbour's house to test. Now it looks very much like a worthwhile undertaking. Yesterday I tried running the generator into the system while pumping water but it made no difference. The generator is only 1kW, its function being to charge the battery bank when solar is insufficient, so I cannot run the pump off it directly. The SoC of the battery bank doesn't vary the behaviour of the pump at all other than stopping it entirely when the DC voltage drops below the Victron shutdown limit. So I think you have very likely found the answer but frustratingly I can't do the phone-a-friend and house mains test as I've just left site for the next 2 weeks. No, I have no special arrangements with the supplier to allow for returning the equipment but I'm a dab hand at eBay, learnt from disposing of outdated photography equipment during a career as a cinematographer.
Backing boards for shower wet room.
Hastings replied to Russell griffiths's topic in General Self Build & DIY Discussion
Me too. The green gypsum board throughout, then tanked just the shower area up to head height, skimmed and painted the rest. Walls are all timber-frame, therefore tanking is essential I would have thought, at the very least around all corners.
