Mr Punter
Yes 32mm treads. No MDF. They are well made.
Light refurb/renovation & building regs
Mr Punter replied to Roger440's topic in Building Regulations
RICS don't share your view. https://www.rics.org/news-insights/building-safety-act-faqs -
These were communal stairs for flats, so 250mm going per tread and lower pitch. We also used chunkier materials to hopefully mitigate noise.
The Building Safety Act focuses on building structural safety and fire safety only, Nothing to do with your u values. It is aimed to prevent future Grenfell tragedies, so high rise buildings and fire safety. It will not apply to any of the works discussed on this forum. -
If you add your stair to the basket in stairbox it will show the weight. I had 2 flights, 1 was 150kg, the other was 200kg. They were commercial spec.
dirty water marks on new rendering
Mr Punter replied to Daniel3103's topic in Plastering & Rendering
I am very impressed that you managed to cut a new drip groove. -
Warm roof is best but the Velux windows are too close to the deck. Could you lose any ceiling height?
It may be different in Scotland but we in England we only do sound testing for compartment walls and floors - between flats and dwellings.
Extremely Distorted / Warped Double Glazing
Mr Punter replied to CGoodge's topic in Windows & Glazing
Of course they claim it is normal because they are unwilling to accept responsibility and they would rather lie. It looks wrong to me. Where did they source the glass? Find out who manufactured it. Get it replaced.- 16 replies
- glazing
- double glazing
- (and 6 more)
As long as they are separate there is no issue. Moisture will not jump from one to the other.
7.3N Aircrete blocks will be fine. Don't shotfire the soleplate into them.
Can you allow for 225mm above the slab to get to your new level? That would give 150mm insulation, 55mm flow screed and 20mm floor finish.
They don't need to be the same level. Also you can have more than 1 DPC if needed.
Yes. They use a different form. https://www.gov.uk/government/publications/registered-titles-part-transfer-tp1
Are you thinking to drop the render down by 300mm as well? Draw it on the elevations and see what you prefer.
You will need your mortgage provider to agree your scheme. You can then go on to build the new house, sell your existing house as a new title, retaining the land on which the new house is built.
Water borehole instead of mains?
Mr Punter replied to flanagaj's topic in General Self Build & DIY Discussion
The cost of keeping the borehole / pumps / sterilizing will outweigh any water bill. -
Underfloor heating pipes within concrete slab
Mr Punter replied to Smallholdertoo's topic in Foundations
I have seen a few situations where UFH pipes float in concrete and can be damaged by power floating / polishing, so be a bit wary. The slab will take a long time to heat and cool as I am sure you are aware. -
Demolition exterior spiral staircase, permission needed?
Mr Punter replied to Zab's topic in Planning Permission
You will need something to prevent a fall from the doors. Often BC are not keen on alterations that are less fire safe.- 6 replies
- demolition
- building control
how to adjust a window that has slipped off 90degrees in its frame
Mr Punter replied to AndyG's topic in Windows & Glazing
I think you need to heel and toe. Take out the glazing beads and redo. Lots of links on youtube. -
You could guess £3,000 per metre for a rough budget, so £345,000. You will need GA drawings and spec to get proper costings.
