Mr Punter
    27
  1. MVHR will make no difference to overheating. The windows open give purge ventilation. MVHR does not. In bedrooms and living rooms it will normally just feed air in, not extract it.
  2. With a pitched roof, most people either have a cold roof with insulation between and under rafters or a cold roof with insulation at ceiling level. It is unusual to have a warm pitched roof, with all the insulation above the rafters.
  3. 4m maximum spans are fairly standard with beam and block or timber joist. Any longer and the beams or joists get heavy and the floor can be more bouncy. With a crane, 3 people would be able to do the floor beams and blocks in a day. If you are hiring a crane, get as much heavy material loaded out as possible to make full use on the day.
  4. If most SIP manufacturers think your roof is not suitable it probably isn't. Trusses or cut roof and maybe some steel are what is widely used. Who is doing the structural design? They should be able to help.
  5. I like the island with no sink or hob. Great for serving up / parties and perfect for breakfast. Hobs or sinks on islands, especially with seating, are a bad idea. Unsightly and potentially dangerous. I rarely transfer stuff from the oven to the hob or vice versa so the distance would not bother me. If the tall unit next to the oven is a fridge freezer I think it looks small. I am putting a similar integrated fridge freezer in a 2 bed flat. Your place looks bigger and you may like more fridge space. I don't think the bench seating will work. OK if it is a banquette or booth to seat max 6 but this is much too big to sensibly use. Using them for storage will be a PITA and they don't look comfy for a leisurely meal. I don't like an oven next to a fridge. One heating the other cooling. I love the windows but be wary of echo / reverberation which can be quite grating. If you have space elsewhere in the house for the TV it may be better. We don't have one in the kitchen / dining and it means we tend to interact more.
  6. I am a big fan of dehumidifiers. I would suggest getting a couple of Meaco units, piping them to the outside with a bit of garden hose and leaving them on constant. They running costs for the pair should be about 6p per hour. You can dry your washing indoors without any issues.
  7. It looks like they built it overhand as they did not have access. When the fence is down they could point it up or render it if you allow them access.
  8. The kitchen layout is not good. Maybe get a design done. The new cavity walls wrap around a fair bit of the existing which reduces the EWI a bit. You need to make sure the left hand gutter and roof does not overhang the boundary. That is a hell of a lot of work and a pain if you are living there. Have you priced it? If it works for you, get it done ASAP or the kids will have grown up before it is complete.
  9. At least it is only a straight flight. I think these are best made in a factory or very well equipped joinery workshop, but if you feel you have the skills and kit I am sure it would be very satisfying. Post up pics if it looks decent.
  10. If you post some floor plans you could get some useful feedback on the layout. For the floor, make sure you have minimum 150mm PIR or 250mm EPS if you have the room. Allow 50-75mm for screed and 20mm for floor finish. EWI can look a bit odd on a semi unless the junctions are well considered. Ground source heat pumps are increasingly far more expensive and less popular than air source. I think you would regret it. You could do the solar panels and add batteries later if you have made provision for them.
  11. I would be cautious about using too much timber cladding as insurers, mortgage companies and future purchasers may not be keen. It can also end up looking like a shed and is potentially more likely to be a fire risk.
  12. I like the main dining area in the kitchen but I imagine this was not practical / desired? You may find the units at the back of the island difficult to access and the worktop overhang insufficient. Don't go for drainer grooves as I have found they just get grubby.
  13. It is good that they did not remove PD rights for further extension and enlargements etc.
  14. Maybe try the Johnstones? I would only use the Zinsser for problem stains.
  15. Our painter likes Johnstones Trade Covaplus Vinyl Matt. Does a mist coat with 2 parts paint 1 part water. If the paint is peeling off in sheets it is not bonding to the plaster. Maybe you need to sand the surface before you paint.
  16. Fantastic news. Well done!
  17. If it is perforated pipe you can lay it in flat. Put the weepholes about 50mm above the paving level every 2 or 3 blocks. You could core drill and waste pipe instead of weeps.
  18. +1 I like to have at least 3 courses of blue engineering with the top being the highest external DPC, matching the internal FFL, then render above. For your cladding you could look at natural slate. You can start / finish render wherever you like above DPC.
  19. Will you have another manifold for the cold water? Bear in mind that lots of washing machines and dishwashers are cold fill only, so don't restrict future options by not piping cold as well. You could use an electric instant hot water for the distant sink for hand wash, but I wouldn't bother. Another thing to go wrong. How much does the Power Pipe cost and how much will it save per year?
  20. A couple of coats of emulsion paint on the ceiling will make it sufficiently vapour resistant that it will not cause an issue. Make sure the loft hatch fits well and there are not loads of holes for downlighters.
  21. If it is only 1 room it will be easier to start again. Very odd though. We have in the past had a flood via broken plumbing fitting and the ground floor was like the rainforest the next morning, with water pouring throughout the ground floor ceiling. The ceiling stayed intact and we managed to dry it out with dehumidifiers and heat.
  22. They may be able to build up to the boundary but cannot place foundations on your land. Why not ask them if they would agree to a shared party wall and get abutments / gutters / overhangs designed from the outset?
  23. I suspect @Pocster has a selection of these kept in his 'special' cupboard.
  24. I don't think it is worth stripping the pebbledash if it is sound. You could remove any bellcast bead and strip of pebbledash that will throw the EWI out and make it up locally with some thin insulation. EWI is quite effective, especially if you improve airtightness and ventilation.
