jack
    41
Everything posted by jack
  1. The Passivhaus standard sets, among other things, a maximum annual energy budget for heating off 15 kWh/m2. On that basis, it's reasonable to expect that heating will be required. The standard says nothing about how the heating is supplied. If your son rarely turns the heating on, what sort of temperature does the house usually sit at during winter? Passivhaus works particularly well in places where there's a lot of winter sun, which doesn't generally describe the UK! As a point of comparison, our house temperature stabilised at about 14 degrees when we went away for a month over Christmas a few years ago. That was no people, no appliances, no cooking, and no showers for a month. In comparison, some of my friends live in Victorian houses, and during cold weather struggle to get parts of their homes to 16 degrees even with the heating running flat out for hours. I know which I'd rather! Have you read that for houses that meet the Passivhaus standard? One other point: when you say you're building a Passivhaus, do you mean a house that's been designed and modeled to meet all the requirements of a Passivhaus? Or are you building using Passivhaus principles such as using lots of insulation and good airtightness? It does make a difference. I don't think our house would meet the standard due to the size and location of our windows, for example. If it's been modelled, you should know how much energy it will use for heating in a year, and you can then easily work out how much it will cost to run an ASHP to supply that heat.
  2. Our BCO actually accepted the original design document. I did the measurements just to satisfy myself that the as-installed settings were about right.
  3. Aesthetic, agreed. If you don't have an out-of-sight place for one, they are generally pretty ugly. We're lucky that we were able to site ours on the far side of our attached garage, where it's out of sight unless you walk along that route (and there's generally little reason to do so). I'm less sure about comfort. There are lots of reports about how noisy GSHP pumps are, to the point where it's sometimes recommended they be sited in their own sound-insulated housing outside the main building envelope. I can't hear my ASHP when it's running unless it's a very still day and I stand pretty close to the unit. I'm not saying there are no use cases for GSHP, just that the economics rarely make sense if you can choose between one or the other (as appears to be the case with OP, since he mentioned both).
  4. Definitely worth checking with your BCO before relying on this unit, although I haven't heard of any of the nearly 30 people who've used our uncalibrated unit having had an issue with building control.
  5. ... and find a way to make 100% sure that the insulation is installed properly. Pointless having a load of insulation in a wide cavity if there are gaps everywhere allowing for thermal bypass.
  6. (PS: I'm going to stop replying on this topic, as we've hijacked the OP's thread)
  7. £30k was the total system cost, which was a guess on my part (added a bit to my vague memory of £20-25k for a typical slinky-type system). Quick search found: https://www.greenmatch.co.uk/ground-source-heat-pump/borehole: Or https://www.imsheatpumps.co.uk/blog/ground-source-heat-pump-borehole-cost/: Given your property has relatively low heating requirements, it'll be at the low end of that range, so probably around £25k. You need to add to your numbers above the periodic replacement of the heat pump itself - maybe £10k every 10-20 years? Not sure. TBF, you probably need to replace an ASHP at least as often, but they are a lot cheaper. Plus a few hundred quid every few years to replace the fluid.
  8. Yes, that's the one. I've heard horror stories about badly implemented slinky systems. I'm sure there was someone on BuildHub a couple/few years ago who had problems with the ground over their system freezing towards the end of winter. My main point is that there are only very limited situations in which a GSHP will make sense over an ASHP.
  9. What's the payback time on a £30k+ borehole system for you?
  10. That's true. Still, in a town centre, you'd probably need to use vertical boreholes, which add significantly to the cost.
  11. Interesting looking build, hopefully you can share more details in due course. I think we've probably reached the point where GSHP is simply not a cost-effective option compared to ASHP. There might be the odd special case where you have a large field next door that you were going to massively dig up anyway, in which case GSHP might approach price competitiveness. But in general, GSHP setups are at least double to price of an ASHP of the same output. If properly done (and that isn't always the case), the GSHP will have slightly higher efficiency, but not enough to ever pay back the price difference.
  12. Awesome news. Despite not having a programming background, I found the programming side very satisfying.
  13. I think we ought to be encouraging larger tanks. They store the same amount of energy at a lower temperature (suits ASHPs) in the colder months, and allow greater usage of diverted PV power when the sun is shining.
  14. Welcome @Allyzap The forum search is a good start, or you can Google "subsidence site:buildhub.org.uk" for slightly better results. If you want to post something, the "Foundations" sub-forum is probably a good place to start: https://forum.buildhub.org.uk/forum/73-foundations
  15. Very useful, thanks for reporting back @Ultima357
  16. Man, I feel for you. We had an UFH pipe nicked (honest mistake) in a much more accessible place and even that caused a lot angst.
  17. Worse, a wooden floor is going over the top.
  18. My recollection is that the consultation date is the latest date by which you can submit comments and guarantee that they will be heard, but there's nothing to stop comments being considered after that date. I think you or a trusted friend being there to take notes would be highly desirable.
  19. I've heard from more than one source that testing them (or having them open due to an over-pressure/temperature event) is the quickest way to cause them to fail.
  20. I've had this problem repeatedly over the last 8 years. First time I noticed it, it was exactly as Dave said (expansion vessel bladder failed). Replaced the expansion vessel, but it still leaked when the immersion diverter was on for any length of time (albeit not as badly). Had a G3 service, and one of the temp/pressure safety valves was found to be leaking. That was replaced, but I still have the issue, and I notice it's gotten worse again recently. No help to you of course, but in answer to your question, yes, they can fail!
  21. Thanks for the photos. Is your stone base MOT1 or similar? I've more commonly seen large no-fines stone specced - something like railway ballast.
  22. Fair enough. I rarely change titles, but someone searching for information about inverters ought to be able to find this thread!
  23. I'd at least run the cabling for three phase. It's orders of magnitude more work to go back and add it later.
  24. Welcome!
  25. It might depend on what "making people abundantly aware" involved, but I think it could well be their fault: That said, if I learned anything during our build, it's that virtually no-one ever listened to anything we said. In my experience, unless you were stood there looking over their shoulders, most trades just did things however they fancied, irrespective of what was agreed beforehand.
