jack
    41
Everything posted by jack
  1. That sort of thing should be fine. If I were starting again I'd use a lot more non-Loxone components, especially DMX relays. They're very cheap per channel and DMX is reliable when set up properly, especially where you're just using it for switching.
  2. We've switched a few lights like this for 8 years, no problem.
  3. One extract will move very little air and make little difference to temperatures locally, let alone to the whole house. If you don't want air conditioning, think it's better to have insect screens and open the upstairs windows as soon as the temperature outside is below the upstairs temperature.
  4. My only question would be whether you plan to terminate all twisted pairs from all ethernet cables at the 24 V terminations section. If so, how many cables are you planning to route there, and what's route are they taking? It can get very busy, very quickly when you have a lot of cables (ask me about the rat's nest that is my Loxone cabinet!), especially when you're trying to retain separation between mains and low voltages. If I were doing mine again, I'd put my ethernet terminations on the top or bottom rail so the ethernet cables don't need to travel far once they enter the cabinet. Since 90% of the time only 1, or at most 2, twisted pairs of each cable are actually used for anything, terminating as close to the cable entry point as possible will signficantly reduce the volume of cable running within the cabinet. Sorry if your plan takes all of this into account, but thought it worth mentioning given how unpleasant my cabinet is to work on given the choices I made at installaion.
  5. 300 mm is usually made up of 3 x 100 mm layers. We have similar, and I ran some cheap drainage conduit through two channels I cut into the middle layer of insulation when the guys were onsite doing the foundations. I was able to bend a reasonable radius up into the plant room. No issue pulling the flow and return pipes through later. More detail here (worth reading both threads in their entirety, but particularly the first one):
  6. jack
    Coral TPU
    Someone mentioned this on here ages ago. I looked into it at the time and you couldn't get them anywhere.
  7. If you like your bedroom that cool, I don't see any way around having active cooling of some sort. Personally, I'd just plan for a small air conditioner for use in summer. Solar shading (ideally external) makes a massive difference to the energy that will be required to keep things cool. Also, if you like the windows open, consider planning for retractable insect screens at the design stage. We can't have windows open overnight at ours because of insects, and retrofittng screens is going to be quite difficult. If you have a central area where you can put an opening roof window, you can get some good stack ventilation going too. We'd planned for that, but the insects have made it difficult. Our solution to the heat is a small pedestal fan. Works fine (basically just directed at me, as my wife doesn't mind sleeping in a warm room).
  8. Not often. I had issues with cheap DMX dimmers for a while so I did need to switch it all off to make changes. I wouldn't bother just for the convenience of having fewer switches to isolate, but I do like the idea of less wiring coming into the Loxone cabinet. As with so many things, there's a lot I'd change if I were doing it all again!
  9. I have to flip several RCBOs in our CU to isolate the Loxone panel. It's been over 8 years since we did our installation, but I vaguely recall having a conversation about this with the electrician, and seem to recall that he was uncomfortable with moving a lot of what would usually be in a CU into the Loxone cabinet. I don't remember whether it was regs or a lack of panel space that led us to the decision in the end!
  10. We're trying, honest! 😄
  11. How thick is your screed (or slab, if the UFH pipes are in that)? Ours are in the slab underneath about 70 mm of polished concrete overlay, and it takes 3 hours for a change of 0.1 °C to be apparent at the floor surface. The floor surface takes about 12 hours to increase by 0.3-0.4 °C once it starts rising. Here's the slab temperature under the kitchen island over the last few days, with the ASHP running 12 hours a day. Lowest temp was 19.8 °C, highest was 20.2 °C: Admittedly this is an extreme case given we run our flows temps quite low (25-28 °C depending on outside temps), but UFH does react very differently to radiators.
  12. It took me too many years to realise this. A 25 pack of DeWalt bits for a tenner last years, and I'm far less reticent to chuck one out when it starts to show wear.
  13. You've been on the forum for a bit so it's fine to share suppliers you've used. That's particularly true given someone else asked for the info!
  14. Not sure if you've considered it already, but what bit are they designed for? Could be an issue if they're a pozi bit and you're using Philips (or vice versa).
  15. Didn't work for us. The most highly recommended guy - recommended by several friends - we had was average at best relative to the others we had onsite. Example: the guy he had in doing the plasterboards noticed that a piece of steel protection we had in place to protect a 240V blinds cable at the top of the window in my study was in the way, so he just unscrewed it and threw it in the middle of the floor. The only good thing is that he was that lazy, as otherwise we'd never have known.
  16. Our window installers were the Irish distributors for the German company that made the windows. They didn't follow the manufacturer's installation drawings - which we gave them - and missed that the frames needed to be packed up by 15 mm. This led to the cills not fitting. I chamfered off an edge of the frame at each window so the cills would fit, then they realised that the blinds (again, supplied by the manufacturer for which they were a distributor) couldn't be attached through the vertical battens in the reveals that I'd confirmed with them were not going to be in the way. I also later learned that they should have lined the aperture with a DPM, but that didn't happen. And on roofing, I complained to the manufacturer about the poor adhesion of the membrane around the outlets through our parapet walls. They confirmed that all was fine and that the installation was to the "usual high standards we expect of our approved installers". Every one of those outlets leaked badly within a month of us moving in, all due to... poor adhesion of the membrane around the outlets. I should stay away from this thread, it's bringing back too many nasty memories! 😁
  17. Not always, in my experience. There were times when we went for what we thought was a higher quality outfit based on the price and professionalism of our interactions with them, but I don't think they did any better on average than the cheaper ones.
  18. I can't tell you how many times I've had this conversation in the last few years. We just don't respect tradespeople enough in this country. It's (wrongly imo) seen as something that kids who weren't any good at school end up doing because they aren't good for anything else. Absolute bollocks.
  19. Thanks. I did look into the modbus module when buying the ASHP, but it was several hundred quid + the prospect of me having the figure out how it all interfaced with Loxone. Seemed like too much effort at the time - I may revisit at some stage, but I already have too many projects on the go! Unfortunately (well, unfortunately for this approach), the time constant on our slab is too long for this to work. At the current flow temp settings in mild winter weather, it I turn the heating on, it takes just under three hours to show any change in temperature (+0.1 degrees). The temperature will continue to slowly rise for another three or more hours after the heating is turned off. I think the solution is just to bump of the flow temp across the weather compensation curve and experiment with how the house reacts. Thanks. If I understand you correctly, that's what I was proposing above when I said: There'll be some experimentation involved, but it's an interesting project, plus I can start working on it now even before I'm back on the cheap overnight rate.
  20. My wife was far more important to our build than I was. She ran the entire site. Most of the guys we had onsite were pretty good, but a few struggled with taking instructions from a woman.
  21. I run our downstairs underfloor cooling at 15 degrees flow temp, only during the day when the sun is out and the pv is generating power. This keeps the floor at about 19 degrees, which makes for a very comfortable room temperature, even in a run of high 20s days as we occasionally experience. Admittedly we have concrete floors, which do tend to be good at sucking the heat out of the room (and your feet - heavenly when it's really hot outside). I have no idea how well it would work in the sorts of temperatures you're talking about. I suspect air conditioning would be more effective, especially upstairs where it tends to get a lot warmer.
  22. Man, that's horrendous. Not quite as bad, but we had rockwool for sound insulation just thrown up between the joists prior to plasterboarding the ceilings, rather than pushed into place to close all the gaps.
  23. Correct. Loxone calls for heat, and there's some (programmed) flexibility about how that happens, but flow temperature (including weather compensation) is set by the ASHP controller. Ideally I'd have Loxone control the flow temperature too, based on various current and predicted temperatures and the availabilty of cheap power (overnight) or free power (occasional excess PV during winter), but that isn't possible with my current setup. Depending on the rate at which my slab can absorb energy, the solution may be to just increase the flow temperature across the weather compensation curve. That might be enough to get me over the line. The problem I have is modelling all of this. I may just need to try it out when it gets colder. I've thought about using this in the past, mainly for when there's excess PV but the house is already up to temperature. The main issue is the very long time constant of my slab. I'm sure there's a way to program in some guardrails to make it work though.
  24. I'm not against this approach. For a while I did have things set up to use the immersion to boost DHW for the last hour when we were on Go. Unfortunately, my Octopus Go contract ended a few months ago and I'm not able to sign up to the other cheap overnight tariff until I get a compatible car or charger (I didn't want to tie myself into the latest Go tariff, as the numbers are nowhere near as good as the other cheap overnight tariff). I'm due to replace my car soon and will be installing a charger at the same time, so I'll be able to get onto the new tariff. I'll need to do the sums to see what works out best once that happens. I was hoping that four hours at a decent temperature would cover most if not all of our heating needs, but if it doesn't, adding in the immersion to help the DHW heating may be the way forward.
