nod
    72
Everything posted by nod
  1. Yes it would our parents home is 25 years old we had the loft insulation and the cavity topped up Free of charge
  2. nod
    Nolte kitchen
    She like what she likes I’ve built the run of base units out to take a 750 worktop also
  3. nod
    Nolte kitchen
    Two Neff double ovens It’s the height that my wife prefers Shes only 5’6 I’m 6’4 so nothing looks high to me ?
  4. We took delivery on Friday I didn’t have time to stay and unpack We went back later that evening and spent three hours unpacking First unit Door damaged Second shelf and internal side damage Forth A tall freezer housing They hadn’t put the internal ally bars in for transport Badly bent Verdict Noltes quality control is poor All could have been avoided The carcasses are pretty much the same as anywhere else The doors and hinges are excellent A lot more work fitting especially the finger rails Lets see if they manage to redeem them selfs by shipping the damaged units out quickly Myself and a friend have two days fitting to get it to the stage we’re we can get the quartz guys in
  5. I’m installing a lux air as we speak All singing all dancing Remote controlled Sounds like a jet engine when tuned upto four £800
  6. If you turn up and by everyone’s lunch That would be appreciated Quite unual to get a thank you Not all builder smoke or drink Real nice that you are thinking of them
  7. I’m guessing it’s aluminium If so there will be little or no adjustment So the frame has to be a 100% square and plumb Any adjustment is normally done with the glass (toe&heel) If the frame wasn’t perfect when fitted In afraid the only option that will solve your problems Is to take the doors out and refit
  8. nod
    Kitchen
    Cheers Ian it will create a big void once we finish Unless we start again ?
  9. nod
    Kitchen
    Yes a Nolte kitchen Ive built the oven and fridge housings and exstractor hood So if my measurements are correct all should go in ok ive rescheduled the eye surgery twice Although it’s private I think I will be pushing my luck cancelling again The big difference here between going to Howdens or even the sheds Is if there is anything missing I will be stuffed Fingers crossed for German efficiency
  10. nod
    Kitchen
    Thanks I had a lens replacement a couple of years back Just a bit of scarring to be removed from one eye
  11. nod
    Kitchen
    Well it’s 530am Just had a text saying our German kitchen will be with us within the hour I’m just keeping my fingers crossed that everything is there I should have enough time to get it loaded in before I go to my day job Im hoping to fit it over the weekend and get the quartz worktops guys down to template on Monday About two weeks to get those made up We are cutting things fine with our buyers looking to move into our current home as soon as Stairs promised for two weeks Ive an eye operation booked for the same day Fingers crossed I can fit the stairs the following day Hoping to get a free day next Friday and have a look around the homes exhibition If anyone is going I’ll be the tired looking one being dragged around all the home furnishing stalls Seriously it would be good to see anyone that is going on the Friday
  12. This one reminds of the pictures that the Americans put out Showing their missile strikes
  13. nod
    Wall thickness
    No We prefer to use the formed kind that are joined together They look better and are much neater
  14. nod
    Wall thickness
    Render and board is fine If well insulated But you need to allow for exspansion joints above and below windows and every six mtrs on unbroken areas
  15. I think it was a case of trying to be different Some of these builds look too commercial This one was surely an acquired taste
  16. There are some exspensive ones But in my exsperience they are all prone to blocking I’m using one that cost eight quid and it does the job Trick is Tirb the gun off when not in use and leave the can attached I never clean the gun Just salespeople the can when empty
  17. I personally wouldn’t put insulation on the garage floor If you are likely to have your car in there You should find that your B&B design will have deeper beams in the garage area for this reason
  18. nod
    Wardrobes
    Yes part of our vat claim
  19. nod
    Wardrobes
    Yeah kit comes with two splayeyed bits that fit Ito the track
  20. nod
    Wardrobes
    Just looking at the photo I added door timbers should things not work out and I ended putting a frame in ?
  21. nod
    Wardrobes
    Ive done it like that in the past Dave It was my wife’s idea to not have a frame or Arks It should be pretty durable as there is little or no weight on the frame It’s all on the wheels I even put an upstanding of ply at the back of the head in case we decided to hand from the back
  22. nod
    Wardrobes
    Yes Ian Personal preference I use it everyday I’ve only a few studs upstairs Mainly making bathrooms up and wardrobes Ive lines all with ply and soundblock and doubled the walls with a 100 mil void between the two unsuits Very solid main advantages millimetre plumb easy to keep square holes Pre cut for services Much better soundproofing than timber Same cost as timber to purchase Five times as fast to install Pictured is a small job I did on a school a couple of months back Build corridor Four classrooms soundblock insulate and skim To be completed in five days Over half term Two days for two of us to build and board with electrician working with us Day and a half for two of us to skim
  23. nod
    Wardrobes
    The doors I bought from Benckmark. We bought 22 on account Was given a price and I made them an offer for a now purchase Worked out about £65 each + and are the very hevy type
  24. nod
    Wardrobes
    I purchased the runners from Slingers of Preston
  25. Just thought I’d share this with you Ive been fitting three sets of wardrobes Very quick and easy way to do and quite inexpensive compared to conventional wardrobe I’ve just a piece of oak trim to add to the top and inset handles
