nod
Everything posted by nod
It doesn’t really matter You will probably have a combination of both dont forget to run your board through green Then push the stud with the arrow up tight and fasten
ICF How much more expensive ?
nod replied to Dave Jones's topic in Insulated Concrete Formwork (ICF)
I think you will be somewhere in between Solid and TF We looked at ICF as an option It was only the material price hikes that stopped us TF costs are now ridiculous -
Plus 1 A bad mistake waiting to happen
I would spend a small amount of money and go through a planning consultant Who will add detail to all of the above points made
New build design - thoughts welcome!
nod replied to AppleDown's topic in New House & Self Build Design
It looks a nice design It won’t be cheap to build Tge roof will be expensive also But if it comes within your budget Go for it -
That’s normal and reasonable
Howdens kitchen - how to negotiate?
nod replied to johnhenstock83's topic in Kitchen Units & Worktops
Howdens are very difficult to deal with All this trade custom only is nonsense The problem is that they use the same sales systems that Ford dealerships used for many years (Pendulum) I’ll ask my boss What figure would you be comfortable with Its normal for them to come back a few weeks later with discounts that Jim has already quoted There products are fine and most bits are stocked Get your quote and wait a few weeks for the second call Don’t forget to mention that Benchmark are also quoting -
Personally I wouldn’t Even the larger companies are relaxing these clauses due to labour and material issues
- 1 reply
Painting on moisture resistant plasterboard - does it need priming first ?
nod replied to greatdayfor's topic in Decorating
It’s not exactly that It’s a hardener also I buy 50 at a time but still works out at £40 each Trade point is DIY -
No primer needed Your taper should be using a gypsum primer once the sanding is done -
Use the Supplied packers Make sure you toe and heel the side hinged windows You may need to get the units out at some stage So don’t bond them in
Make a U shape with The DPC Stand some rigid insulation in 50 mil short of the floor Fill with mortar
If you are fixing matting to timber Use Ardex Absolutely Bombproof
Yep It can be a real issue We have to crane our boards in on some of the larger job So they are often there for months before we get near them with plaster Mainly sound block boards We normally use two coats of SBR 3-1 One of the coats the day before if possible
quote Roof replacement and insulation install
nod replied to Matt89's topic in Roofing, Tiling & Slating
It would probably be worth getting more quotes Whatever insulation you put in You will notice a massive difference -
Insulated slab, do I need DPM under internal insulation before screeding?
nod replied to Thorfun's topic in Heat Insulation
I don’t make the rules If you put any studs on top of the screed BC will still want a strip of dpc under them -
Yes dmp below and a fly sheet on the top -
Yes
