Mike
Everything posted by Mike
Not sure if it's that unpopular at a population level as there was a >15% reduction between 2008 & 2019 in the UK. However the reasons are unlikely to be entirely environmental; the research hints that cost & health concerns may be factors. I'd guess that shrinkflation may be another, since portion size is a key factor behind the reduction.
It looks promising - similar to stuff I've used in the past - but standards change and I'd want my SE to take a look at it. Otherwise try selling it (or part-exchanging it) to a local gravel company who can screen & resell it.
floorplan change to accommodate dorma
Mike replied to DWBungalow's topic in New House & Self Build Design
Remove the wall between garage, which becomes the kitchen (adjacent to the bathroom for ease of services), and bedroom 2, which becomes the dining room. I probable wouldn't do it though. -
Fine tuning my IWI Solid wall (Warm Batten) design
Mike replied to Annker's topic in Heat Insulation
In some situations I've done similar to @lookseehear, in others (particularly for some odd timber-to-timber junctions) I've used FM330 as you proposed, sometimes with anti-rodent mesh embedded in it. -
50mm pipe spacings in problem rooms - any bad effects?
Mike replied to James of the North's topic in Underfloor Heating
Because @James of the North is asking about increasing pipe spacing in specific rooms, not 50mm pipe spacing near the manifold (where a somewhat higher temperature would occur). -
It's not ethical and probably illegal to leave any behind encased in something else that a future builder won't expect to contain asbestos. Bring in a licensed asbestos removal company to remove them and any remaining adhesive, and to decontaminate the space. Also check out the Control of Asbestos Regulations 2012 & the associated guide, which contains this: NNLW = Notifiable Non-Licensed Work
Or replace the car parking with trees and cut the air temperature by around 4°C: BBC: Plant trees to tackle deadly heatwaves, say experts
Try searching for drive-over LED lighting channel?
Not cheap, but the cost will depend on factors such as the roof structure & how much you want to get involved in the work. But if you want to achieve something like it later, then it's worth developing an overall plan now, rather than making things up as you go. -
The temperature will be limited by the water temperature supplied, so it will just reach the maximum temperature of 27 to 29 quicker - it can't go higher than that. No problem; the hot water is still being pushed through the pipes, so the floor will warm up. -
I agree with @JohnMo. You also have problems upstairs. The two bedrooms on the left are small; the upper one due to its dimensions; the lower one because the WC door (and the route between it and the other door) means that, by the time you've added a wardrobe, much of the space will be unusable. The first of these two is also between 2 bathrooms, so deserves some sound-proofing.
Fill your roof with in-roof PV panels instead of pantiles?
Mike replied to Alan Ambrose's topic in Photovoltaics (PV)
It's part of the Microgeneration Installation Standard (my emphasis): 5.8.7 Solar PV modules should not be mounted within 400mm from any edge of a domestic roof unless specific measures are taken to: • Resist the increased wind uplift forces in the edge zone through additional fixings and, where necessary, additional roof timbers for those fixings • Ensure ridge-tiles remain secure • Ensure rainwater run-off patterns are not affected • Ensure build-up and shedding of snow cannot cause injury or property damage • Reduce nuisance from wind noise https://mcscertified.com/wp-content/uploads/2021/10/MIS-3002_Solar-PV-Systems-V4.0.pdf -
Not necessarily not to be liked, but: "When specified correctly the PURe® range can give Uw-Values as low as 0.71 W/m2K for commercial CEN Standard windows" - but are you specifying commercial CEN Standard windows? "PURe® has been tested to relevant UK and European Standards for Shear strength, air permeability, water tightness and wind resistance" - but no mention of thermal testing (nor independent testing), though maybe they forgot to mention it. From https://www.seniorarchitectural.co.uk/architectural-systems/pure-window/ Alu-wood doesn't have to be chunky (and can have lower Uw values - for example https://database.passivehouse.com/en/components/list/window?filter_frame_type=Alu%2CWood%2FAlu&filter_location=GB&sort=u_value)
Flexible conduit is used almost exclusively in Europe, so there's no problem with the concept. However the rule here in France is that they should be no more than 1/3 full by cross-sectional area. In other words, you need a bigger duct or more than one. I'd pull no more than 2 LAN cables though a 25mm duct, for example.
I like the idea, but there was a recent warning over here in France against integrating panels into roofs due to a number of fires., Risk listed included lack of regular checks, faulty electrical connections, and the accumulation of material underneath the panels. The advice was to stick to mounting them on rails so that the tiles act as fire protection. There's a photo of the aftermath of one recent incident here: https://www.revolution-energetique.com/actus/feu-de-panneaux-solaires-le-toit-de-ce-college-est-presque-entierement-detruit/ -
Boiling water tap - Quooker alternatives
Mike replied to canalsiderenovation's topic in General Plumbing
It's recommended that there should be a supply of unsoftened water in the kitchen - either feeding the kitchen tap, or a separate one like @Nickfromwales provides. -
Help! How can we avoid trickle vents on a Jacobean cottage reno?
Mike replied to Amberella's topic in Windows & Glazing
Find a an installer who is a FENSA / CERTASS / Assure member who agrees that you don't need them because your cottage is drafty enough. However, adequate ventilation is necessary to maintain a healthy internal air quality and to avoid condensation & mold; the dMEV fans mentioned by @Iceverge would also be my choice if there is any doubt about that. It's also vital that any solid fuel fires / wood burners have proper dedicated ventilation or you risk carbon monoxide poisoning, or worse. -
I'd choose a flexible woodfibre batt such as SteicoFlex (or hemp batts, but I AFAIK they're not yet widely available in the UK). Apart from being pleasant to work with, they provides roughly double the 'decrement delay' compared to glassfibre or mineral wool (the length of time taken for heat to move through the insulation). That's very helpful in reducing indoor overheating in summer. Of course it also has good green credentials.
Advice as I start budgeting - can I afford to self build?
Mike replied to four_candles's topic in Costing & Estimating
There are a few things mixed up in there: The pore structure of lime mortar and plasters does transport moisture transfer though them better than through sand-cement & gypsum (and lime putty does so better than NHL), so lime plasters are useful in allowing moisture in a wall to escape - which is why it's often recommended in older buildings without DPCs. Gypsum plasters are better than clay and lime at absorbing moisture, but clay is better at short-term (daily) bi-directional moisture buffering, while lime buffers moisture the least. However if the wall material behind the plaster is good at buffering moisture, then lime (due the above mentioned moisture transporting behaviour) and clay can both be useful in moderating daily swings in indoor humidity. And that can increase comfort in circumstances where uncomfortably high or low humidity would otherwise occur. I don't recall seeing any any research on plaster types & VOCs, but since Fullers Earth has some useful properties, it wouldn't surprise me if clay plaster had some too. VOC levels are normally very high for around the first 3 years after construction, partly due to off-gassing from building materials, partly from the new carpets and furnishings that are often used. Reducing them is going to require good well controlled ventilation, as will keeping CO2 levels to acceptable limits in both the short long-term, irrespective of the other factors. -
New extension DPC Tray Flat / Sagging - What to do?
Mike replied to boxrick's topic in Brick & Block
If there's EWI, then indeed it's very unlikely to be a problem. -
If you can find a bung (68mm » 40 reducer +40mm bung?), then you could have a capped-off 'stub' downpipe just long enough to fit a rainwater diverter. The connect that to a black hosepipe and run that along the top of the wall. Or even under the coping stones?
Tipped off a few days ago by @Nick Laslett's mention of the free Opaque software package (decrement delay calculator etc.), I experimented with another free package from the same site: Climate Consultant. Climate Consultant indicates the potential effectiveness of different design strategies that could be adopted at a particular location, based on its typical local climate. Being based in France, I found it interesting to compare different geographic locations, but was thinking that it would be good if it were possible to use it to compare current and future climates in the same location. I spent a day or longer trying to pull together a similar comparison for a client some years ago Today, I came across a website from the University of Bath - COLBE (https://colbe.bath.ac.uk/) - that provides separate future climate files for every 5 km square in the UK (and every 25 km for India), based on current projections. They're provided free and are in the same .epw format that Climate Consultant uses, so it's now easy to use it to compare climate design suggestions for a regular year or a heatwave year during 1961-1990, 2010-2039, and 2070-2099. All suggestions are generic, not tailored to a particular building, but it's worth a look if you are into your building / climate science. The cut in the need for winter heating and the increased desirability of shading windows both stand out and, of course, the climate projections are scary.
- 1 reply
- 4
Or non-harmlessly though to the inner leaf. One or the other.
