Everything posted by Super_Paulie
I wonder how the zones work around a beam like this... Might have to do some research on that one as I guess anything within 150mm from the ceiling and the wall is technically a zone. But where does that leave under the beam as it just ends rather than continue down.
Suspended Timber Floor insulation - critique my plans please.
Super_Paulie replied to SoliD's topic in Heat Insulation
i have my lower PIR attached by using clout nails into the battens and then pushing the 50mm into those nails so its held in that way, then foamed and taped. Then the 120mm over the top, staggering the joins and again foamed and taped. Yeah, the more insulation the better as far as im concerned, i have mine over the entire ground floor no matter if it has UFH over it or not, such as under the kitchen and island units. -
as long as the EPS70 doesnt enclose in the bottom of the joists it'll be ok. The bottoms need to be left exposed to the air under there. See attached for what i have done in my own in terms of insulation, the lower 50mm is held on nails and the whole lot foamed and taped in. So long as your UFH system and design is sound, i dont see any real issues. JohnMo and Nick on here will be along soon im imagine, i got most of my top quality info from them in terms of buffer tanks etc. -
The problem with all of the ideas is that my wiring will be out of zone to get within the flange of the beam. I'd have to go down (or up) and then sideways towards the web. Going out of zone is surely a no-no but I can't see a way around it.
so far there is zero wiring, so everything is still on the table. The idea of the socket was to plug in whatever, LED strip, fairly lights, i dont know, and have it controlled via a smart socket rather than having a physical switch. We have a lot of smart control in the house and this was just an addition i said id look into. Its just to be used on rare occasions/events/ id image (not at all). But yeah, looking at it a socket up there would be troublesome if the smart ever packs in. So a light switch below, that would create a zone as well, and an exit above with a transformer sat on the beam. I guess that would make the device (whatever it is) not really transferable to some other latest gimmick she likes.
the missus has decided that having the option to plug in LED lighting along our exposed steel beam would be a nice idea. However im a bit stumped on how to achieve this as to get a socket within the flange of the beam seems impossible to do and keep the socket in a wiring zone, see attached. The only way seems to be having another socket horizontal to this one further along the wall but that doesnt sound great. I can come down from above but i wouldnt be able to get past the top flange of the beam. The dotted lines are the concealed steel post and the other end the beam rests of a brick/concrete pad stone, the wall to be clad with brick slips. Does anyone have any bright ideas on how i can achieve this, as im a bit stumped.
Sonoff smart relay - no neutral?
Super_Paulie replied to Super_Paulie's topic in Networks, AV, Security & Automation
how do you connect them? L-in live, L-out switched live. S1 to the live side of the switch and S2 the returned switched live? All my new switches have a neutral as i made it that way but my old part of the house doesnt, so these might be interesting. -
i hang my buffer tank on the wall with resin and threaded rod, it aint going anywhere. Could probably inject the resin into the hole and then drill and plug it again if thats the route you fancy.
Built-in fridge with ice dispenser
Super_Paulie replied to puntloos's topic in Kitchen & Household Appliances
going through something similar, but different. My builder didnt leave a big enough return next to the bifolds so i need to get the slimmest possible due to the above that the doors need roughly 8cm protrusion to actually open. I found a Haier that was 66cm deep and a Beko that was 70.5cm but its frustrating that i cant just pick and choose which was going to be be initial intention. Even so id have to bang it up almost flush to the wall behind so id likely have to carve a recess out of the blockwork at the bottom and not plasterboard the whole area behind the fridge. Still probably blow up but got no real other option. -
Do you regret your ufh setup John? I'm yet to commission mine but it's happening imminently and I'm dubious myself. Too late now, but if I could go back I'd just fill the gaff with quad rads and be done with it.
id whack 100mm of PIR flush to the flooring and be done with it. If you can sacrifice any height from the room then you could overboard it with PIR as well but i probably wouldnt bother. 100mm should be a decent improvement if you can get it all air tight.
Pretty sure the bottom of the joists need to be exposed to air flow, that's probably why you can't find any examples of it online. I was in the same boat in my original part of the house, could only get 100mm of pir into it. Not a lot I could do about it without major surgery.
Heat loss via external drain cock?
Super_Paulie replied to Super_Paulie's topic in Central Heating (Radiators)
That was my initial idea but the wife had other plans with some fancy valves, copper left on show etc... Not planning on doing it a lot, it's just while the gaff is a building site now would be the time. I'm still in 2 minds about it... -
Nah that won't matter really, it's just to get rid of the majority at radiator level. Im just unsure as to having the cock outside is essentially losing a shed load of heat at all times. I could probably have it on an isolator but that would haveto be under floor level, so mightily inconvenient. -
It just seemed an easier way to get rid of a ton of old heating water as the cock would be directly over a gully. -
Morning everyone, nice and warm today. I'm looking to fit an external drain cock to completely drain the central heating when the need arises. So the lowest point is obviously under the floor and I was going to just tee into the closest rad flow and bring the pipe straight out the wall with the cock on the end, a run of maybe 40cm, pretty simple stuff. But my question is, am I just going to be haemorrhaging heat outside via the drain cock? As it's all under the floor level I can't really get an isolator that I can access on there. Water won't be flowing through the leg but the heat will transfer through the water/pipe. Or am I worrying about nothing here as it will be miniscule? Cheers guys.
i went under the foundations and brought it up inside into the floor void in some 110mm pipe. Used a slow bend 110mm for the bend upwards. Once into the void i used a 90 elbow to bring it back level again. I concreted the slow bend in and used fibreglass insulation and expanding foam on the entry and exit points.
It's interesting for sure, I might come across using one for retro fit where I don't have a neutral at the switch. Strange though how the switch will technically always be live. -
Think I'll stick to the logical version rather than the version that uses black magic! -
Anyone have any experience with the Sonoff smart relays? I've got one to test and it requires the neutral and it works great. But I've just seen you can get some that DON'T need a neutral. How does that work then? The information is pretty sketchy but my brain can't work out how it runs with no neutral as it will surely be unpowered while the light is off. Any sparkies here have an idea?
i defo hit the wall a month ago. Finally got my radiator system in and working after 6 months and at that point my urgency to carry on just nose-dived as the house was able to be warmed. Difficult on the dark cold nights to come in from work and start to crawl around the house for sure.
Standard of workmanship
Super_Paulie replied to Kelvin's topic in General Self Build & DIY Discussion
is it normal to have to remove about 3000 fag butts from under the joists and all your plant pots once they are done? asking for a friend. -
ive got a list as long as my arm (and leg) of the things the builder did that were p!55 poor, you get what you pay for. The only saving grace is that the external brick work is really nice so that was a bonus that cushioned the blow somewhat. Just daft things like they didnt tool off the silicone on the doors for example, and the setting out of rafters and joists is erratic as is their overly zealous use of a nail gun. Thats passable at best but i have found they used bits of knackered old fence i had behind the shed as parts of the roof in the porch. I mean thats just mental, the fence i took down as it was borderline falling down and it was only fit for burning, i had it stashed for fuel for the chimenea, not for a brand new porch. Too much hassle to pull them on it after they had left, i just wouldnt use them again or recommend them to anyone.
