ADLIan
    1
Everything posted by ADLIan
  1. Thermal Mass is actually 'thermal mass parameter' used within SAP. Based on the heat capacity of internal linings (kJ/m2K), area of each element and total floor area. In older versions of SAP it was broadly classified as low, medium or high depending upon construction method but now has to be calculated more precisely.
  2. Heat loss from (cavity) party walls has been in the Regs for many years - all linked to air movement within, into and out of the cavity. Fully filling with mineral wool and sealing the wall edges are deemed to give zero U-value. Description here
  3. I'm not sure exactly what is being shown there. The 'baseline' may be the 'notional' building used as the benchmark to compare your actual proposed dwelling (see Table 1.1 in AD L1). As mentioned before the Planners will look at this very simply (unless they have more detailed requirements which is doubtful). The important numbers are those for your 'proposed' house - a 40% reduction in the DER here is normally sufficient for the Planners. I note the main fuel is electricity do you have lots of solar PV or using a heat pump to get the CO2 emissions down?
  4. Planners make up these rules but haven’t got a clue what they are actually asking for. In the absence of specific guidance from them if the DER is 40% better than TER then box ticked, move on…. Your SAP assessor is just confusing the issue, how you get the 40% uplift matters not to the planners.
  5. Generally a masonry cavity wall (insulated or not) should not be ventilated - nothing to do with reducing condensation risk. A open cavity must be sealed at the top and must not link with any ventilation into the roof space/roof ventilation route - it’s a fire safety issue.
  6. Ursa acoustic roll - heard it’s a great product, better than many similar and nicer to use
  7. Loft insulation will effectively do the same job acoustically but should not be used as it does not have the correct mechanical properties to be used in a vertical application. Additionally Building Regs ask for a minimum density of 10 kg/m3 most loft insulation is probably a bit lower than this. Beware as denser does not equate to better acoustic performance once installed!!
  8. PUR insulation does contain artificial blowing agents that give the product an enhanced thermal performance and yes this does leak out over time reducing the thermal efficiency. Check the thermal performance of foil faced boards against that of tissue faced flat roof boards. Foil faced is always better as it delays the escape of the gas. The test method for the thermal conductivity accounts for this with an artificially accelerated aging process prior to testing so quoted values are acceptable longer term.
  9. The heat loss from a ground floor depends upon its size, shape, edge condition and ground under it. Assuming your floor is a simple rectangle it will have a u-value of approx 0.65 W/m2K without any insulation. Try inputting this value into the heat loss spreadsheet
  10. The report doesn’t cover rendered brick/block wall as it covers worst case scenario of pretty poor quality brick outer. It was also a study to ensure the BBA test rig could still be calibrated and used.
  11. NHBC requirements always trump BBA Certs. That’s just the way it is!
  12. Plastic retaining discs that fit onto the wall tie will do the job. Standard practice.
  13. No it isn't - call the manufacturer for advice. Surprised you're using 37 grade, would normally expect 35 or even 32 under current Regs
  14. The BRE is a commercial body and will want payment for a new set of Accredited Construction Details - I doubt the Govt is minded to fund this sort of work. There is no need to be 'accredited' or 'approved' to undertake psi-values - the requirement is simply to be 'competent' - a discussion to have with your BCO (if he knows what a psi-value is!). Will be interesting to see what the BRE have to say.
  15. Manufacturers offering psi-values will obviously promote their own products. The 2D thermal modeling of the junctions is time consuming and complex - I undertake them for the insulation company I work for as part of our technical and sales package. The problem with some current psi-values is to be acceptable under the current Building Regs and SAP 10 they must be done to the 2nd edition of BR497. Many older values were to the 1st edition and these can only be used for the previous Regs and SAP 2012. Note photo evidence is now required for many aspects of the build so the Regs have tried to close this loophole. I cannot say how successful this is or will be as I'm no longer an accredited SAP assessor. I baled out as I would be spending too much time chasing for these photos and other evidence and then being cast as the bad guy when they're not available (which is a BR failure!) or show a different insulation/thickness, etc, etc and the 'as built' potentially fails.
  16. Following last changes to the Regs many manufacturers have introduced their own psi-values that can be used in the SAP process in place of the old ACDs. Elmhurst keep a register of these companies that assessors may use. Available to Elmhurst assessors - copy attached. Remember under the new Regs photo evidence is required to show the exact detail has been followed on site Elmhurst Thermal Bridging Scheme List v3.xlsx
  17. If we assume a floor with perimeter 50m and area 100m2 with a U-value of 0.15 W/m2K. The rate of heat loss associated with the floor and perimeter would be as follows; Floor only = 100 x 0.15 = 15 W/K Perimeter heat loss(using SAP default psi-value) = 50 x 0.32 = 16 W/K Perimeter heat loss(using dense block psi-value, insulated cavity) = 50 x 0.17 = 8.5 W/K Perimeter heat loss(using enhanced psi-value, with aircrete block inner, insulated cavity) = 50 x 0.08 = 4 W/K The exact geometry of the floor/wall junction may change the psi-values but above are the right order of magnitude.
  18. The detailing of the floor/wall junction does not give a SAP 'fail'. Some details will be better than others but this is only one of many (40+) linear thermal bridges that must be accounted for within SAP.
  19. Get a new build SAP assessor on board asap. A sap calculation should be done at the design stage to show the proposed dwelling complies with the regs. This is updated on completion to reflect the ‘as built’ house and to generate an EPC that is required as part of BC sign off. The Regs now also require a lot of photo evidence of the insulation and its installation. Your sap assessor will advise further. Without this evidence the assessor will use default values with the risk the completed house fails the Regs.
  20. At the edges of a flat roof the VCL should be continued up through the thickness of the insulation to join with the waterproof layer.
  21. Depends upon what’s in their BBA Cert. May be limited to max ‘severe’ exposure zone with masonry inner and outer. 50mm cavity still applies with sip and framed construction.
  22. compliance with a BBA cert is an alternative way of complying with the Regs rather than using Approved Docs. Most built in cavity insulation will be approved for severe or very severe exposure zones but look at the small print for the need for render or have flush/weather struck mortar pointing. Has nothing to do with insulation being breathable or not. Above applies to masonry. Sips, timber frame or metal frame must have 50mm clear cavity between insulation and brick/block outer.
  23. Note SAP is a method of assessing energy use in a house in a standardised way; it should not be used as a design tool for hot water or heating systems.
  24. Insulation of pipe work is in building regs too, for the same reason
  25. Because you are only altering the area weighted average u-value. The correction for fixings is a separate calculation (based on type of fixing, number of fixings and construction/insulation thickness of the element) that is then added to the basic u -value.
