DavidFrancis
Everything posted by DavidFrancis
Our local wildlife trust uses these "tree poppers", but don't know where they get them from. I've used them a fair bit and they work well on saplings
Thanks for the replies @pdf27 and @TerryE I guess I was being thick, but the design of that graphic made it look like the losses came after the energy had already departed the power stations and I was thinking the conversion losses happened when changing voltages or going from AC to DC or vv. One of the accompanying tables to the DUKES report gives fuel-used to electricity-generated figures by fuel type and these give the following efficencies: Coal 33.4% Oil 36.5% Gas 48.5% Nuclear 39.9% Thermal renewables 36.9% Solar & wind are given as 100%
According to the latest DUKES report from the goverment, we lose more than 50% of our electricity generation in "conversion, transmission & distribution losses". I never seem to hear anything about what's been done to reduce those losses. Anyone know? https://assets.publishing.service.gov.uk/government/uploads/system/uploads/attachment_data/file/1094628/DUKES_2022_Chapter_5.pdf&ved=2ahUKEwjLsJ3R17f8AhWSdcAKHdMVCR0QFnoECAoQAQ&usg=AOvVaw1Lf32nQsybhTjyvh6DJ4Nd
Thanks for the answers. Bought a Torbecks and got it to fit (just) after cutting down the spindle for the flushing lever. Thought the valve was broken at first as lifting the float lever doesn't have an immediate effect. Didn't realise it needed to build a vacuum. Just got a leak to fix now.
Not done much plumbing stuff before and have a problem with the fill valve. The previous valve was so old it broke-up as I tried to replace an O-ring. The old valve stem has a lean on it - see picture - and has a metal arm. This enabled it to fit beside the siphon and for the arm to reach over the siphon. I bought a new fill valve but the bottom entry ones all seem to have a plastic arm and this now catches on the siphon and won't operate properly - see picture. This is in part because the back of the cistern now pushes the valve body out, when the "fat" part of the old valve body used to sit in the wider section of the cistern at the side. Has any one else encountered this problem, or do I have an unusually shaped cistern?
Google reckons it could be Himalayan honeysuckle.
Don't remember seeing test pots. Could try ringing Bedec?
I like Bedec MSP. Doesn't need a primer or undercoat. Lasts well. Goes on OK for me. Been using it for the last six or so years. Not repainted anything yet. Also used Sadolin Classic stain on some cladding. That on the shaded side is still good after nine years. On the side with more sun I gave it a recoat last year.
What type of shower can I use in my new install?
DavidFrancis replied to TryC's topic in Bathrooms, Ensuites & Wetrooms
On Valspar paint, see this story https://www.bbc.co.uk/news/business-40655163 -
You say the gutter is currently covered over. To me, this would seem to be the cause?! (Water running down the brick/flint.)
We got quite a few quotes recently for PVC and ali-clad and Russell Timbertech were a competitive price. Shame they only do installation on big jobs - or so they told me.
I was referring to the felt you linked to. As is often the case, I was not sure what Tony was talking about. Now see it is an undertile felt, which is something new to me. By coincidence Iko are based only a couple of miles from here.
I used that Iko felt on a shed a couple of years ago. Thought it was rather flimsy. Used some Icopal Xtra-Gard this year and thought it more robust.
Advice on the process or getting dry rot repaired
DavidFrancis replied to Stephen cooper's topic in Roofing, Tiling & Slating
I nearly had Peter Cox treat one of our bedrooms as the floor joints had woodworm holes, but then I did some reading, and just checked for new frass every couple of years. Not spotted anything yet. Joists are at sub 15%, some sub 10%, moisture, so pretty happy everything is OK. -
I'm not sure if you got my point. Apologies if you did. See here, for example, for the differences between heartwood and sapwood https://www.thesprucecrafts.com/heartwood-or-sapwood-for-your-projects-3536898. Because sapwood generally has a higher moisture content, it is much more susceptible to decay from rot or insects. A large piece of timber is likely to be mostly heartwood and so could still be pretty good from a structural point of view. That Peter Cox article isn't too bad, but you need to be very careful with woodworm "experts". There's been a great deal of mis-selling and over-treatment from people in the wood preservation and damp treatment business. I think these articles provide some useful info: https://buildingconservation.com/articles/woodworm/woodworm.htm and https://buildingconservation.com/articles/envmon/timber_decay.htm -
Could it be the soft sections are actually sapwood (as opposed to heartwood). I have a large lintel where the sapwood has decayed but the heart wood is fine (I hope!) If this is the case you may be OK as long as a decent section of timber is sitting on the wall and the rafter is also supported by a decent section at the top. -
MVHR - list of questions/thoughts
DavidFrancis replied to mjward's topic in Mechanical Ventilation with Heat Recovery (MVHR)
My current gas cost is just under 2.5p/kWh. Electricity is just under 15p. So you'd need a very, very efficient ASHP to improve on unit costs. But then there's a standing charge of about £80/year for gas that could maybe be eliminated. Using an ASHP may produce less CO2, but I don't know enough about the current grid mix and efficiencies to comment. I think the ASHP installation costs could be greatly improved-on with shopping around. Look at @ProDave's blog for example. -
Corten for decorative purposes in the garden
DavidFrancis replied to Savi's topic in Building Materials
Only £100 sq m. Great value! -
Self build offgrid strawbale house in Scotland
DavidFrancis replied to Pord67's topic in Introduce Yourself
Just "wasting" time watching Building the Dream after lunch. It's a straw build and includes the inevitable trip to another house - straw built of course. Season 2, episode 11. Probably available on on All 4.- 59 replies
- straw bale
- offgrid
(and 2 more)
30p/metre at my BM here. Not too bad a trip from s. Manc https://www.cwberry.com/ProductDetail.aspx?p=01020061
On ICF walls, I've read that ants can be a problem with EPS in the States. See here, for example: https://www.greenbuildingadvisor.com/article/if-ants-like-rigid-foam-should-we-stop-using-it No idea if British ants like it, though.?
- 63 replies
- cladding
- open joints
Wasn't it @Pord67 on the straw house thread?
But a brick/block house on conventional footings isn't quite the same as a straw house sitting on piles of tyres where those piles don't seem to be connected one-to-the-other. Might be good in an earthquake, though!- 59 replies
- straw bale
- offgrid
(and 2 more)
Recycled Type 1 crushed Hardcore - Asbestos worries. Help.
DavidFrancis replied to Danieluk37's topic in Building Materials
SWMBO's father also started his working life in a power station. Some pipes were lagged with asbestos. The lads working there used to throw balls of asbestos at each other for a lark. He's still in good health at nearly 87. -
Is there anything to tie the house to the ground? Or are you relying on friction?- 59 replies
- straw bale
- offgrid
(and 2 more)
