Its fair to say youve punched a gut to get there. Congrats mate. Nowt better than winding the amp up and getting the speakers working up a sweat. When SWMBO goes off to the shop the kids leg it downstairs and shout "chuck the beats on dad!" and my Yamaha / KEF gear gets the dust knocked off it. Sweet.
He's taking his Labrador for a walk.
"feeding" aka "steering".
Yup. Grabbing hold of the tile and feeding it into the blade 'manually' is the kiddy. Leaving it down to the fence when its a vibrating tile chewing machine is a bit open to skew, but as I said, the proof is in the pudding. Your test tiles were ceramic yea? Are the floor tiles same or porcelain?
To most people it doesn't wander, but its us were talking about. A bit of wander will show after the test cuts. Either that or your freeby cutter pisses over my £350 Rubi.
Draw a line, eat the bastard nuts and chuck two more down your kegs. You'll need to steer the blade as you cut, as the radial saw still wanders.
The reason one side cuts better than the other is the back of the blade cuts on the upstroke. You'll typically be pulling or pushing so will reflect which side has the upcutting edge against it. Whichever that is gets shelled, not by the initial down cut but by the resulting upcut off the arse end of the blade. Gets on my wick TBH but you soon learn to engineer how you lean on the machine during use to change the rough edge from the 'keeper' to the offcut.
And the boiler is a paperweight. As WB are a bunch of tossers, you need to spend a fortune and ask their permission to convert from LPG to natural gas. With Vaillant you just buy a sticker for £6 and turn the screw on the gas valve. 15 mins work. Unless your willing to wait a long time to sell it, don't buy the boiler. 150L is for a 1 / 2 bed flat .
FYI my mate was £120 for all the cuts in that black and white tiled room that everyone loves so much. Beer money.
Put the cut edges against a full tile to see what it looks like sat next to a dead straight other tile. Tbh the cuts will stay in pairs so no need to be laser straight.
That's called keep ya beak out ! Ask if you can bond them to a PB and lay it out with blobs of silicone. They can lay it on the bed and let them plot it. You'll snap the ends offeirh a scribe and snap most prob as you've got ceramic yea? Porcelain you could scribe and then snap over a dowel, ceramic doesn't do so well. Maybe see if you can buy a 3mm wheel for your cutter ?
And then you have control and maintain the hedge for the rest of your days ?!? ?
Solicitors letter and give a deadline for the fence to be moved back. State if its not done you'll be doing it for him, via contractors, and they'll be paying for it. No messing, 30 days and not a day more. Clearly a piss-taker. Not the tenants fault, the LL is 100% responsible ( or irresponsible as the case appears ).
If he just blankly ignored you and fitted it to your wall, time for an 8-pack and a chainsaw me thinks. Just what my mate did after getting the FO from his neighbour over pretty much the same thing.
Sock bin? Gonna need an MVHR extract in there -
If going combi > UFH manifold without buffer then you really need a bypass between flow and return just before the manifold. Use a 22mm lock shield gate valve so it cant be inadvertently adjusted. Try it first set at 75% open and see if the UFH manifold still gets to the set flow temp. The UFH manifold will still pull all the hot water it needs so dont worry about the bypass being open, just VERY important not to have the boiler pump going 70MPH and the manifold pump going 30MPH and them fighting it out. It should really go to a low loss header or buffer to hydraulically isolate the two pumps from each other. Boiler can blast into the buffer, and the UFH can just trickle through the other side of the buffer and do its own thing. Boiler will then only fire to reheat the buffer instead of constantly running its internal pump and adding a lot more mileage ( and shortening its life cycle ), same with the boiler fan. Should be ; Boiler fires up at 55oC ( no higher eg to promote condensing ) and heats the buffer. Buffer gets to temp and the buffer stat tells boiler to go dead / standby. UFH pulls from the other side of the buffer. Buffer then cools and the buffer stat tells the boiler to fire again. Repeat. Everything gets to temp and the boiler cycles get further apart. When heatings not needed the buffer stays cold. Best solution is to put the buffer in the airing cupboard ( or the hot-press if your a big fan of potatoes ) so the seasonal heat given off goes towards airing the laundry.
For the pointy cuts, go in from the narrow end at least 2", then turn the tile around to complete the cut or the pointy bit will break off with the vibration of the cutter wheel. Remember when you cut a tile, if you plan on a grout line between it and its partner you'll end up with a 303mm tile not a 300mm tile and it all goes tits up. Thats why I had mine water jetted so the cut took out 3mm of material.
I've a way with words.....what can I say.
Mop the concrete with a dilute primer such as FlexiPrime. Do NOT tank until you are 100% ready to tile. Literally the day before. You'll just scuff it and ruin it. Total waste of time and money if your not laying tiles the next day.
2 stand alone items thats all. A box of tricks to make it a quick fit is the attractive bit, pre-plumbed / wired it says so a few quid saved on installer complexity too.
@nod You tiling straight on to the P5?
Hi and welcome. Go to the text you want to quote and highlight it, mouse and drag or click and select. After you select at least one word a drop box will appear saying "quote selection" and you'll get the result above. The above will help deal with the Jargon
- 34 replies
- first post
- summer house
Dont we need to say his name 3 times before he appears ?
Selling a house with an ASHP
Nickfromwales replied to newhome's topic in Air Source Heat Pumps (ASHP)
Thats one of the options yes -
5 year plan, Nick.
