So...I'm about to do Rainwater Harvesting
Nickfromwales replied to mike2016's topic in Rainwater, Guttering & SuDS
If you are suggesting a retro-fit of a RWH system, then I'd bet my left nut that over the next 20 years, the cost of install / maintenance / pump replacement et-al would actually be a very different figure..... -
So is this 9" wall brick with no cavity? I expect so. What you have here, sir, is "penetrating" damp. Find the epicentre of each problem area and get the drill out. This will get messy and worse, before it gets better. This isn't a rising damp problem, for sure, just rainwater finding its way down through the old mortar perps and into the interior surface of the wall, or, is the same thing you see with older walls that have knackered, corroded cavity wall ties that are then bridging the damp across them; you can almost find the fault to the nearest 100mm.
đ€Ł
Mothers milk
If it doesn't, neither of us will wake from our deep sleep tonight, but if possible the two should overlap Will any of this actually matter(?), remains to ever be documented and evidenced in honesty. For the sake of the polar bears, fit the 100mm is my 2 cents.
Let this follicley challenged chap explain.... Random grab off the interwebnetiness
The question is, how thick is the screed / constructional slab that sits atop the 180mm PIR? And are the two finished levels matched or are the thresholds slightly raised? That will likely invoke a necessity to install the 100mm, eg so there is an overlap of the Marmox where it meets the PIR (unless my Brewdog Wingman has taken over control of my thoughts).
ASHP: monobloc, split or combi?
Nickfromwales replied to AndySat's topic in Air Source Heat Pumps (ASHP)
2021 iirc. I'm not sure what they do with these things nowadays, but I really can't see the benefit of a split unless you need very hot water eg to run existing rads etc. -
Does the castellated mat act as the barrier
Nickfromwales replied to Post and beam's topic in Underfloor Heating
Yup, if dry screed, nope if liquid. -
Does a portable electric heater without a thermostat exist?
Nickfromwales replied to london8's topic in Other Heating Systems
Found my son in his attic room, wrapped up in a quilt in front of his PC, with the A/C set to 16° ffsâŠ..đ€Šââïž -
Budgeting Spreadsheet and Cash Flow Forecast
Nickfromwales replied to JohnParf's topic in Costing & Estimating
You need to keep a handle on that, as Iâve all too often seen architects setting fire to my clients money at a terrifying rate of knots. One such architect I had to babysit all the way through from foundation to airtightness, and I was only there for the M&E!! Iâd have some conversations about this to keep it in check, as you can have your dream home without a nightmare budget. Plenty of good advice on here. -
Is this any help? https://national.homebuildingshow.co.uk/exhibitor-list?_gl=1*nluiv0*_up*MQ..*_gs*MQ..&gclid=CjwKCAiAkc28BhB0EiwAM001TQJ8Ytd6ErRY7hplY613HTsR6ei1teruNiXdE05ma7VjOZLoZ0fn1BoCxNYQAvD_BwE&gbraid=0AAAAAD-0KvykclfbMk73XWoN-FvOZJJdl -
+ 1
Each piece of glass (referred to in the trade as a unit) can be swapped out in an hour. Itâs a dead easy job. Random online grab for a cost calculator. https://sealedunitsonline.co.uk/regular/default_mob.aspx?gclid=cjwkcaiakc28bhb0eiwam001tbuisaorwfyxwzcam8f2frf9yhkbhgbvx51ngwlqrmtnuol16et9vbocdwsqavd_bwe Should be a couple of ÂŁhundred supply and fit by a local company.
đ€Ł. đ”đ„đ đš
Hi and welcome. Sounds like a plan! Great you got permission to do these as replacement dwellings as now youâll enjoy zero rate VAT Have you built before or are you complete newbies? Please ask loads of (some say stupid) questions as I doubt there actually are any stupid questions with an undertaking such a house build (let alone two ).
One I visited was just beyond what Iâd accept in my house, but was in their basement. When firing up from cold it was ânot quietâ, a bit like a washing machine shivering into life then starting a spin cycle is the best way I can describe it. Lots of buzzing, whirring, and vibrations etc, a Daikin iirc. -
What he said.
Our opinions on advice to bypass the thermostat on a domestic electric heater are âdissimilarâ. âșïž -
Sorry to say, that crack will only get bigger. The only solution is a replacement unit. What size is it, and how long has it been in for?
Sorry, this touches a nerve as itâs just a little too open to misadventure imho. What if the stat is there to prevent local overheating of floor covering / other build fabric? -
If itâs a decent airtight house with UFH, then during the heating season youâd be âon constantâ (long and low) so having a decent slab would be beneficial. Iâd recommend around 80mm of liquid Cemfloor, but you could go thinner. B&B floors should be designed so parallel load bearing walls land on a single or (sistered) pair of beams, depending on the type of load etc.
Yikes đ If the thermostat is a design feature to prevent the heater itself from ever getting above a certain safe operating temperature, then đ„. đ. No bueno. -
And the cause of a lot of house fires. Just put a desk fan in the room to âwaftâ the heated air about the room and thatâll work quite effectively, but as said just get 2 small heaters vs one just overheating the local area to it. FYI I use 2x ÂŁ19.99 fan heaters in my office which can switch between 1 or 2kW and have stats on board. Almost instant heat, only on when needed, and fill a decent volume of air / space. I doubt youâll find such a heater, as you ask for, as theyâd just be dangerous to use. I wouldnât want one in my house. Nearest thing would be an infrared bathroom heater which is fixed and up & away from people and combustible things. LINK
