Nickfromwales
    346
  1. Can you try that one again, plz, lol. Not clear at all what you mean there sorry!!
  2. Looks to have passed the O-ring and not to have breached the hydraulic body as such. Prob because string / rope was used not PTFE tape....
  3. Pretty much. A.4 - balanced cold output to the cold manifold comes off the dedicated port on the CG at the UVC. Assuming you know that, but just adding to for clarity. The 4 bar will give a 4 bar feed to the kitchen sink tap. The hot will have 3 bar from the CG at the UVC, and there's your 1 bar fight Solution is to put a single check NRV on the hot feed at the kitchen mixer tap, and a 22mm NRV on the hot outlet of the UVC, to be fully compliant. TBH, if you have a 3 bar "PRedV" (:rolleyes:) at the stopcock with 7 bar available I doubt you'll have any issue with dynamic flow rates being choked, and on paper that would make the 2x NRV's redundant (but they'd still be requisite as failsafe for G3 afaic).
  4. If its a deep concrete garage slab then is there still the obligatory 100mm step down into the garage from where you've knocked through?
  5. Or just lock you in the cooler with pocster.....
  6. Another unpredictable digression. We’re a diverse forum., if nothing else 🙃
  7. Last GC I did we simply self levelled the original concrete slab to get it flat and level, and then put 2 layers of PIR insulation down over a DPM. DPM needs to be done neatly and tidily with the joints / corners tucked in and taped so the insulation lays perfectly flat. Cut the insulation about 20mm too small to create a gap all around the perimeter for foam, and use the P5 boards (before laying them) as ballast to weigh the insulation down while the foam cures around the perimeter. Over that went 2 layers of 22mm P5, 1st layer parallel, and 2nd layer perpendicular with both screwed together and just glued joints. Worked a treat, including an en-suite with a shower tray on legs and a WC, all with zero movement, so no need for screed etc afaic unless you want wet UFH? That won't be cold, but you can get low temp electric UFH kits for use with engineered flooring if you want a bit of extra comfort for the 3-4 months of winter. EWI is only any good if you've dealt with the cavities and draughts, otherwise just do a minimal IWI so all of your room interior is an insulated surface.
  8. We all needed our heads examining....lol....as my 1st 42" plasma was £4-figures too. (I'm too embarrassed to say what I paid for it ), died pretty quickly and was buried at sea
  9. Unlimited throughput, rest of info I will try and link in a bit I've got the bumf just need to find it in the mountain of emails I have!
  10. Solarwatt are offering a guaranteed 80% minimum capacity at year 12. About as good as it gets. Also, afaik, they’re the same cells that they’re using in the cars (Solarwatt is owned by the folk who own BMW) so should be very robust. Any manufacturer should have a statement for recycling / end of life practices etc so just ask whoever you decide to go with for their info / policies.
  11. The apprentice has become the master....... 👌🙏
  12. I didn't look into it too intensively, just inherited some of it from jobs / surplus stock etc. Yes, if you lose the app / cloud then no way to view cams or save footage is a ballache, but was (is) quick & convenient which is the market it is pointed at I guess.
  13. Ring cannot be networked via LAN, they’re WiFi only, which is a piss-you-off tbh. I’ve got 6 devices and they’ve been pretty consistent and reliable over the last couple of years, decent wide angled view that zooms in pretty well for not much money). The floodlight ones are shite for the lighting, nearly 50% of the lamps are now dimmer or dead, so beware. If you’re going for one that takes an USB (C?) then you’ll have to generate that remotely and fire it down 2 cores of your CAT6 and use a soldering iron to splice. None of the Ring devices can run POE afaik.
  14. I’d be checking for a DPM, as you may find damp is something of an issue here. Maybe you’ll need to apply a liquid membrane first and then level it. I always use a 2 part self leveller (Ultra Level It) which comes with a 5L tub of solution which mixes exactly 1 bag of compound, so you get consistent mixes. You can lay this up to your max thickness in one sitting. For areas where it’ll be 5-6mm or less, you need to add 1/2 pint of water into each mix to allow it time to flow and to improve the viscosity so it’ll run out to the thin areas before biting and refusing to move any further. For those areas you need a spiked roller (google that and you’ll see examples) to help disburse the compound uniformly. Its not a job for the front hearted btw, and defo you’ll be better off with 2 people and to mix 2 bags / tubs up at a time for the thicker areas so you get a good spread and fill, plus it’ll go nice an level then too. Just be sure to mix the compound with a machine and only put the water into the mixed compound immediately before pouring out, mixing it again thoroughly after adding the water, so the heavy stuff doesn’t have time to settle to the bottom of your flexi-tub. Use decorators caulk or other mastic sealant to make sure the compound cannot disappear into any gas or voids, as this stuff will just vanish before your eyes if there’s any small hole or crack it can go into. For the floor area, spot fill with rapid set tile adhesive for divots, cracks, voids etc. You need to tick the ‘DPM requirement check box’ first to see if you need one. If not, then priming the surface will be the next bit of advice. If you have to use say black-jack as a liquid DPM then this needs sand to be thrown over it as you’re putting it down, to provide a key for the leveller. Simples, eh?
  15. Who’s is the hedge / fence? Can it be put behind the fence? Even if you have to pay for it I think it would be sensible for any possible resale to go advantageously, as you say. Other than that they’ve prob ticked every box tbh and have no further obligation to you. A tricky one to squabble out in honesty.
  16. You’ll need to check if FR plasterboard was used, or if there are sufficient layers with plaster skim to provide the FR you will need in order to store combustibles / vehicles back in there. Spotlights all other penetrations in there etc, will all need to be reviewed for compliance, so maybe not as easy as it first appears. Domestic garages are usually 2 layers of FR PB or 1 layer plus skim, but iirc 1 layer of standard PB plus skim will not suffice. One for your building control officer to answer properly, methinks!
  17. Almost no sites have any kind of running water in portaloos, let alone hot. You can hire ones which have a 110v wall mounted water heater, and then just hook up power and water, but then they’re littered with stickers saying you have to prevent freezing (?!?wtf) or pay for damages. You stand more chance of getting your ears bent for having a hot water ready unit on site that’s not hooked up than having a regular portaloo on site that’s clean and well maintained. Hot water in the welfare yes, portaloos no. Just ignore. And make sure you proactively enforce clean behaviour on site, as some people are just horrifically stinky bar-stards and will leave U571 in plain sight for someone else to deal with, which is disgusting for anyone else on site. Plenty of loo roll on site and some hand sanitizer is appreciated, as nobody wants to use one tbf, but using a clean / tidy one is tolerable.
  18. There is no shortage of overzealous architects and structural engineers, so I’ve seen a few!! All domestic residences. 🤦‍♂️
  19. Doubt that required at this thickness. Only ever seen this with a 100mm thick raft tbh.
  20. My go-to stuff is, https://www.solseal.co.uk/building-products/primers/ultratile-proprimer-advanced-polymer-primer-5l/?gad_source=4&gad_campaignid=18660036211&gbraid=0AAAAAC6dNVJMz5_DklvkI8Cb7s5WA0_vQ&gclid=Cj0KCQjw_dbABhC5ARIsAAh2Z-Szkw_J1yfigRCTCR-KcSqzIKRHp74qcZ292_5C6y0OlxwMnUEPySsaAu-HEALw_wcB Just buy it wherever is the best price obvs.
  21. As long as you leave for at least 60 days, preferably 90, for the concrete to 'go hard' then you'll be fine without the decoupling membrane. The important part is to use a good quality flexible adhesive, and prime before laying, and also as you lay. I clean / decontaminate the surface of the slab with a 50/50 mix of primer / water, and scrub this into the slab with an old school janitors mop, until the surface is saturated. Then leave to dry after you back mop any pooled solution. Then I put 75(w)/25(p) mix or just neat primer onto each m2 with a sponge as I lay the tiles. I don't ever put adhesive onto 'dry' concrete, ever. Primer NOT PVA
  22. @Tony L, seems like @Pocster is offering to come rebuild your walls just for tea, biscuits and to get some experience 👍👍👍👍👍. Send him your postcode 😜
  23. Yup. Leave it there, install the nice plaster-in one as shown, and go put the kettle on. 😉. You ‘may’ notice a bit of a dust line over 6-12-18 months of operation, but if you use a Ken Dodd stick to keep those walls clean as preventative maintenance I seriously doubt this is any issue whatsoever. ’twill be fine
  24. You can also use T&G pine floorboards for the area under the bath, as bare P5 will cave if you get any kind of moisture under there, and DEFO do not use OSB(3) either. Are you tiling in here? If so, you’ll be fitting plywood and spreading the point load with the tiled floor, and at that point P5 / ply / tile will be plenty here, with a couple of noggins obvs.
