D&D Plasterboarding in kitchen
Nickfromwales replied to crispy_wafer's topic in Plastering & Rendering
Yup, it’ll pay dividends. Run the electrics horizontally, in the safe zone, to make like easier, or come up to the outlets from down low and then there’s the least amount of wires to navigate when drilling / fixing bits and bobs. -
SIPS but no MVHR?
Nickfromwales replied to sips novice's topic in Mechanical Ventilation with Heat Recovery (MVHR)
If a certain volume of air is removed from the property, the exact and equal amount of outdoor air will be drawn in to replace it, via whatever gaps or engineered openings (such as trickle vents) there are. Smells from outside get into my house, same as any house, but with MVHR you get to shut it off in extreme cases whereas I’m bloody well stuck with it. Builders are great…….😌 -
Yup. A continuous layer where wall units need fixing for sure. Base units not so much, but it’ll be a lot easier if you do the same at the lower level too. -
SIPS but no MVHR?
Are there comprehensive pictures of the house being built? The VCL would be my biggest concern, as ventilating internal spaces can be done later tbh. -
To be clear, you are being asked to install more fence line between the houses? There’s no need for a physical barrier, just both properties share that access and respect the boundary. Seems nuts to have that dead man’s land between the 2 fences though. Ultimately, it is 100% your own fault for not checking the official deeds and listening to a builder when he just pointed at things, however, if they sold you the property on this understanding and you have it in writing, with evidence, then you could go after the builder (if they were the sellers) for misrepresentation. Are you on good terms with the neighbour?
Rapid EV charging is the obvious advantage, but if you’ve only a modest home it’ll still possibly need a second phase if you want more than one EV charger. It’ll become commonplace for homes to have more than one EV I expect, so this is defo a big consideration for future proofing.
The main issue will be wind catching it, and wind-driven rain getting behind it, so best to get it sorted tbh. Another mass built atrocity? Sorry to hear you’ve had such problems, but it generates more argument for doing the build yourself (next time ).
- 1 reply
IIRC, the test is 10 positive + 10 negative, and the score is the average of the 20 tests. Things change, standards move, but the basics remain the same; the devil is in the details and airtightness will always be my #1 recommendation for a comfortable, efficient home, then insulation, then fabric and roof choices for acoustics and decrement delay. Fabric choices can either help or hinder with airtightness, but understanding what you’re doing before you do (or attempt to do) it is paramount, so ask a lot of questions and prepare well.
That was just a random internet grab, so shop around.
Contact a local pvc installer and ask them to supply and fit a suitable, replacement hinge for you. Likelihood is, that it will need to be adjusted when fitted to get the door to open and close / lock / seal properly, so needs a bit of attention tbh.
Long shower waste run - can I avoid a stub stack?
Nickfromwales replied to maznaz's topic in General Plumbing
5m in 50mm pipe will be fine. To appease the BCO you just need to demonstrate it working afterwards, they shouldn’t really be too bothered about anything after the 110mm pipework / vents etc. No need for an AAV unless the pipework drops vertically a good distance before meeting the stack. -
https://www.buyinsulationonline.co.uk/product/novia-a1f-building-paper?gad_source=4&gad_campaignid=22149925402&gbraid=0AAAAAolHs116snL13ZrLXATGXtAl0ng5L&gclid=Cj0KCQjwoZbBBhDCARIsAOqMEZUWvJ23gaPqHoGM1WgXfutk1-neASiKkpZE0KoCZTsh0mwEStg5KcIaAsLCEALw_wcB
Can the DNO cutout be located inside?
Nickfromwales replied to WisteriaMews's topic in Consumer Units, RCDs, MCBOs
Indeed. You don’t need much room unless you’re splitting off for other things, which would then need extra kit in there such as switch-fuses and isolators etc. -
Not so sure that's practicable? Ventilation and rainwater runoff, moisture behind cladding needs to be able to drip, dissipate etc so I don't see how the cladding can finish flush with the lower course. Pretty much anything is 'doable' with time, imagination, and budget, but I think you need to look at sectional examples first to decide if the flush finish from one discipline to the next is actually going to work in real life.
They're not airtight, so don't really need any ventilation as such, also they don't get 'hot' so to speak. This kind of thing. Random grab. https://www.ebay.co.uk/itm/192527358041?chn=ps&_ul=GB&mkevt=1&mkcid=28&google_free_listing_action=view_item -
Not needing a crane will be one saving. I'm not a fan of a SIPS roof, particularly with a metal rain screen, due to the noise / acoustic transparency of the PIR vs say blown in cellulose or other similar higher performing material. SIPS will need manufacturing, cut roof will be DIY / builder and more flexible / forgiving for you to work with.
Codswallop..... It weighs the same, either chuffing way !! The better job would be to increase the footprint of the timber at the point where the load is transferred to the masonry. Complete nonsense afaic, sorry. so different fixings change the weight of the load do they? Not what I was taught, in the few physics lessons I attended. This suggested methodology, of cutting a section of a brick out, shows that this person has zero practical skills or has ever tried this in person, as it simply cannot be done. You take out an excess amount of masonry, clean the hole and set a mix of compo in, then use an offcut of timber to create the pad out of compo (sand and cement) and allow to dry. I use a piece of synthetic slate on top of the compo to create a nice clean shelf for the timber to sit on. Once the timber is in place you fill in around the timber with more strong (3:1) compo and job done. Trying to get the timbers into this wonderfully neat little pocket you are going to attempt to make would be wholly impractical and cause you no end of logistical aggravation during the install, and the suggestion of you disturbing say 100mm of masonry would compromise the strength of the wall is just make believe, sorry again. Is this guy a 1st year apprentice or something?
Underlay is for impact / noise more than anything, so just use whichever you want. Some have a foil for an vapour barrier, and some insulate, etc. If it’s over a suspended, cold ventilated sub floor then you’ll need to control vapour, so look for one that offers that functionality.
Ah, ok. Just make sure you mop and clean the floors aggressively, I use a janitors mop. Soak the floors (and I mean soak) with 75% water 25% primer (not PVA) and repeat a couple of times. This will rid the surface of dust / contaminants, and size it prior to levelling. The self leveller will need fibres ideally, so go for the Mapei builders screed (20kg bags) and mix to the exact detail on the package. 2 person job so ones pouring a bucketload out whilst the others mixing the next, this isn’t a job where you can break off for a cup of tea as this needs to be laid wet on wet so it flows and levels. Use the same mop and prime the floors immediately prior to laying, repeating as you go. Don’t worry about standing pools / puddles just avoid as best you can, but you can’t have this too wet imo and it makes a huge difference to how the leveller will settle and blend. After mixing as instructed, you then put 1/2 pint of extra water in and give it one final good whisk, and literally get it onto the floor whilst it’s still spinning. The extra bit of water will further promote it levelling out and flowing very well, plus it extends the ‘open’ time between bucketloads going down to guarantee that wet on wet application. You’ll need a spiked roller too. Have you levelled before? If not, do one room at a time, and choose the easiest one first for a practice run.
