Not enough cement available.....and I'm not willing to share any of my pies, or pasties for that matter lol. The government do not seem to want to help to get rid of the 2 or 4 legged/winged variety. Personal injury ain't! My son had a bad cut to his thumb, as the fecking things beak was like a breadknife. Just imagine what that can do to a face. My pack of 2x16 slices.....when I looked at it properly, the beak had gone through the quite thick plastic, and through 14 of the 16 slices!!!! Even with me running towards it, it refused to let go of the pack until I was less than a metre away. And even then it just sat on the ground screaming at me to give up the goods. ffs. My hand was on its way to my mouth when that large gull put its head between my hand and my face, and plucked my steak bake out of my ninja like starving plumber grip, and with zero noise or warning. These things are out of control and are not scared of humans any more. Genuinely intimidating to be walking around trying to eat something in the open in town tbh.
Seagull thread coming next. One attacked my youngest son, cutting his thumb open, and flew off with an entire fecking BigMac. Same spot in town where these food outlets are, I had one swipe a pastie literally as I went to put it in my mouth.Then a few days back I had my shopping laid out loose in a small trolley. Stopped to talk to my mate in the car park and he said “look out!”. Fecking seagull was flapping his ass off trying to take off with 32 slices of bacon. I ran over and it just stared me out and then gave up. Time for a cull of these ‘flying rats’ ffs. Bastards things are everywhere now.
Radiator update to thermostat rad valve's
Nickfromwales replied to AidanGee93's topic in Central Heating (Radiators)
Hi. You’ll need a sealed and pressurised system for the combi to work for hot water. Just buy cap end when you remove valves / rads, and fill the system back up to normal working pressure. You’ll heard few gurgles for a day or so where the system has to evacuate all the air out, maybe, and you’ll prob need to top up the pressure a little the next day. Then you can leave the rooms capped, decorate, and the do one more drain down and refill with all new valves done in a day. Use a junior hacksaw to cut the pipe under the existing nuts, as the pipe where the olive is will be compressed, and if you remove just the olive and push that into a reducing set, it’ll leak. You need to be on to fresh clear pipe. -
Chimney removal and joist need replacing/sistering
Nickfromwales replied to moe's topic in General Structural Issues
Yup. There are thick square washers which are typically used for this job, and you just size them for the threaded bar you’re using. Prob M12 or M14 for this size joist. -
If you have 230v power already there, and there’s more than 1 breaker feeding them, then I’d just have all the 110v stuff plugged in as and when required. Leave the trannys outside and just run 110v leads to the point of use. 110v can be extended for miles, 230v not so much. Have one tranny dedicated to lighting, and then invite trades needing 110v to arrange their own portable tranny and that’s usually the end of it. The only time I see these multiple outlet, fixed 110v banks is on commercial sites. I’ve not seen one on a domestic site in ages, and last one I saw was on a huge site. These are mostly for when there’s a huge amount of demo and major construction. We did a basement dig out and underpin last year and for the ground workers we just bought 2 standard portable 110v units which was suffice for the breakers, 3 storeys of temp lighting, power tools etc and all fine; we put a 230v CU in with 3x 32a RCBO’s feeding 2x 13a metal-clad double sockets each and nothing tripped afaik.
It won't hurt that's for sure. -
Covered Decking Area (pergola)
Nickfromwales replied to marshian's topic in Landscaping, Decking & Patios
Still lets a lot of light through. Tres bien. -
Stuart Turner Negative Head 3bar Twin
Nickfromwales replied to John Carroll's topic in General Plumbing
They will likely have unvented hot water cylinders, so the point is moot? -
👌. Maybe get some brick acid on the floor to clean off residue before painting?
Defo need one person at the helm and the others following. One person to take the info, and one person responsible. If not, it’s he’s said / she said, or worse; when the chap you programmed fecks off for a few days leaving Larry and Mo behind, who immediately start doing their own thing.
Services issue post purchase with inaccurate PEC
Nickfromwales replied to DC5's topic in Party Wall & Property Legal Issues
That’s what I meant. Not saw one before but then thought what a brilliant tool. Only good for ground that’s largely organics though. Otherwise it’s a world of pain and digging with the narrowest bucket you can find. -
Some farmers will have a pipe trenching attachment for their daily driver. Can shoot through this job in a day with that tbh. -
I wish I could charge for “tools” lol. Could just drop my stuff off at 08:00 and collect again at 16:30, and say “stump up please “ Finally, the perfect career
Potton Homes(Kingspan) out of business
Nickfromwales replied to Post and beam's topic in General Self Build & DIY Discussion
A lot of companies go through due to cash flow issues and non payment, iirc Beattie was one that suffered the same demise; an otherwise fine and function-able company with a good reputation. Them going down affected other smaller companies that I deal with, which nearly put them under too. This is a 2-way street tbf, but clients can use CC’s to get covered whereas when someone didn’t pay their bill to me (more than once) I just had to suck it up. It’s near impossible to prove a client owes a contractor money, when mid multi-disciplinary turnkey works, unless your paperwork is as good as your practical work; mine wasn’t so I got screwed. I charge a fair bit up front these days, but only nominally and at as little risk to the client as I am willing to risk myself. I come via recommendation, clients fee to reach out etc, so the risk is with me; one client last year said they had 6-figures of funding in place, so I cleared my calendar for 4 months, and then said “oops, what we meant to say is, we’re flat broke and a year away from progressing”. Ffs. Left me in limbo looking to pick up another job then, with the resulting impact to my pocket book. Recommendations and trust are the best you can hope for, but both parties take a leap in one way or another, for sure! -
Installation or manufacturing defect, quite common tbh. They should exchange that in a heartbeat, so I’d not panic. It’ll get worse, nothing you can do other than don’t open / close it, if you care that much of course. If the opening ‘door’ part of the bifold is the other end, then using that will have no affect, but if this is the ‘door’ then every time you open and close it you’ll see this crack grow. Let us know how you get on.
I’ve fitted loads of these, always ST, and never a moments grief; other than them clapping out after 100k miles, with a full military funeral. -
I’m assuming this is to balance the chambers and possibly the output supply? If it doesn’t affect the shower, then I guess a design that allows it to work is not a flaw? -
This is what I just scan read through. https://www.stuart-turner.co.uk/product/monsoon-u3-0-bar-twin-46410 -
