Laundry room sink / appliance plumbing wobble…
Nickfromwales replied to Omnibuswoman's topic in General Plumbing
Ok! After the first bend, you are then on quite a steep incline. This is putting your washing machine (appliance) upstand quite high off the floor. Yes, you can guess what I’m going to say next….. The amount of incline in the room itself is good, just you’ve used up too much ‘fall’ in the service space. You could abandon the connection to the stack and ‘boss’ in lower down, but that’s prob worst case scenario. This needs a tweak first, to lower the pipe as it enters the utility space, to lower that upstand. Good effort though, and good on you for getting stuck in / hands dirty I’d lose the blocks that you’ve used as stand offs, and simply use 2x 45° bends to see the pipe out just before it goes through the wall. Is there any reason you’ve not run the pipe on the plain OSB wall and then just punched through exactly where the pipe meets a trap? Would save cutting the back of units / navigating around that horizontal waste pipe run in the utility. -
Floating floors: compression vs vibration
Nickfromwales replied to Workerbee's topic in Floor Structures
OK!! Give us the depth you have to play with, from slab up to FFL please, as there's a lot of info but it's all a bit tricky to correlate. And why electric UFH? It's the most expensive thing you can run, and is this for supplemental heating or full-on space heating? -
Get your prelims in check, and listed / costed out so you can see ‘hidden costs’ as a lot of folk skip over this, and become unprepared for paying for things when they pop up, that’s before laying a single brick btw. Who’s been mentoring you to date? Architect?
2 sides clad in insulation and windows up against those, small alu capping internally to match window frames, then just alu cappings again externally. I had the external one made up in 2 pieces, to ease fitment (and manufacturing). No pics sorry, I had departed soon after sorting designs as these took some time to manufacture, powder coat, and for the installers to then book the clients in. Once I’ve broken the back of a job for people I’m usually then off to the next one, only then staying in contact for remote assistance, such as this type of ‘last minute’ detailing and problem solving; a lot of this goes on as the design and pre-construction phases are often just skipped though sadly.
Consumer unit replaced. Certs needed?
Nickfromwales replied to BotusBuild's topic in Consumer Units, RCDs, MCBOs
Send me a PM please!!!!! -
Exactly what I faced on one job, and opted to not insulate externally; the design I gave the client for that featured a very generous bead of mastic to affix the aluminium to the steels, with continuous beads at foot and head to stop convection through any otherwise resultant free air space. To date, no complaints, and a far lower profile solution from the exterior aspect 👍. Compromises can be made successfully if managed meticulously, that’s the ‘gotcha’.
On a few previous clients projects, similar circumstances, I clad the steels with 20mm Compacfoam, and the client ordered the fenestration with the deductions in width made accordingly. Then I employed a designer / installer for alu cappings to be made, and RAL sprayed to colour match, and results were perfectly satisfactory. I actually preferred that to the option of dragging the steel inboard, so maybe a review would change your mind; at least put it at ease a bit anyways.
Check my PM to you plz mate Sorry for the hijack. @BotusBuild, I’ve never done a CU swap with testing first, and then giving a certificate (via one of my bonafide sub contractors), so you should have had one. If you didn’t ask then they probably did it as a ‘cash’ job and wanted to be in and out. -
They could have concrete screwed some treated battens into the brickwork, and then screwed into that. There’s always a way to do a job to the best possible outcome. Or. Cut corners, grab the money, and shoot off.
Chimney removal and joist need replacing/sistering
Nickfromwales replied to moe's topic in General Structural Issues
Whatever’s salvageable you can keep. Just check it’s in good condition and retain it. -
Here we have put OSB in as a packer, then 8x2 over that to get the timber past the edge of the steel.
Ubbink - what are they like?
Nickfromwales replied to lizzieuk1's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Yup. Sounds like it’ll be a barrel scrape solution for that money, afaic. -
Brink / Ubbink is all I’ve used in 99% of my clients builds. Zero issues. I’ve had great prices / service / design support etc from CVC Ltd (Oxon) and they have some good prices for kit on their box-shifting platform (Air-haus.co.uk). £8.5k supplied and installed for that size house is cheaper than I’d have done it for, by a LONG way. Are they quoting a single 600 unit? Or 2x 325’s? -
Hi. You bolt timbers into the web, so they finish just proud of the steel. You then fix the joists to that timber, using a gas nailer firstly, to pin them, then proper joist hangers to complete. Your SE is making work for you imho, and prob still lives at home.
If 12/24v then it’s SELV (Safety Extra Low Voltage) so you could lay it in the bath and jump in safely. There are some very thin led strips out there atm, but the likelihood is you’d need deeper than standard worktops to gain a little more overhang, as a standard worktop doesn’t have sufficient real estate to do this imo.
FLIR camera to see if waters making its way around the FF loops most prob. Or feck off to the pub, and order a jumper on Prime whilst supping soothing cold beer.
metal framed cupboard and dropped ceiling
Nickfromwales replied to Thorfun's topic in General Joinery
Change it You know you must. -
Step 1
These should have been left open by the installer. They stay ‘open for life’ so they can look after you and let any ‘air’ out.
Amen 🙏. My issue was, it was always a clients build site
If they were tight, then they weren’t doing any venting. A box has been ticked. ✅
Changing wc gasket, between cistern and pan
Nickfromwales replied to saveasteading's topic in General Plumbing
Conclusion: You did a shit job lol. The ‘leak’ is seldom from the doughnut washer, and more often from the bolts. When did this leak? Continuously, or when flushing? If it’s a daylight issue, then please do consider fitting a light in the bathroom. Your family will thank you. -
Those caps are like the ones on your car tires. They need to be ‘loose’ to work, so give them a ‘twiddle’ and see what the situation is there plz. Close them finger tight, and then open 2 full turns 720°, if unsure. Then they’ll be able to function properly and let ‘air’ out.
