Nickfromwales
    346
  1. I’ve done a few HMO’s where 3 phase wasn’t available, so I had the DNO bring the same phase in twice; so 2x 100a supplies. Depends on how the charger uses this power, as 2 phase doesn’t make any sense at all, and as you say should be glaringly obvious in the MI’s. Can you get 3 phase and switch the zappi out for the fast charge unit? That will charge at differing rates iirc, so you don’t have to keep bashing the battery with unnecessary super-rapid charging.
  2. Agreed, but a), we can’t assume they right do it and b), if there are any issues with a modern RCD / RCBO CU then the circuits will just trip out. I’m not saying not to do it, and I always priced in to do a full health check with the existing CU left in place in case every circuit tripped, as otherwise you’re left holding an expensive nightmare.
  3. Yup. That’s what I was referring to. Gives the install a 10 yr (iirc) MOT
  4. Compression stuff is pretty bombproof, so I can accept the compromise which you are proposing lol.
  5. Horse manure. Solvent weld all day long.
  6. I fit these, not too tall tbh. Put the SVP elsewhere? Or out horizontally at the top of a gable maybe? Done that a few times too.
  7. If it’s not part of the network, and you T in using a compliant and recognised method, then I doubt you need to say much more; assuming you have not been told by anyone not to do so. Was nothing agreed before you bought someone’s garden off them to build in?
  8. MCS is required to sell your excess, and you’ll have a LOT of it. You should defo consider an ASHP, as your winter generation would offset gas use. Split roof elevations mean 2 strings. You can only use so much hot water, and electricity, so where’s the maths to justify this enormous array? Asking for a friend
  9. Only suggested, if you lost the blocks of wood. A 90° bend in the corner is 👍. @marshian makes a good point, so make the final 90° bend going into the utility a T instead, and put a cleaning eye in the redundant open end so you can ‘self clean’.
  10. Simple question is, do you need one? Unless you’re renting the place out, you don’t “need” one, and we don’t know the arrangement you had with this person (cash / invoice), but you can get a simple inspection done and get a cert that way if you really need / want to.
  11. If this is an installed system, the installers would come and survey this and underwrite the whole thing. They will have done this a thousand times, so unless you’re DIY’ing it the information here would maybe be of not much use to you, sorry. Are you paying contractors to supply and fit, for eg is it coming via a grant / funding?
  12. You could also go out through the wall and mount an external flue using stand alone / secretly mounted brackets.
  13. You just sell it on later with the WBS installed as a bonus. Just do a good job, with a good appliance, and then you’re all good. You’ll have a relatively long time to advertise / sell it at the end of the build, so I’d make life comfortable for the build and stop panicking about minor issues. Worst case, the roof can be put back ‘as was’ in a couple of hours with some plate, rivets, and CT1. Even if it knocks a couple ok £k off the resale value, who cares?! It’ll save you 20x that in the long run anyways, so is basically sacrificial in terms of cost / loss.
  14. A PP (positive placement) gun These allow you to get the nail into each hole in the hanger accurately, at a decent pace.
  15. Hang under the gutter and use clear cable ties to fix to the gutter clips? You can get some tension in the strings then, to stop them flapping about.
  16. This may be worse as you’ll likely need 1/4 cube concrete pads set in to take these point loads. Load would likely be better transferred down through the walls so it’s distributed.
  17. They’re doing a very good job. Id be happy to relax on hols whilst these guys were working for me, so that’s great news for you on yours
  18. Granite installers should notch cut the underside of the worktop and install stainless dog ears set into resin, plus bond the sink also. Between those two measures, the sink should be plenty well fixed. Builder should 100% have supported this as a temporary install. A carpenter would very likely have offered this up as a solution. TBH, you can just fit a piece of iron on edging afterwards, once that cracked timber has been bonded and clamped to the granite.
  19. Can you get a hoover in there and suck the debris out? Then, get some bendy straws to fit on the foam gun and pack it out with FM 330 foam. That’ll be the end of this saga then , to the top of the tiles. Then pipe insulation and job done.
  20. If you get some compo out of them, I’ve seen a nice private plate for your car.
  21. Having the equipment makes a job like that a doddle. So many struggle to save plant hire costs, but that’s dangerous and hugely inefficient. Nice to see a good site setup and the progress speaks for itself.
  22. “Stinks” of a manufacturing defect. Unit needs a forensic strip down and rebuild, and to actually see / examine every joint and junction. Probably something very simple, there’s not much to go wrong with these things.
  23. Ah! Then no, you’ll be fine. Most appliance manufacturers will give a max height for the discharge hose to be at, when going into an upstand, so that is now deleted from the situation and a (combination) trap will be fine. I’d still move the pipework to the other side of the wall if possible.
  24. Assuming this is a continuous piece of MDPE to the stopcock, the only place a dribble could be occurring and going unnoticed is from that ungodly stopcock which is brass compression onto the MDPE. I hate them, as the least amount of excuse you provide will result in this failing. I always go MDPE > copper via an MDPE fitting which is specific for this job. @gambo are you 1000% sure this MDPE > brass connection is 100% leak-free?
