Temp
Everything posted by Temp
That would be my guess. Sometimes a power supply can go unstable if its too lightly loaded. If it says minimum 7.2W and you only have 3W that might account for it. Got any 12 V car bulbs? Perhaps put two 10W bulbs in series to see if loading it up stops it flashing. Only having a working range from 7.2W to 12W is pretty poor. I happen to have the 24V 60W version of this one going spare. Its new and untested. No instructions but you can have it if it helps. It says "no minimum load" in the info. https://www.amazon.co.uk/dp/B0BRQ6Y9VZ?psc=1&ref=ppx_yo2ov_dt_b_product_details If interested PM me an address and I'll stick it in the post.
@Marvin I think you are looking at a valve on the filling loop. The one on the left appears to be on the pipe at the back eg where the other end of the flexible pipe goes. It's common to have isolation valves on both ends of the flexible filling hose.
[Mod note: this reply and the next are responses to a post by a spammer that has now been deleted. Leaving the responses here in case of interest] Kingspan and Celotex are companies. Both make a range of insulation boards both PIR and Phenolic with similar thermal conductivity. Just two examples.. Kingspan - Kooltherm K108 - Phenolic - thermal conductivity of 0.019 W/mK Celotex - GA4000 - PIR - thermal conductivity 0.022 W/mK The smaller the number the better.
Insulated Concrete Slab Garden Office - Questions
Temp replied to Ticky's topic in Garages & Workshops
Yes I laid two courses of engineering bricks then put a DPC on top and then the wall plate. I cut an X with a knife in the DPC and just pushed it over the bolts. Then trimmed off the bits that stick up with a stanley knife. It was overlapped at corners and where the end of the roll occurred. The double thickness in a few places didn't cause any issues. The holes in the wall plate were drilled quite a bit oversize just to make their position less critical and allow it to drop over the bolts easily. I put big washers on top under the nuts. -
Heating controller and thermostat change
Temp replied to James94's topic in Boilers & Hot Water Tanks
+1 if that black backplate still used? It's got wood to the left so its not the one behind the controller? or the thermostat? -
Building Control Inspector Changes Previously Approved Inspections
Temp replied to Dabooj80's topic in Building Regulations
I think he's asking for far more than he really needs but all I can suggest is providing it. The only "report" I can think he needs is from the designer eg structural details to justify the design. As for a warranty I would collect together warranty info for the roof tiles and roof membrane. Possibly from their websites. If its a flat roof the installer of the top layer would normally provide a warranty for the system used. If you are getting a 10 year warranty provide details of that. So you may already have provided the first bit. Normally a plan showing the house on the site with the location of things like WC, showers, stacks, inspection chambers and the routing of pipes to the main sewer in the road. Ditto for surface water. Ideally the plan would have the depths for pipes but you might get away with specifying the falls on pipe runs. If soakaways are being used the location should be shown with the distance from the house marked and a note on how the soakaway will be built. He may also ask you to justify the size of the soakaway but I would wait for him to ask unless you have that in hand already. Where pipes go through the walls below ground there are standard ways for dealing with settlement and rodents ingress. Probably copy them from the regs? When stacks go through the roof there there should be some sort of flashing around it. For this sort of thing perhaps copy the suppliers drawing onto a blank drawing and add a title such as "Flashing detail for roof penetration of soil stack". It's not real hard to make it look professional just annoyingly time consuming. -
What about drilled piles? Thought they weren't too bad for vibration. https://www.self-build.co.uk/piled-foundations-explained/
There are plenty of conventional programmers available from the likes of Honeywell they might find more familiar? -
Im not very familiar with the Hive controller but isn't it App based? Are they young enough to cope with that? Won't find it too confusing? Youtube has guides on how to install hive but it's not necessarily straight forward. -
What problem are they having? Is the existing controller faulty or are they just having difficulty working it? That thermostat is pretty crude. A small turn of the dial can change the temperature several degrees. Is it possible they are just over controlling it?.. too cold.. turn it up.. too hot.. turn it down repeat? -
Has weight per square meter.. https://regaltiling.nz/tile-selection/tile-weights/
Yes. No you should get it ALL back as its been empty more that 10 years. https://www.no-use-empty.org.uk/advice-and-guidance/property-tax-and-vat/reduced-vat-schemes/ However its important to pay any trades the correct VAT rate. If they charge you too much VAT (eg 20%) you cannot reclaim that as you should not have paid it in the first place.
Does Class Q mean residential status is granted
Temp replied to ChrisF8's topic in Planning Permission
Class Q does include the land (but there is a but).. but most of the sections/classes that allow people to add extensions or construct outbuildings etc have these words.. So in short getting Class Q removes a lot of what would normally be Permitted Development on a regular new build or conversion done under Full planning permission. You cant even add a patio, porch or oil storage tank without planning permission. Planning permission isn't normally needed to convert an outbuilding to a gym or similar that is incidental to the main dwelling but I'm not sure which Class it comes under in the GPDO. Probably Class A but that also has the same words as Class E above. Its also worth noting there is completion time limit on Class Q. -
My understanding is: 2 Years - Contractors should charge you 5% VAT under section 8 of VAT708. I believe that's the only provision. I don't think a self builder can reclaim the 20% VAT he pays on any materials. The 5% paid to a contractor cannot be reclaimed. 10 years - VAT paid by a self builder can be reclaimed using Form431C. I'm not 100% sure what rate contractors should charge you. I think its treated the same as a conversion of a non-residential building, in which case they should charge you 5% and that can be reclaimed.
Just remember the £30k limit on section 75. If the total order value is over £30k you aren't covered. Not even the first £30k.
Beam & Block Grouting - Estimating Materials...
Temp replied to Mulberry View's topic in General Self Build & DIY Discussion
Perhaps make up a small batch from bagged materials and see how much area it covers, then you know how much to order for the rest. -
Some LED floor standing lamps similar to this one have the transformer in the plug. Sould be easy to insert that flat cable between the plug/transformer and the inline dimmer. Just check the output current from the transformer is less than about 6A. Should be written on it. https://www.lampandlight.co.uk/design-floor-lamp-black-incl-led-5-lights-sixties-trento?gclid=CjwKCAjwitShBhA6EiwAq3RqAxrQv_uHGA7xh7eJau_drOi1TLmbuqe7-_emfq462tk7ppOMRcMqixoCTj4QAvD_BwE
+1 Perhaps the super thin cable in the OP could be used. Eg Cut off the plugs and use it between transformer and lamp. The spec says it's ok for 1500W which at 240V is about 6A. So should be fine for 6A @12V or about 70W. Plenty for an LED. Perhaps fit a suitable fuse on the output of the transformer.
No Earth in the cable? Insulation must be extreemly thin if it's only 0.9mm thick overall.
+1 If you have to keep topping up the system pressure that suggests water is escaping somewhere. Either out of the PRV or a leak. I know you said the PRV has been replaced but PRV can be a bit temperamental. If they let water out once for any reason they can often start dripping or letting water out at less than the rated pressure. Perhaps put a plastic bag over the outlet pipe for 24 hours and see if it collects any water. If its not the PRV I think you may need to start isolating and pressure testing parts of the system to narrow down where the leak might be.
Digital shower questions and feedback?
Temp replied to VickyBH's topic in Bathrooms, Ensuites & Wetrooms
Most conventional shower mixers can be serviced through the front plate with no need to damage tiles.
