Temp
    43
Everything posted by Temp
  1. The only other issue I can think of is that the land in the visibility splay must normally be under your control or public land. Under your control means you either own it or there is an agreement in place that the owner will keep it clear.
  2. Where is the cistern going? The geberit frame with cistern need more than 4" depth. Looks like min 195mm but check the model you are using. Drilling 40-50mm holes in say 205mm studs no problem. Even in 100mm would probably be ok. You could always double up the thickness. There are typically two long bolts/threaded rods that fix the top of the frame to the wall. Ideally these should fix to the blockwork (or a substantial bit of timber fixed to the blockwork) as they carry some load. There are adjustable feet at the bottom that you need to set to the right height and fix securely. Height not too critical for a wall hung but more so for floor mounted back to the wall type pan.
  3. You said there is no ditch by the road but are there any surface water drains along/in the edge of the road? Frequently in the past old ditches had pipes dropped in them and filled in when the road was widened (so called piped ditch). I think time to discuss your rights with your solicitor or a firm that specialises in drainage rights. Does he own the land all the way to the river? If you can prove to him you have a right to discharge he might be more amenable to allowing the pipe to be extended to the river.
  4. I think the amount you can discharge increases from 2m^2 to 5m^2 when you replace a septic tank with a treatment plant. Edit: Ah sorry that's only if you can discharge to a water course not a soakaway... https://www.charlesrussellspeechlys.com/en/news-and-insights/insights/private-client/2022/buying-or-selling-a-house-with-a-septic-tank-what-you-need-to-know/
  5. Make sure you understand the VAT rules before accepting any quotes. It's likely you should be charged 5% by builders and reclaim this after completion with form VAT431C. Make sure quotes spell out VAT at 5% or it can cause grief later. Any problems getting a trade to requote correctly refer them to VAT708.
  6. I suspect you have a right to discharge into the existing pipe but you should probably replace the septic tank with a package treatment plant.. https://www.hcrlaw.com/blog/drainage-discharge-and-riparian-rights/ I believe treatment plants became mandatory on 1st Jan 2020 where the discharge is to a water course or ditch but its not clear where yours was going so this may not have applied... https://www.draindoctor.co.uk/about-us/hints-and-tips/item/2020-septic-tank-law-changes-what-you-need-to-know#:~:text=However%2C the new regulations released,directly into a local watercourse. So if it was to a ditch the previous owner of your house might have some liability. Otherwise my thinking is you can probably replace the tank with a treatment plant and assert your right to discharge to the existing pipe. It then becomes the other land owners problem to disperse the discharge. I'm no legal expert though. Given there are several houses involved you probably need to join forces. If one of them won't engage you may have to leave the septic tank in the ground for them to continue using. Again as several houses are involved it might be possible to persuade the water co to provide a first sewerage connection. Sometimes they do this by installing their own small plant shared by a hamlet/village.
  7. Company 3D printing 100 houses in USA..
  8. Typically they require nothing over 1m high in a triangle who's dimensions depend on the speed limit.
  9. I've had good response times on the forum but check replies are HMRC staff. Typically had answers in a day or two.
  10. +1 There must be dozens of different solutions. Oak posts and rail with glass panel. Ditto but metal posts and rail. All glass, no posts or rail Numerous styles of wooden bannisters and railings. Wrought iron. Curved brickwork with holes in Glass bricks to the ceiling. Hugely expensive curved polished copper panel 🙂
  11. BCO almost never do their own structural calculations or similar design checks, they ask you to get an SE to validate the design. Then all they have to do is check you have built it as specified. (Grenfell tower).
  12. The only time I can think continuous mode might work is when you have a rad system with a TRV on every rad? and a bypass to shut the boiler off when they are all closed. Will be interesting to hear what the answer is.
  13. Manual also has this.. Not sure it make things any clearer.
  14. That's what I would expect in Room Temperature mode but it doesn't mention being controlled by room stats (directly or indirectly via a wiring centre) in the paragraph describing continuous mode.
  15. Possibly too late now but for others i recommend writing down what the BCO has approved verbally and any changes or issues raised at every visit. Before he leaves ask him when you should call him back. Then that evening send him an email or letter to confirm what was agreed. You know something like.. Thank you for the visit today which we found very helpful.. Just to confirm you were happy with abcd but require us to address efgh by doing xyz. and would like us to call you back for the next site visit when we have done pqrs but before tuvw. Keep the subject field the same (use your site address?) so its all one thread in his email system.
  16. I'm wondering if the installer wasn't familiar with UFH and someone told him that the best way to run UFH was "continuously" so that's the boiler mode he selected ! Presumably when none of your UFH manifolds or towel rads are calling for heat a bypass opens, the return temperature rises and that shuts off the burner?
  17. I think it's something like this you need but not 100% sure.. https://www.bathroomspareparts.co.uk/grohe-90mm-x-3x22-straight-union-pipe-42766000-10056-p.asp?gclid=Cj0KCQjw2v-gBhC1ARIsAOQdKY1aisc1rZhBeK-rogfTvHe9EwjPeHY9Jr3ylCKkZeYDWm-ux35zhp4aApstEALw_wcB
  18. I'm afraid I agree. I recall a case where PP for a granny annex was granted. VAT on materials for this cannot be reclaimed as its not considered a seperate dwelling. Work started. Then the planning condition precluding separate occupation was removed meaning the annex could now be sold as a seperate house. HMRC argued that only materials purchased after the planning condition was removed could be reclaimed.
  19. +1 Materials you buy yourself you can reclaim the VAT using form VAT431NB. Must file claim within 3 months of completion. There are some restrictions on things not normally included in houses and things that are removable like freestanding wardrobes. VAT on Trees can only be reclaimed if mentioned on a landscaping plan as part of your planning permission. Any labour for fitting those materials should be zero rated to you. Eg if you buy paving slabs yourself you can reclaim the VAT back but the builder should not charge vat on labour to lay the slabs.
  20. There is a big difference between a warranty and an architects certificate. An architect certificate only lasts for a period of 6 years and only covers you against defects in design not workmanship or materials. However it's not clear all warranties cover workmanship either. I recall someone had an issue with their drains blocking regularly and the warranty claimed they worked fine when unblocked so weren't covered.
  21. HMRC forum... https://community.hmrc.gov.uk/customerforums/vat
  22. If they have been used for domestic storage for 20 years it's too late for the planners to take enforcement action so a certificate of lawfulness should be granted. The problem you might have is proving that. Would the buildings be suitable for conversion to houses? If so they might qualify for planning permission under Class Q permitted development. In the right place they could be quite valuable. However Class Q requires them to have been in agricultural use for 10 years. Might be worth taking advice from a planning consultant to maximise the development potential before you approach the planners. Sorry if you know this stuff already.
  23. HMRC VAT forum here.. https://community.hmrc.gov.uk/customerforums/vat
  24. I bought a house with tiled garage floor. Sort of tiles you would put in a utility room. Previous owner had gone in with wet tyres one day and slid into the end wall.
