Everything posted by Dreadnaught
I have received a quote for the design of the drains for my site. I am keen to do this early, well before my project starts, as I can ask for the works in the road done by my boathouse neighbour who is opening-up the road for their own purposes. They may well be willing to do this for me as in return I can give them access to my plot for site storage for the duration of their build. The timing would suit me as I need to go back to planning anyhow so wont be starting until after they finish anyway. I am told that they will be planning their work quite soon so I want to have my drain plan ready so I can hand it to them. At least that is my thinking. Am I going about this the right way? Note that I have already got a detailed survey of the local drains, including cover and invert levels, etc., which was prepared for the boathouse neighbour by this same SE company, and which the boathouse kindly shared with me. Having said that I have all the invert levels, the foul manhole nearest my plot was UTL ("unable to lift") so I do not have that invert level but I have it for the next manhole along upstream. I have been quoted by a local SE firm £1350 + VAT for preparing: (i) a foul drainage drawing showing external drain runs, manhole locations, and levels, etc. And (ii) a drawing showing the below ground surface water drainage for surface water to be discharged in to the adjacent stormwater drain via an attenuation tank. Given that this is the South East, I wonder if there is an SE-premium there? I wonder, does drainage have to be designed by a local firm or can I go to anyone nationally? By the way, must I have an attenuation tank for surface water? My PP does not mention anything about drainage.
- 60 replies
- foul drains
- surface water drains
- (and 3 more)
Hi & welcome. Which is your native language?
Yes. Here's a fitting guide for the Egger boards which mentions that glue. https://www.egger.com/get_download/17e6c5ab-960a-4e7d-99ee-c46608c62f3a/Flyer_Advanced_Structural_Flooring_System_Fitting_guide_UK_2017.pdf Note that the only nails recommended are for the first row of boards only, and one nail per joist. No screws mentioned.
@Garry, if you're interested in Passive House, I found reading Janet Cottrell's Passivhaus Handbook informative.
UFH pipes in the walls, not floor? Silly idea?
Dreadnaught replied to Dreadnaught's topic in Underfloor Heating
Thank you very much @Nickfromwales. That makes sense. Spot on, Nick. I will be working in the coming months on the fate of that tree, be in no doubt. If the tree can be removed then I shall indeed be embracing PV. -
@Nickfromwales, would you ever design electric UFH in bathrooms for its higher temperature and responsiveness in comparison to wet UFH? -
Internal windows in a design?
Dreadnaught replied to Dreadnaught's topic in New House & Self Build Design
I did wonder. I suspect yours is even more colourful! ? -
@Nickfromwales, wow, thank you for your comprehensive reply. That was very helpful indeed. I am learning fast. Quite a lot of that was known to me but not all. As its in a conservation zone, effectively yes (or at least the slap a TPO on the moment you reach for the saw as your required to give advance notice). Thank you. Two people have now shot down the idea of electric UFH. You plus one on private message too. So I am moving on from that idea. The next idea is to use a MVHR post heater for space heating. And, with a unit like the Zehnder ComfoCool, for cooling too. Airflow rates with MVHR is relatively low so heating (or cooling) capacity is also low In mid winter, if more heating is required then the air flow of the MVHR would also need to be increased, with possible problems of noise (whistling) and low humidity (possible to be remedied with a enthalpy heat-exchanger) I think that using the ducting for heating and cooling will require for all the supply ducts to be insulated Duct heating can also lead to a burnt-dust smell Any thoughts? Ever seen such a solution used, Nick? -
@JSHarris, yes. Thank you. I have learnt this from you. Decrement delay: I have rejected EPS beads for this reason and am only targeting frame systems that use blown-cellulose insulation. My design has a very poor form factor, 4.9. Its a bungalow with a flat roof. As I am following a fabric-first approach and passive house, this probably means 450 mm of blown cellulose all around, possibly even in the floor. A benefit of this will hopefully be a desirable decrement delay. Is is in this context that electric mat UFH is appealing to me for space heating. -
True. Terry uses off-peak electricity to store heat in his slab at night, via wet UFH. That heat is then released into his house gradually over the subsequent hours. But with a passive house, I am not sure the slab heat-buffer is needed. A passive house needs so little heating that even direct heating at night using electric mat UFH of a few kW might be sufficient to maintain a constant temperature throughout the day/night cycle even in the depths of winter. Of course I would need to do the calculations but this is my hunch. -
Thanks @JSHarris & @Construction Channel. That's clear then! It goes in the draw labelled Silly Ideas. -
@Nickfromwales, thinking some more, and taking note of what you said about emitters and the wish to maintain a constant ambient temperature across the day/night cycle in the winter, I tried to imagine the simplest solution possible. Assuming a passive house, this is what I came up with: E7 electricity electric mat underfloor heating throughout, which is on at night with E7 Willis heater and Sunamp* for DHW, again charged at night from E7 cooling: install a cheap (sub £1k) air conditioner (otherwise known as an air-to-air heat pump), if needed Strikes me that this hits all the marks. It would not give the SPFH2 gains from a heat pump, nor take advantage of the cheapness of gas. But, my word, it would be relatively cheap to buy and install and low maintenance! Nick, what do you think? * I believe the Willis heater can now be built in to the SunAmp -
Thanks @Nickfromwales. Very interesting and good advice. I only wish I could have a slab! The problem is a tricky site with protected tree roots and a risk of clay heave. The solution looks like screw piling with a void beneath the floor. I am still in the design phase and am hoping things might change by talking to the right SE. Listening to you, I am keen that they will. (Oh and I wont have PV either. I have a whopping (if somewhat sick) chestnut tree slap bang due south and inches from the edge of my plot. I am in a conservation zone. Trust me, I shall be having a close look at this tree). Very good point. I raised the question of decrement delay with Beattie recently but did not receive an answer. I even asked if they would substitute blown cellulose insulation for EPS beads but they said they would not. -
UFH pipes go under the floor but, when linked by a ASHP, they can be used for cooling as well as heating, @JSHarris-style. But… air convection works against the cooling effect at the floor. So wouldn't it make sense to put the UFH cooling pipes in the ceiling not under the floor? Or… is the best compromise for both cooling and heating is not put them in the floor or ceiling but in the walls instead? Is this a silly idea? (I thought of this because, in my build, I may not have a concrete slab and have an insulated timber-frame floor instead. It strikes me that it could be just as easy to put the pipes in some of the internal walls as it is it put them on the floor.)
@jack, wow, spectacular! -
Oh interesting. What was your motivation? Did that one bedroom not have much external light? -
Oh that's a clever idea, and most encouraging. -
What do people think about internal windows in a design? I have large plate glass floor-to-ceiling window on one side of a corridor which could throw light into a bedroom on the other side of the corridor if I put an internal window. That internal window could perhaps be high up (I have 3m ceilings in that area). Its also worth mentioning that that bedroom has no other windows other than roof lights. I am slightly concerned about sound ingress with internal windows. And whether they can be made to look any good. Anybody have any internal windows in their design? What do you think of them?
Mocking up a Kitchen island
Dreadnaught replied to ToughButterCup's topic in Kitchen Units & Worktops
Its perhaps worth considering that that those USB-A sockets may well be obsolete in a few years time. I personally wouldn't install them now. USB-C is on the way (for all my bits and bobs at least). -
From wonky shelf to self build in deepest Cambridgeshire
Dreadnaught replied to Lots2learn's topic in Introduce Yourself
@Lots2learn, lets organise that. PM inbound. -
Why would you want to pre-warm the air through the ground? @JSHarris points are well made. An alternative if you can really justify the expense might be a brine loop system? But as you are going for a near passive house levels of insulation, your heat demand will be very low so I suspect you wont be able to justify the expense.
@Lots2learn, oh I am interested in how Bartram will make a frame for a PH. Looking cursorily at their website they give the impression that most of their frames are not for PHs. On my list is MBC, PYC and Touchwood but I am far from making a final decision and am interested to learn from your example. While not going for certification, are you going to model your house in PHPP? I have a first model for my design and I found the process revelatory. Recommended. -
Another week comes to an end
Dreadnaught commented on recoveringbuilder's blog entry in Recoveringbuilder
@Christine Walker, I will be following in your footsteps, quite some considerable distance behind. I have read all your posts with careful interest. I too will not doubt have times when its hard to see the end. I am rooting for you! -
@Lots2learn yes I do have PP but I am going to go back to vary it, so I wont be breaking ground until the next spring at the earliest. Bartram is new to me. Looking now. Nearby I see. How low-energy do you plan your build to be on the spectrum between building regs at one end and passive house at the other (I plan to be at the passive house end, myself).
