TW9
Everything posted by TW9
If you want to manage the electricity used by heat pumps you wouldn't do it by cutting all the power. That risks causing all sorts of problems. You'd do it by remotely connecting to the controls.
Heat pumps won’t work in old homes, warns Bosch
TW9 replied to Temp's topic in Air Source Heat Pumps (ASHP)
It seems to be mostly oil companies promoting hydrogen, not environmentalists. -
Different chemicals depending on the time of year? Red flames for Christmas. Green for St Patrick's day. A cheery yellow in summer. -
Energy Catapult showed that heat pumps can work in all types of property (assuming there's space to fit one) - https://es.catapult.org.uk/news/electrification-of-heat-trial-finds-heat-pumps-suitable-for-all-housing-types/ The Fully Charged Show did an episode on hydrogen. The expert they talked to explained why hydrogen is not a good option in pretty much every situation (particularly home heating) - https://youtu.be/MgmBkvrO0Dg -
We use it. We shift as much load as we can into the cheap periods (water heating, washing machine, dishwasher, car charging). We also adjust the settings on our battery to limit our use of the grid during the expensive period. Our heat pump is controlled by a Tado so we have made small adjustments to the timings to try and push use away from the peak period. It's harder to do this with most heat pump controls. Without an EV or a battery I think you might struggle to save more than pennies. If you're already on Octopus there's an app called Octopus Compare that tells you how much you would pay each day on different tariffs. So you could see if it's worth going for without actually moving it.
I read that as a 12kW hybrid inverter with 11.6kWh of batteries. No solar panels.
Combined community and household PV and battery storage
TW9 replied to Stones's topic in Photovoltaics (PV)
That's a recipe for neighbourhood discontent. There will be arguments about who is using more than their fair share. -
Yes, it's normal for the tank to gradually lose heat. How much it loses will depend on where it is and how well the pipework is insulated (I'm assuming it's a modern tank with built in insulation so there isn't much you can do to improve that). We heat ours to 50 degrees, which is hot enough.
Efficiency - help required for an amateur, please!
TW9 replied to EdieCampbell's topic in Air Source Heat Pumps (ASHP)
I suspect the radiators aren't able to put out enough heat because they're too small. Did you have a heat loss assessment done on the house before the heating system was specified? This will tell you how much heat each room needs so you can check this against the radiator specifications. Make sure you check the spec at the correct flow temperature. -
https://www.ebay.co.uk/itm/203546625381?hash=item2f64530565
One thing to add to Nick's excellent advice, the application you need is a G99 (not a G98) as your inverter is over 3.68kW. It doesn't matter that it's export limited. As Nick said, this has to be approved before connecting the system to the grid.
Ecodan heats water only to 39C with heat pump
TW9 replied to FrankG's topic in Air Source Heat Pumps (ASHP)
My Ecodan heats to 55 degrees so there's no reason yours shouldn't be able to. What happens when you try to increase the temperature on the controller? -
Is it possible for PV diverting the opposite way round
TW9 replied to Gone West's topic in Photovoltaics (PV)
What would happen if you put the CT clamp for the iboost on the inverter output? Would that result in the iboost attempting to divert to the immersion whenever you're generating electricity? The immersion will take as much of the solar electricity as it can leaving the rest to go to the house. Or is that utter nonsense that won't work? -
How would you avoid DNO approval? I thought as soon as you connect any generation to the grid they need to know about it.
Unless you build a system that is entirely off grid you can't avoid DNO approval. The DNO are interested in the export capability, not in what it actually exports. So if you add more panels on a separate inverter and/or a battery they need to know.
The increase in energy prices has made solar PV much more attractive so all installers are really busy and there's a shortage of equipment. Our installation is scheduled for the end of September as the installer is booked up until then. I've got my fingers crossed that the panels, inverter and battery will be available.
We have Mira Platinum showers that can be set to run for a limited time. We don't use this setting at the moment but it will be switched on if my daughters start having half hour showers.
I assume you mean whatever is triggering the lights on the front of the Sunamp that show how full it is? They're still there... at least they are on ours. There are only four of them so it doesn't give a detailed view of how charged it is but it's better than nothing. They're only on the electrically heated Sunamp. For the others you have no way of knowing how charged they are.
There are V2G trials underway, using Nissan Leafs (leaves?) and Indra chargers. It's managed by the Kaluza platform.
ASHP with large thermal store (for load shifting)
TW9 replied to apesort's topic in Air Source Heat Pumps (ASHP)
Yes. They phase change at 45 degrees which is fine for a heating system. -
Have you considered heat batteries instead of a tank of water? We have two Sunamp heat batteries that are used for this purpose, storing about 18kWh of heat. -
We have them. Climaveneta i-Life2. They work well but aren't perfect. There's hardly any mechanical noise but you get the noise of air blowing through the vents. It isn't very loud and we got used to it quickly. You have to clean the filters every few weeks, which I do when vacuuming the house. They don't start up until the water temp is 30 degrees so it you're running a low flow temp and the rad is near the end of the circuit you might have problems. You should be fine with a 45 degree flow temp but it's something worth bearing in mind. The controls aren't great although once you've managed to get them set as you want you can mostly just leave them alone. The biggest problem is the cost. They're about £600 each. I did see someone on one of the Facebook heat pump groups selling their i-Life2 rads so you might be able to pick one up for less.
ASHP is the power of the water pump enough for the radiators?
TW9 replied to keyser's topic in Air Source Heat Pumps (ASHP)
I have four circulation pumps on my system. Is that too many? 😁 -
Our Ecodan doesn't draw 200w constantly so I suspect you've got a fault or something has been set up incorrectly.
You're right, if you leave the doors open there's no point in using TRVs. In fact it can reduce your heat pump efficiency. Heat Geek explain why in one of their YouTube videos.
