This is more a job for air conditioning rather then MVHR. MVHR works on the little and often principle.
Does it really need to be perfect?
Can't you just get a USB wireless adapter?
That is because they are. Just a matter of where you stand really.
Any chance it is just getting hot. Stopping for a minute or two while dealing with the faulty firings may be enough to cool it a little. Or it could be the nails, have a good look at the next batch.
Not talking alcohol induced, more running around a 40°C commercial kitchen for 6 hours. Trust me, you sleep after that.
Can you design the house so that the ES is, initially, separate from the bedroom. But in the future a new doorway can could be fitted to connect the two. Or do what I do, work before bedtime, then I am a little dehydrated for the night, and tired. I sleep quite well because of this. Mornings I get up early, tea and fags for an hour or two, then shower/bath. No one is disturbed. Living alone is the real answer.
That will be the glass ceiling then, well until it is shattered.
Your Home Base Load / Background Power Draw
SteamyTea replied to MrMagic's topic in Photovoltaics (PV)
@JSHarris I was actually thinking that these could do the donkey work and something very low powered would sit on desk. It seems a shame to have loads of low power, but powerful computing and just run a simple task or two on them. -
What is the standard deviation, i.e. does it happen a few times in a row, begining of nailing, towards end of nailing session, or apparently randomly.
As most if these small, but powerful, computers probably have a spare bit of capacity, how well would they work with thin clients (term may have changed now to Cloud something or other). Be a lot less clutter on my desk to have just a monitor and keyboard. Easy to move too. -
You should at least know how much DHW energy us needed. Wind direction and speed have a big affect on performance. Strong South Westerlies are warm, week Easterlies and Northern winds are cold, and in winter there is little solar gain to be had in the 6 or 7 hours of daylight.
You can always fit PV at a later date, though it need not cost more than a tiled roof. Again, parts can be self-sourced. 300 m² is a big place, about 6 times the size of mine. So without a lot of insulation under the UFH and perimeter, you stand to loose a lot of energy. Is it realy any cheaper to fit radiators upstairs, rather than UFH into the floor? You can use a different spacing for the pipes to limit the energy transfer. Have you done the heat loss calculations and DHW usage yet?
Going to be hard to gauge the effectiveness of any ASHP over the late spring and summer months. Do you collect external weather data?
02/09/2019 09:03, 17.125°C Full day off as well. Bikini weather.
Bifolds : Solar gain vs heat loss
SteamyTea replied to Benjseb's topic in Energy Efficient & Sustainable Design Concepts
May be worth improving the walls with some extra insulation it it is possible. -
What is the effect of EPC changes?
SteamyTea replied to Ferdinand's topic in General Self Build & DIY Discussion
Is that total emissions (absolute), or CO2/kWh emissions (relative). -
Gravenhill Solar Gain Factor 0.5-0.7 in Design Code
SteamyTea replied to Ferdinand's topic in Boffin's Corner
Are those building codes really any better than basic building regs? -
Not sure how no increase in temperature can shorten then heating time from the AEHR. If the equipment needs cooling, cool it with a fan, don't over complicate it. Energy scavenging is not really worth the effort. https://www.newscientist.com/article/2186721-green-car-tyres-can-generate-energy-while-monitoring-road-conditions/
Sounds like this is heading for prorogation.
Any Carrier unit. Many are rebranded. Also the Japanese ones are good. I keep banging on about this, but look at CO2 ones as the current generation of refrigerant gasses are being phased out, so long term servicing may be a problem. Not that they should leak gas.
