SteamyTea
    200
  1. If you swap a 60W light bulb for a 10W LED one, you are reducing the power draw to 16%, call it 20% to allow for naff transformers. Now say you had 30 60W bulbs, that would be, if they are all on together, 1.8 kW, but the LED will be 0.3 kW a 1.5 kW difference, or about half the power a kettle draws. Keep things in perspective. If is a rare day you need anything like that sort of power, anywhere. Unless you like burning everything. I have never understood why people by high power hobs, the skill is in not burning your tea. If you need to boil a large pan of water fast, use the kettle, they are better at boiling water.
  2. And quite possibly a pure sinewave, so a more expensive inverter. Like a PV system, a wind turbine will only give the rated output when the conditions are right i.e. 800W, direct beam for solar, 20 m/s windspeed for a turbine (or whatever the production curve is). This is why battery storage is used, it can soak up all the smaller generation packets and store them for later. So a larger battery would be needed ideally. It eventually get to the point where thermal storage becomes cheaper i.e. in water, and then just pump that about.
  3. Yes, or hotter. If ceiling mounted radiant heating worked, we would all be doing it. There is also the distance from the radiant source to take into account, though at a couple if metres, this is not generally significant, and the object you are trying to heat, which may have an exposed surface area many times smaller than the emitter. Also, humans breath, so regardless of the person's surface temperature, if they are breathing in cold air, they will be cooling.
  4. Give it a go and then tell us you you think it is not a good idea.
  5. I just went to sleep, better use of night time.
  6. Some people have found that there is no wayleave agreement when cables cross their land, then use that as a bargaining point. Also try to design out the need for such a large load, PV and battery/thermal storage can reduce the peak power considerably.
  7. I can forgive students at first, why they came to my lectures. By showing how the units are derived explains so much. But when it comes to energy (heat in old money), we should really use joules, it makes so much more sense.
  8. Have a look at air to air heat pumps. Quick search found this. https://www.aircon.panasonic.eu/GB_en/ranges/domestic/ You can also get multi spits. https://www.appliancesdirect.co.uk/p/iqool-3ms9k9k9k/tcl-iqool3ms9k9k9k-air-conditioner
  9. That is a bit of a sweeping statement. I was very impressed with the effects that Monodraught got from their sunpipes. Slight disclaimer, I had done some work with them in the past.
  10. That works out at ~18W/m2, which does not seem excessively high for an old place. (it is late and I may have made an error) But it is still ~160 kWh/m2.year. A quick google shows this. https://www.ovoenergy.com/guides/energy-guides/how-much-heating-energy-do-you-use.html UK average seems to be about 133
  11. How big is the place (m2), how much DHW do you expect to use (litres/day), is it detached, semi, terrace, number of stories, is the loft converted to a habitable area? Does it use 34,500 kWh/year (~35 MWh/year) (kW is power, kWh is energy, kw is a nonsense unit, as is kwh, kW/h, KWH). It may seem a bit snobby and pedantic mentioning the units, but apart from the odd type, if you get a quote that is incorrectly mixing SI units, consistently misquoting derived units, and the worse, mixing SI and Imperial units i.e. kWh/square foot, be very wary of the company.
  12. Yes, very important, especially if you look at Carrier, or rebadged Carrier units. Seems a reasonable price, what power it it?
  13. Used to live just up the road in Abbot's Langley. Had some nice times in the grounds if the Abbey, especially when they had no traffic wardens in the area.
  14. I think that is a great idea. Nothing to stop you moving a lot of air through it as well. Just need some filters to catch the bits. A couple of fans, set at an angle to each other, could move tonnes of air almost silently. I think this idea needs exploring more. Where in Herts are you?
  15. Yes, but we are getting a new one. And not an old Channel Ferry design this time. It is because it is to do with the person, not the vessel. It is a mismatch between what the senses say, and how the body reacts to it. Prone to motion sickness? Your sex, diet and shoe size may be to blame We are finally solving the mystery of why motion can make us queasy – just in time to help us deal with nausea-inducing VR headsets, driverless cars and space tourism HEALTH 19 August 2020 By Helen Thomson Somsak Bumroongwong/Eyeem/Getty Images; Neyro2008/Getty Images IT STARTS behind your eyes, a niggling ache that heads down towards your stomach where it tumbles and turns before building towards a climax of vomit. Bleurgh! Motion sickness. This has been a human affliction pretty much since we began travelling on anything but two legs. Most of us have experienced it, and it is likely to become even more prevalent when we all become passengers as driverless cars roll out, space tourism takes off and virtual reality headsets take over, both in the gaming industry and, increasingly, for virtual meetings. Even before covid-19, environmentally conscious businesses had started adopting VR technology to bring international clients together. Motion sickness is clearly related to the movement of our body and head, but why this results in nausea has been a long-standing mystery. Now, however, evidence from brain imaging and genetics is helping scientists get to the bottom of it – as well as suggesting new ways to solve the problem. It turns out that there is far more to motion sickness than you might think. Your genes, gender and diet all have an influence. It might even come down to your foot size. The word nausea derives from the Greek for “ship”. But motion sickness goes way beyond the odd queasy sailor. Seasickness has had a big impact on history, influencing the outcome of several military conflicts, from the battle of the Red Cliffs, which marked the end of the Han dynasty in ancient China to the defeat of the Spanish Armada by the English in 1588. And, of course, motion sickness isn’t confined to the high seas. There are reports of ancient Greeks and Chinese feeling nauseous while being carried aloft in Sedan chairs or travelling by horse and buggy. Their solutions included fasting, drinking the urine of young boys and hiding earth from the kitchen hearth in their hair. Today, there are more ways to induce motion sickness than ever. One in three of us easily succumb, another third will experience it in rough seas or on a roller-coaster. Nobody is completely immune. We aren’t the only species affected, either: cats, dogs, even a variety of birds and fish feel it. In fact, the only animals that don’t are those without a vestibular system. A new idea about motion sickness can explain why car passengers are more likely to feel nauseous than drivers Imgorthand/Getty Images/iStockph This gives us our first clue as to what the cause might be. The vestibular system is a delicate assemblage of structures within the ear that detects motion (see diagram). It includes three semicircular canals filled with fluid that sit at right angles to one another. As the fluid sloshes around, the system sends signals about rotational movement to two places. The first is the brain’s cerebellum – the region responsible for balance and movement – and the other is the brainstem, which links the brain to the rest of the body and includes areas that trigger nausea and vomiting. The vestibular system also transmits signals to the eyes, which stop the world from blurring as we move our head. Early ideas about motion sickness put it down to overstimulation of the vestibular system. However, if that were true, why would sailors experience nausea after returning to land? Why don’t we suffer motion sickness when jumping around on a dance floor? And why is the driver of a car less likely to feel sick than the passengers? Attempting to address such anomalies, a second idea posits that motion sickness results from conflict between different kinds of sensory information. When you read in a car, for example, your vision of the book and the dashboard tell your brain that you are stationary, but with all the bumps and turns, your vestibular system is convinced you are moving. These conflicting signals make it difficult for the brain to create a coherent sense of balance, which triggers nausea. Something unexpected This “sensory-conflict” idea has problems, too, however. If a novice and a seasoned sailor stand on the same deck, for example, they receive the same sensory signals but have different levels of nausea. There is a third possible explanation for why. Rather than resulting from conflicting signals between your eyes and ears, this idea frames motion sickness as a conflict between these signals and what your brain expects to happen. This is the idea embraced by Charles Oman at the Massachusetts Institute of Technology. In 1990, he argued that when you make a movement, your brain subtracts the actual sensory input from the expected pattern of neural activity, and what’s left is a “sensory-motor conflict signal”. This is generally small, but it spikes when an unexpected obstacle or motion is encountered, resulting in a corrective response from the brain’s motor systems. You then rebalance yourself and the conflict is extinguished. However, if the conflict signal is stimulated over a longer period, it triggers motion sickness. This would explain why we don’t feel nauseous when we jive around a dance floor, but do when we are swayed by high seas. It also explains why sailors get motion sickness on dry land – their sensory expectations don’t fit with the stable environment. It even explains the mysterious immunity bestowed on the driver of a vehicle: being in control gives you more accurate expectations of your movements. There was just one problem with Oman’s idea – nobody could find evidence for it in the brain. The required network of neurons was missing. “Why don’t we experience motion sickness when jumping around on a dance floor?” Meanwhile, Thomas Stoffregen, now at the University of Minnesota, had another idea. His research, measuring the subtle movements that people make to maintain their balance at sea, led him to believe that an inability to control our posture is to blame. His studies also indicated a simple solution to motion sickness: when sailors increased the width of their stance, making them more stable, they felt less nauseous. Ginger stimulates the vagus nerve, which may explain why it can reduce nausea Getty Images/Design Pics RF The debate looked set to continue. Then, Kathleen Cullen, now at Johns Hopkins University in Baltimore, inadvertently discovered Oman’s missing neurons. Her team had trained monkeys to move in a specific way to get a treat. Occasionally, the researchers would disrupt this movement – by placing a weight on top of the animal’s head, for instance – causing a mismatch between the animal’s expected and actual head motion. When this happened, there was a spike in the activity in some neurons in the cerebellum, cells that didn’t seem to be active when the animal generated its own movement. “It suggests that the cerebellum can perform this amazing computation within a millisecond, in which it compares an internal model of sensory expectation based on prior experience with actual sensory information,” says Cullen. Now her team has shown that when an animal subsequently adapts its movement, the internal model is updated and the neurons stop firing. “I was startled when I saw their work,” says Oman. “These neurons arguably play the critical role in motion sickness.” But one piece of the puzzle is still missing, he says. Neurons are known to project from this region of the cerebellum to areas of the brainstem that trigger nausea. “It would be a clincher if we could establish that they are the same neurons Cullen’s lab has been studying,” he says. Despite this progress in understanding motion sickness, questions remain about why some people are more prone to it than others. Why, for example, do female sailors seem more likely to be affected than male ones? And why do women, especially pregnant women, consistently report more symptoms of motion sickness during VR experiments than men? One possible explanation for this sex divide rests on a decades-old idea about why motion sickness exists at all. Vomiting is a handy reaction to ingesting bad food, but what is the purpose of being sick in reaction to movement? “Motion sickness is so physically disabling that if there were no positive reason for its presence, natural selection should have acted strongly to eliminate it,” says Michel Treisman at the University of Oxford. Such thinking led him to suggest that it is a side effect of our robust reaction to poison: the network involved in keeping us balanced is an ideal early warning system for detecting the unbalancing effects of toxins. Unfortunately, anything else that makes us unbalanced has the same result. If so, it would be beneficial for women to have a lower threshold for motion sickness so that, when they are pregnant, the fetus has increased protection from toxins. It’s in the balance Stoffregen’s research suggests another explanation for why women are more prone to motion sickness than men. “They have different distributions of body mass,” he says. “Women carry weight lower in their hips and have smaller feet even when compared with men of similar height.” As a result, women may be less physically stable, he says, so find it harder to balance when faced with unexpected movements. Genes also seem to play a role. In 2015, consumer genetic analysis company 23andMe conducted the first genome-wide study on motion sickness in some 80,000 people and found 35 sections of DNA associated with the condition. The genes involved are related to the development of the eye and ear, and to glucose regulation – women who have particular versions of them are up to three times more prone to motion sickness than men who have them. How the genes influence motion sickness isn’t known, but people who experience more motion-induced nausea tend to have lower levels of insulin than those who don’t get sick. Because insulin helps us stabilise glucose levels in the body, the researchers suggest that stabilising glucose through your diet – by eating plenty of vegetables, fruits and whole grains, for example – might help to keep motion sickness at bay. “Why do women report more symptoms of motion sickness in VR experiments than men?” Closing the case on what causes motion sickness and why some people are more susceptible might lead to new pharmacological targets. Currently, the most effective drug for it is called scopolamine, which works by blocking chemicals that transmit information from the vestibular system to nausea centres in the brain. However, it can cause dry eyes, drowsiness, headaches, palpitations and urinary retention. Antihistamines work too, and probably in a similar way, but they also have side effects. Regardless of what might be making you susceptible, there are other things you can do to reduce sensory conflict that leads to nausea. Oman recommends staring at the horizon to help synchronise visual information with motion, and keeping your head and body as still as possible to limit unexpected external forces. “Soldiers flying in transport planes found that strapping their head against the seat reduced their sickness,” he says. Habituation training also works. Just as sailors eventually get their sea legs, so prior exposure to the sorts of motion you are likely to experience while travelling can reduce your chances of becoming seasick. Few other traditional remedies have been tested. “Some people swear by things like pressure bands [worn on the wrist],” says Oman. “There’s no good evidence for them, but any clinician will tell you that placebos can be useful.” There is evidence the placebo effect alone can reduce motion sickness. “When I meet sailors who swear by these things, I say ‘if you believe in it, do it’,” says Oman. Some ideas do have a little evidence behind them. Studies suggest that ginger can reduce nausea during pregnancy and chemotherapy, and although the jury is out for motion-induced sickness, ginger activates the vagus nerve – which runs between the brain and gut and controls aspects of nausea – and there is evidence that vagal nerve stimulation can reduce motion sickness. Adam Farmer at Queen Mary University of London found this when he fitted volunteers with an epilepsy device called NEMOS – an earphone containing two electrodes that stimulate the vagus nerve as it passes behind the ear. Another way to stimulate the vagus nerve is by breathing slowly and deeply. This simple measure has been found to successfully decrease motion sickness. Standing with a wide stance and staring at the horizon are two ways to reduce seasickness piola666/Getty Images The latest idea is a wacky-looking pair of glasses, which are claimed to stop motion sickness in 94 per cent of users. “Seetroën” spectacles, produced by carmaker Citroën, feature four rings – two framing the eyes and one at each side of the head – half-filled with a coloured liquid. “The liquid moves in the same way as the liquid in the inner ear,” says Antoine Jeannin, CEO of Boarding Ring, the company that developed the glasses. “It’s like a visual inner ear, which helps reduce sensory conflict.” Jelte Bos at Vrije University in the Netherlands thinks it is a nice seasickness idea. But the glasses only give information about two of the three planes of motion, he adds. “So I’m a little bit sceptical,” he says. In future, the best solution for motion sickness might not be a pill or ginger or a pair of special glasses. There is a growing realisation that we need to improve the technologies that make us nauseous in the first place (see “Sexist technology”). “We don’t design the oceans, but we do design VR and driverless cars,” says Stoffregen. “We can’t be held responsible for seasickness, but we are damn well responsible for the technology we create.” Sexist technology Motion sickness is predicted to become more widespread with increasing use of nauseainducing VR headsets in gaming and for business meetings. Part of the problem is their size. Bas Rokers at the University of Wisconsin- Madison has found that the lenses on the average VR headset are too far apart to work properly for the eyes of 5 per cent of men and 90 per cent of women, and that this results in greater risk of nausea. “The technology is sexist,” says Thomas Stoffregen at the University of Minnesota. “VR can be up to four times more nauseating for women.” Even a perfectly fitting headset can cause queasiness. This needn’t be a “necessary evil”, says Rokers. The technology could identify when users start to move their head more – a sign that they are starting to feel sick – and pause the game. It is also possible to help people adjust to the cues that make them nauseous by introducing these more slowly. The easiest solution is to get rid of the most nausea-inducing aspects of an image altogether. Unfortunately, this involves reducing the image contrast. “The irony is that this makes the display worse,” says Rokers. “It creates a tension between the engineers who want to make things look as good as possible, and the vision scientists who want to make VR more tolerable for more people.”
  16. Just had a quick read of the wikipedia page about it. https://en.wikipedia.org/wiki/Basalt_fiber Seems to be used in a similar way to glass fibres. The thing to look up, in my opinion, is what the mesh is mixed with i.e. binding agents, coatings, water repellents etc. Some fibres have proved very hard to process, so a Silane coating is added, this can, depending on the chemistry, be a help or a hinderance. Chemists can sometimes be quite clever and design polymers that have one end that is attracted to a material and the other end that can be attracted to another material. But as a clever Dr. of Chemicals I worked with once (actually worked with 3 in the past, all a bit weird, well one was just Scotch) said, 'you get the properties you want, and something else'. It is that 'something else' that catches us all out.
  17. Yes, not conclusive, but it is a hard sell to customers when you turn up with a drill and a foot diameter hole cutter. No it isn't. A silver roof is, or failing that, there are now some paints that are dark but still reflect a significant amount. PV on the roof is the obvious solution. That will suck out 20% of the energy on a good day, just in electricity, and a fair amount by reflection, depending on the angle of incident.
  18. Mate of mines company tried that, got close to freezing as there was not enough airflow. MVHR is better, and cheaper. Or an exhaust ASHP.
  19. Seasickness is not a function of boat size. Ask everyone that has taken the ferry to the Isles of Scilly. Like a narrowboat, it is shallow draft, so rocks in a peculiar manner. You can make simple stabalisers for when you are moored up. Just metal dustbin lids in a rope tied to the side. Or a very large gyroscope, which can also store energy.
  20. I had heard of it, may have to do a little research when I get time. Holiday season now so not got much free time.
  21. Yes, only seen the plug in ones in the USA. But the do jiggle 20% faster. Is this the space flight conversation?
  22. I am a bit of a fan of simple gravity fed systems. I agree that my shower pump is noisy, but it is a retro fit, and only cost 100 quid. All this talk about fitting this and that to boost flow (pressure is rather irrelevant, not much flow in a jet wash, but you don't want to shower under one), rather reminds me of those Heath Robinson contractions. Aims and Objectives. Decide what you want, then work backwards, it is how man got to land in the moon, and return safely.
  23. Not really. Can be a problem with just a few millimetres. There is also a problem with different shrinkage rates between the side that is in contact with the mould, with or without a gel coat, and the side exposed to the air. It was a serious problem with Carbon and Kevlar fibres in the early days, part of the reason vacuum bagging was developed. But if you lower the pressure too much, you get greater evaporation and that changes the chemistry of the resins. I used to know a guy at Sheffield University that was very knowledgeable about concrete, we used to call Ewan, Dr. Cement. The place I did my apprenticeship at made material testing machines, was always fun watching then push, pull, shake, cycle, freeze and bake stuff to destruction. When I went back to university to start my Masters, one of the older lecturers asked if I was Mo or Joe (an Instron joke), he knew his stuff and was over excited to meet me. Material testing people are a bit strange.
  24. My water and sewage costs about £8/cubic metre. City of London costs £1.10 Their shit can't smell. Please don't bring dogs to Cornwall, I am paying to clean the mess up.
