SteamyTea
    198
  1. I use low power devices. Phone lasts me a couple of days, tablet a week. The only things that are permanent plugged in are radios and laptop, both low power devices, oh, and the energy monitor/weather monitor. I monitor my power usage and it is not unusual to have 50%, which amounts to several hours a day, when my house is drawing no power at all. It is all about management, not the number of sockets.
  2. Need to know all the relevant wall floor, roof/ceiling (depends on roof construction), door and window areas, along with the associated U-Values. Then it is just addition and multiplication.
  3. But you can import on the cheap (sometimes with a variable tariff). So just get some dedicated circuits i.e. washer/dryer, hot water, persecution chair, and wire them off the batteries.
  4. Isn't that just down to storage, rather than power delivery though.
  5. They grow like weeds here. One is even growing in the planter I temporarily (8 years ago) put some bamboo in.
  6. That is because you use Apple products. They are made for artist to do colouring in. Real people use a proper system.
  7. SteamyTea
    I am done
    I will miss you
  8. Check on AirB&B and see what other services are offered. Or maybe on Bonking.com
  9. The pipe spacing is about power delivery, not energy. The only problem with wider spacing would be if you had to run at a higher temperature, increasing losses to the ground, or required a faster slab recharge time i.e running on an E7 time window.
  10. And the heat loss calculations for each room, along with the power of the heat source.
  11. Should that be the other way around in Australia and South Africa.
  12. Turn till loose, then back half a turn.
  13. That was marketing/PR hype. I seem to remember reading that a mobile network base station used 5MWh/year. Not sure if I remember it right as that works out at just under 600W. A small microwave oven.
  14. No. You are a (expletive deleted)ing useless twat with too much time on your hands.
  15. Off you go then, you know how to do it. I am not your secretary.
  16. Not possible to do as it depends on the make and model of ASHP, and the duty cycle. But if you have some unique inside numbers, post them up. No. Hardly an 'edge case' if it is constantly frosting up is it.
  17. I am really not sure. Common sense say fan blows same way as wind, but it may cause over speeding of the fan (though I doubt it). I would have thought that there is really little difference, and putting the ASHP in a sheltered position is best, but not shaded as that may encourage mould to grow. Shall have to see if I can find any north facing ASHPs and see what they look like.
  18. I did that about a decade ago. Just for my location though. Basically A NE wind, gentle, colder, but sunshine, SW wind, strong, warmer and cloudier
  19. Until the direction reverses. I suspect that if the ASHP is close to a house then the windspeed is significantly reduced, especially at ground level.
  20. apologies to @ProDave, @Nickfromwales and others i've forgotten, i do wish sparkies and plumbers appreciated this prior to renovations Did they drill holes, willy nilly, in your joists and beams. They are given a book that tells them what they are allowed to do. @Gus Potter If you are up for it, I may start a thread about something structural I was thinking about as I did the long drive back today (was even longer as there was a 'jumper' on the M5 with loads of rubber neckers on my side of the road.
  21. OK, here is how it is proved. Sit in the shade with a thermometer and take several air temperature readings, then sit in the sun and do the same, but make sure that the thermometer is not affected by sunlight. Or, tell me how an ASHP can only take air from a shaded area, when it shifts several tonnes of it a day, how can it 'know' that it is in the shade, and the air it is drawing is in the shade. Air has a habit of moving about, luckily. Also, how do ASHP perform effectively at night? Not as if the CoP drops drastically. Also, the metal case would only hold a few kJ of energy, hardly a measurable amount, especially as the external heat exchanger has refrigerant gas expanding into it at about -23°C. Do you actually know how an ASHP works?
  22. 108 m2. Makes a volume, after insulation, of around 275 m3 My house, 48 m2 and 240 m3 I fancy one of these.
  23. Has the 30 minute time limit been lifted then?
  24. Link don't work. But I will add that a CO monitor is important.
  25. Wish us 'ordinary' contributors could do that. Main reason I have never bothered with a blog. Be alright when @pocster becomes a moderator, then a simple bribe, or blackmail, will get anything we like posted up. Good to know that the old RPi is still chugging along. I left one logging at @joe90's some years ago, the 'sister' one at mine has been very reliable.
