SteamyTea
    200
  1. Me to. Got to get it done before the new age verification restrictions.
  2. Looks like Internal Wall Area. So the external walls, but measured on the inside. Ignore that I posted above.
  3. Walls that do not touch the outside. I have never filled it in, may have a look later and see what terminology is used.
  4. Fill out what you can, then loo up what you can't, then ask when you get properly stuck. Most of it is fairly obvious.
  5. Dirty bugger. But yes, that as well, once.
  6. I forgot about the water, so a 10 kW seems about right. would still get someone to do a proper room by room heat loss calculation. You can download the MCS spreadsheet and have a go at it yourself. On this page under Heat Pumps https://mcscertified.com/standards-tools-library/
  7. Back to resistance heating at 30p.kWh-1. He will have to put the price up in the rented rooms.
  8. I did, well the insurance company did, and gave me £2,500 extra for my pain and time off work. But Abbey National took me to court for unpaid mortgage. Compensation was so different back in the 1980s.
  9. Must have misread it, though it was a max heat load of 7.9 kW. Ah, add water.
  10. ABS? Airbags I had a serous head on in my 205, then got rear ended. Only 2 months in hospital and another 6 recovering. Now, 36 years later, the aches and pains in my neck are getting really serious. But it crumpled like it was meant to and saved my life.
  11. So the HP has almost doubled in size. And almost doubles in size as well. Get someone in that knows what they are doing.
  12. True. Have you called a few MCS companies to come and give you a quote?
  13. So would I be, my heating energy for yesterday, divided by my total floor area, works out at 15W.m-2. And my house is over 30 years old.
  14. Not our windscreen, so boiling will work.
  15. If we all have PV, and no batteries, and managed to generate around 150 GWh/day, electricity prices would be cheaper. But if we all stored that energy locally, they would be higher.
  16. We can use something similar when this latest installation is fitted and rattling like @Onoff's Peugeot. Shall I start the topic now, or wait till later.
  17. Did that quip a year or two back.
  18. Off you go then, see you when you have done. I think there is something on there about share of bills. Just reading a book about Oil, by Vaclac Smil. Interesting how governments have raised more money on oil company taxation than oil companies have made profits.
  19. Does Locktite reduce noise? Suppose it can on a wheel nut.
  20. does that take into account we use less, and meter rental? Adding 15p a day to rental is quite steep, £55, on £110.year-1, no need for it to change at all.
  21. Penzance is end of the Great Western Line.
  22. You are not going to get a frosted up system at night as you always turn the system off then. You will get a cold house, so you will be fighting that battle later.
  23. Yesterday, I drove past the National Aboretum. https://www.forestryengland.uk/westonbirt-the-national-arboretum
  24. Have you looked into roof integrated PV? If your angles are right, fairly cheap alternative, and you get some power from them.
  25. I worked for a company that was one if the few independent places that was allowed to reproduce the Coke red without prior checking. Odd as I was half blind with misted cataracts from all the excessive UV exposure I have had. Colour matching by eye is fun, I can copy almost anything, Lovejoy would be proud.
