Will I be eligible for ASHP Grant?
SteamyTea replied to richo106's topic in Air Source Heat Pumps (ASHP)
Yes, covers upgrading from an open fire, or rubbing Boy Scouts together. Think the latter us now covered by other legislation. -
Yes, my car is more economical at 65 than at 30. Why I jump red lights.
Hybrid inverter for small in roof 2kw array - help please!
SteamyTea replied to Timmyk's topic in Photovoltaics (PV)
If it is physically connected i.e. NOT off-grid, then yes. It is a safety thing, the DNO can physically check that all generation is off. It is why you have to tell them where the isolator is physically located. -
Was his name Owen.
Yes, it is not bad, not are surefooted at my old 309s. And nowhere near the grip in the wet. It does have an A2AHP in it, just to get the thread back on topic. -
I often upgrade my thoughts and opinions. Not as often as I downgrade them though. In my mind, I have upgraded my car to a Porche, in reality, it is a rattle C-Max (which is in the garage at the moment to cure the rattle). Reality kicks in when I take a corner too fast. -
Neighbour being rather ridiculous/arrogant
SteamyTea replied to hendriQ's topic in Party Wall & Property Legal Issues
I thought it was 'high fences make for good neighbours'. -
Sound all very expensive.
Get your university to pay for it, or you will be living in a cabane in the Bois de Fontainebleau.
Not at all, I like that idea. I have a mirror hanging on my neighbours fence. It reflects light onto the back of the bamboo, where an echium if growing. -
That is a brilliant idea. Cover the problem over. -
This neighbour, is he called Boris? -
I think that one problem of being 'off grid' is that people expect to get the same controllable levels of comfort that we have all come to expect. It really does not matter of your house swings 4°C in temperature day to day, or you have to take a short shower, instead of 3 baths. When I was a student in the early 1980s, we had flat that had a 2 kW bar heater in it, that was it, apart from the cooker. We survived, through studying, fresh vegetables (one flat mate was a farmer) and alcohol (2 other flat mates died from it, eventually). Just a change of lifestyle, and thermal underwear.
Insulate it and use it as a thermal store, or other energy storage.
Chalfont St Giles.
Needs a huge amount of insulation under it, and to the sides, as well.
60s flat renovation - what's the best way to go?
SteamyTea replied to skiberd's topic in Other Heating Systems
Is that purely heat pump driven, or does it use the built in resistance heater as well? i.e. it has a CoP of 1 at 60°C. -
Nor me, or landmines. A more manly method.
- 15 replies
I think so. Basically you need to be able to isolate the inverter from both the AC and the DC sides. Just remember that if the inverter is working, isolate on the AC side first. -
No, thermal bridges are places where you have a larger than normal surface area. So corners and internal walls where they meet external walls. Basically any uninsulated areas that protrude. Airtightness is purely the ventilation. You need to control ventilation, not let just random holes and joints govern the infiltration. Airtightness also improves sound insulation. Have you started to think about sound transmission. You my find that mineral wool is better than rigid board. There are also 'resilience' bars that decouple ceilings and plasterboard walls.
Because the inverter supplies at a slightly higher voltage. Electricity takes the path of least resistance. -
You could use a CHP unit to generate electricity and supply thermal energy. A diesel one would be reasonably cheap to run.
Himalayan sea salt, but only works if you pronounce it correctly, otherwise it is just salt.
Or dream? Now that is an idea worth pursuing. Flashing website, nice write up by a recent graduate in Marketing and PR. Get millionaire investors on board, then retire. No need to actually sell any hardware. Seems to have worked for many companies that are going to save the planet.
