Yes, it is good for rolling up bodies in.
When is it necessary to insulate heating ducts?
SteamyTea replied to Garald's topic in Heat Insulation
It is about finer control of the heating distribution. There is not 'one size fits all' method to this, so certain generalisations have to be employed. Just stick to the rules and guidelines and all will be OK. -
Wood. Burning stove for the Windy Roost Static
SteamyTea replied to Jenki's topic in Stoves, Fires & Fireplaces
Document it all so we can see what is involved. Be an interesting project. May even post you one of my homemade energy loggers, could be useful data.- 14 replies
- the windy roost
- occumster
That would need a large vent hole cut into the van. The one I linked to just needs a small hole. If you ever go to to a shop that has a portable AC unit running at the back, point out that they are actually heating the shop, not cooling it. They need to draw in outside air and expel the hot air. So the working bit should really be outside.- 14 replies
- the windy roost
- occumster
Not really. Panasonic used to do them for under 300 quid, There is this one for under 400 https://www.appliancesdirect.co.uk/p/tf-12000ch/telefunken-tf12000ch-air-conditioner-air-conditioner Not sure how much it would cost to get an F-Gas man in, but a few people have fitted them themselves.- 14 replies
- the windy roost
- occumster
Get the draughts sorted out, stop the wind blowing underneath the van. Then, assuming you have electricity, fit a cheap A2AHP. You may have a second use for it later i.e. heat workshop or garage, summer cooling in bedrooms.- 14 replies
- the windy roost
- occumster
You will have to re-type @Binky so he gets a message. Not seen him on here for a while.
Then what? Wait for bin day?
https://www.thermalec.co.uk/calculator/
ASHP, Just an outdoor fridge ?
SteamyTea replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
I don't, they work just the same as a fridge. A fridge in reverse would produce electricity from a temperature difference. -
Laughing at your futility already. It has been a while since we have had a humdinger going. Maybe it is a winter thing when we all get cabin fever.
Shall bring it over when I build the new one. Saves a trip to the dump.
Told you before. 'man who goes to bed with problem: wakes up with solution'.
Bloody spell checker. SEED
Do all these hopeful research papers take into account power delivery? It drops off quite quickly as the store temperature drops.
My house needs about 500W. It has a volume of 160m3. So about a tenth of the house size. But as you say. Just realised that is about the size of my shed.
Yes, why I keep it in a jam jar on my mantle piece.
Most failled experiment don't get published.
Shall I go around and 'charm' her.
Tell her how brilliant fast your Broad Band is, and how it will be so much easier to run your business from home. Point out that there is enough parking and turning space for even quite large trucks. My neighbours still think I am a vivisectionists for the government and I do taxidermy for a hobby. Well one side does. The other thinks I am gynaecologist, all I said was 'acute angina', but her English is not too great.
Are they allowed to do that. Some utilities have a statutory right of entry.
I pretended to be that friend. Here is what it costs to heat a small section of pool. https://jubileepool.co.uk/pool-info/geothermal/ It was meant to be all GT, but as they were over enthusiastic amateurs, it all went wrong and they fitted a HP. So really just a GSHP. Odd choice as they have one if the world's largest bodies of seawater, that they pump in anyway, a few meters away. It is 34°C today, they are proud to say it is too warm. So they have no thermostat on it. They also have the phones switched off 'because it is Monday, we don't open Mondays'. They do, (expletive deleted)ing amateurs spending my money.
Hybrid inverter for small in roof 2kw array - help please!
SteamyTea replied to Timmyk's topic in Photovoltaics (PV)
One of the problems I found when doing my ResM was that nearly all the research is either small scale, i.e. load reduction to take the load of a large diesel generator, or purely academic i.e. what would happen if we turned fridges on and off in response to grid frequency fluctuation. We do have large scale grid modulation though load shedding, it is well managed and is based on historical scenarios i.e. kettles on at half time. Our grid is based on predictions i.e. weather, time of day, marginal generation capacity, voltage and frequency tolerances. If say a million automatic storage devices started to switch half a gig of power on and off in response to changes in parameters, when they decided it was right to do so, our grid would quickly become unstable. Case of tail wagging the dog. This is why, even though we have the technology, it is not done. Everything on our grid has to be controlled centrally, and the effects predictable. We have seen what happens when an unusual, but predictable event happens alongside another such event. https://www.independent.co.uk/news/uk/home-news/uk-power-cut-cause-national-grid-wind-gas-energy-latest-a9051016.html
