ASHP with 1-2000L thermal store
SteamyTea replied to Tommytipee's topic in Air Source Heat Pumps (ASHP)
I am in the far SW of the UK. The Spring is cold, the sea has not warmed up. Makes for very mild autumn. Biggest weather related problems here are cloud cover and Northerly winds. Had a lot of Northerly winds this year. I take it your R values are in metric as NZ is all metric. -
Can't get more succinct than that. -
Hybrid inverter for small in roof 2kw array - help please!
SteamyTea replied to Timmyk's topic in Photovoltaics (PV)
You find those files and I shall see how it correlates with grid frequency. -
If a solar house, or an interseasonal store were viable in the UK, there would be lots of working examples. Fact is, there isn't. If my memory is correct from when I studied this, we have a mean insolation of 135 W/m2 down here. The very best PV modules will, over a day, give you 15% efficiency. So around 20W/m2. Just not enough. Even ST, at 80%, only gives you, on average, 110W/m2, of low entropy energy. It is that low entropy that is the problem. You need a machine, or a Maxwell Daemon to make it useful. Redo all your thermal calculations on Kelvin scale and it highlights the problem nicely.
It was still logging when I got home a few minutes ago. File was almost 7 meg. Just left it going and shall see what is happening in the morning. I should be able to calculate how many pulses have been missed. Would be happy if it was less than 1%.
Short of a totally isolated system, the inverter/auto isolator needs to be if a minimum standard. I think it is reasonable that even if an approved isolating devise is fitted, the DNO still know which, in event of failure, houses to check out. -
@MikeSharp01 As a test, I have set up an LED to flash for 0.01s then wait for 0.03s. Left it logging, expecting a large file when I get back. I think that will work out at 25 Wh per second. 90kW draw. Few houses will go above 20 kW. Dropping the odd Wh is not really a problem, and I think my CurrentCost does this anyway. I did initially try to append to a list, then when the list got to length 10, timestamp it. Was not very successful. Be interesting if it works in the WEMOS D Mini. I have some ESP 8266s, but not that good at micropython, not that good at python. I did wonder about the file write time, if I deleted the tfile.close line, what are the consequences?
The French copy no one.
@Tommytipee Had a quick look on their site and can't find a performance curve either. Pretty poor that is. -
I think you will find that it has been done, and failed big time. There was an Irishman, that some will remember well from the Other Place, that got a customer to pay for it. He also got another customer to buy into a domestic AD unit. When I met the Australian 'Inventor' my 'con man' flag went up immediately. “extraordinary claims require extraordinary evidence” (ECREE) Carl Sagan 1979
Should not be a problem as the RPi has loads of GPIO pins, Just add button1 = Button(23) and button1.when_pressed button1.when_released = sort_time1 Also add def sort_time1(): dt = datetime.datetime.utcnow() runday = dt.day dt.day == runday ts = time.time() UTC = datetime.datetime.utcfromtimestamp(ts) logfile = '/home/pi/monitoring/data/PV-%s-%s-%s.csv' % (dt.day, dt.month, dt.year) tfile = open(logfile, "a") tfile.write("%s"%UTC + '\n') tfile.close Though there is probably a more elegant way to do the above.
I had clumping Black Rod and Golden Rod bamboo. Both grew gently for many years, then spread very quickly, into neighbours garden. Was a right (expletive deleted)er to dig up. No idea if it really can damage buildings.
No it don't, the UK spans nearly a 1 hour timezone, and we frequently have large difference in cloud cover as well. From an academic viewpoint, if we wanted to limit energy usage with the least disruption, we would place maximum generation at times of maximum usage i.e 7 AM for an hour and 4 PM for 4 hours. Hard on emissions, but better on stability as it is easier to coordinate 300 large generators than 70 million people. -
Could they be made to run reliably for a couple of years on a couple of D batteries like the CurrentCost does. My old clamp ones lasted 5 years transmitting away. The Optisence uses just one D cell and lasts at least 2 years, as long as I don't put my metal frame collapsible chair in the way. It is better that a tinfoil helmet at blocking a signal, and you can sit in it.
I think the problem is not technical, but financial. I did a write up several years ago about adding small amounts of storage (sub 1 kWh) to each house to help grid fluctuations. One problem would be who owns that unit and who owns the energy in it. The decentralising fans would point to a blockchain solution, but that is just energy intensive, even using 'proof of work', fine for a few bearded hippies, not so good for 30m homes doing 540 transactions a day. Easier for a DNO to just plonk a shipping container with 100 kWh of storage next to a local substation. Then there is only one thing to worry about, not 100. -
You live in a rural area, so only a few tens of homes, and a milking parlour are affected. Not the same in even a small town where 1000 houses can be without power for several hours. There is a good chance that we will have energy rationing come this winter. The easy way to do it is via scheduled disconnection. -
Me neither. In law, silence is not acceptance. So I silence my critics.
I suspect, anyone that fancies making one, will be a bit of a DIYer. So you had any thoughts about adding a cheap display, but not one of those tacky LED matrix ones. Something like this. https://www.ebay.co.uk/itm/165511794894 And the code to display useful stuff, i.e power, energy, time, price, temperatures. It is that side of it that I have never done before and find frustrating.
As it is Sunday, thy will will be done. -
Have you read the terms and conditions about posting on here?
Energie thermodynamic system anyone have experience
SteamyTea replied to Calw's topic in Solar Thermal (ST)
On the face of it, it does seem low. But. DHW below about 30°C is of little use, and above 40°C it too hot. As I use just the top part of the cylinder, there is only around 60 lt heated. As that is about 50°C, that is only 15 to 20 °C uplift. 60 [kg] x 17.5 [°C] x 4.2 [SHC] = 4.41 MJ = 1.225 kWh. So pretty close. -
I may give that a go as I have never managed to get it to SSH in with the 'create an empty file' method. Can you get small crimps to join very small wires. Though that is more things to buy. I am going to look around the shops and see if I can find anything that can be easily modified to make the LED holder. I used a bit of rubber pipe and some epoxy. after super gluing the LED into place. Picture to follow in a few minutes.
May be called something else in UK. Work on improving it. Makes any heating problem smaller. -
Thanks. Shall see what I can knock up.
We should have installed air conditioning… now what?
SteamyTea replied to Adsibob's topic in Other Heating Systems
Like that today, and we have an extreme weather warning issued. I am off to the beach, it may get to 23°C today.
