How does your garden grow?
SteamyTea replied to recoveringbuilder's topic in Landscaping, Decking & Patios
@Onoff How well did your nettle tea fertilizer work? -
ASHP, how to decide - I just don't get it!
SteamyTea replied to Jimbo37's topic in Other Heating Systems
Almost. You may get short cycling when close to the minimum flow rate, especially if you are running at the lower end of the temperature window. If the buffet/volumizer, and associated pipework is properly insulated, then there not many thermal losses. Mostly, but as you have found out, it is hard to get decent information, this leads to customer ignorance. Ignorance in the proper meaning. Trying to explain, via a sales or remote technical person all the nuances, when the basics are not understood, leads to customer confusion. Let's face it, many people still struggle to understand Economy 7, let alone the multitude of ToU tariffs available today. Terms like 'refrigerator in reverse', 'low grade heat', 'only work in a well insulated house' (how often do we hear that unqualified statement on here), 'they don't work when it is cold', energy and power constantly mixed up, and no explanation about what they are and what uses of the term means, and even the experts on the radio getting latent heat and sensible heat mixed up, just adds to the general ignorance. A first year science students does not learn any new science, what they are taught is 'unlearning'. All those simplistic, basic ideas and examples have to be broken down and rebuilt. It is why, after 120 years, the public really don't understand Quantum Physics, they had 400 years to badly understand Newtonian Physics, then get told it is wrong. No wonder there is distrust in science. We can create an effective vaccine in record breaking time, while still believing that Bill Gates is implanting microchips into all humans, and 5G masts caused COVID. Lots of education is not helping. There is a thread on here from someone that had never heard of a heating system that stays on 24/7, said it was ridiculous. I wanted to point out that most heating systems are in 24/7, just that during that window they may not be consuming any energy, and may, or may not, be releasing energy. Economy 7 is a classic example. It is on all day and night, the difference is that it only received energy for a limited period of time, it is always releasing energy. If it goes 'cold', that just means it is either incorrectly sized, or being used badly, nothing to do with the underlying technology. Explaining to a customer what the problem is, during an hours sales visit just ends in useless soundbites. -
Or in Russia/China.
Possibly no need for a buffer may be more accurate. I am still of the mind that a buffer/volumizer is always worth fitting. They do have to be designed in from the start, not added as an afterthought. -
It is a garage, so damp. And there is ply already on site.
Need a bog cleaner. Long hours, but as much heroin as you can handle.
9 m² https://www.planningportal.co.uk/permission/common-projects/solar-panels/planning-permission-stand-alone-solar-equipment-panels-not-on-a-building-but-within-the-grounds-of-a-house-or-a-block-of-flats
Don't forget that you can hang a lot of stuff on the walls. Was listening to Costing the Earth yesterday, Steve Backshall Goes Off Grid. Apart from getting his sensible and latent heat mixed up, and not giving a cash price on what he spent, he said one interesting thing about his plant room. 'it is hot in here' Sounds like he has not insulated enough. So make sure you have enough room to add extra insulation to everything. Manufacturers of cylinders and tanks may boast about how great the levels are, but if a room gets hot, it isn't good enough.
With 6mm that may be ok. Still out some cross bracing though. There was a calculator link posted up about ply sagging, think it was in one of the shelves posts, @Adsibob one I think.
How would you deal with guttering between the flat and sloping roofs (I know it is a simple model)?
How far apart are the joist. If 600mm, then yes it will sag. Can you put in some lightweight 'noggins' every 300mm?
Opinions on best way to drop a ceiling
SteamyTea replied to Thorfun's topic in General Construction Issues
One for @Gus Potter I think. Had a quick look, Cord 1 and 1 (top and bottom) have similar dead loads at 210 and 200 N.m-2, so that is 410 N.m-2 for flooring and ceiling. The there is the imposed load, which I think is point loading, at 1500 N.m-2, which is 159 kg.m-2. My knowledge is lacking in that I do not know for definite what the imposed load it. Seems from a very quick internet search that they are considered equal to impact loads. https://eng.libretexts.org/Bookshelves/Civil_Engineering/Structural_Analysis_(Udoeyo)/01%3A_Chapters/1.02%3A_Structural_Loads_and_Loading_System -
I think you can get modules that fit within the seams. They clamp to the upstands.
Just run it though a beam calculator and see what the deflection is. -
Total Control heating tariff phaseout
SteamyTea replied to Crofter's topic in General Self Build & DIY Discussion
Yes, I have that. Means I can limit when the stuff comes on. -
Not really.
It is quite possible. You will need a charge controller (that can handle the voltages and amps) a battery and an inverter to run anything that is 230V. There are two types of inverters for this, full sine wave, not full sine wave. You probably need the former. Probably going to cost you 500 quid.
Have you run your angles through PVGIS.
