SteamyTea
    200
  1. I went on it before it was closed, I liked it, great views up and down the river.
  2. That's true though only (expletive deleted) don't use GRP. I foresee the board delaminating. Screws are good. Those as well. Personally I like to design in 3 methods of retaining something when it fails. So screws, adhesive and the DC cables. Had a long discussion with a train driver about bricks though the window. It is not all about stopping failure, just making sure when failure happens, it is low energy, predicable and noticeable. You mentioned the Wobbly Bridge the other day. That did not fail, as such, was just a bit wobbly when too many sheep like people walked on it.
  3. Not a beaver then.
  4. While making the classic donkey sound.
  5. Yes, anything that can spread a load is helpful, pick the correct adhesive and it tensile yield point could easily be greater than the screw/OSB interface.
  6. The Port of Rotterdam will take a slice. Most goods that are shipped to Europe, and geographically we are in Europe, go via there, so a bit of double handling. Then there is exchange rate fluctuation, which ever way it is done, the UK, having an independent sovereign currency, will have charges, usually higher than the $ or € as they are currencies that are in greater circulation (so 'collected' by other countries to help stabilise world trade). Then we have high storage prices because we have high property prices. So I doubt that anyone is actually overcharging because they can, we just have high costs of doing business.
  7. Was at a home building show (with our old mate Jeremy Harris as it happened). SIPs was all the rage back then. I asked a salesman about fitting PV to it, he hesitated way too long before answering the it was fine, they had done loads, never had a problem. Those roof panels (the SIP ones) were 9mm OSB.
  8. And that is assuming you want the full 1 kW. My house takes about 400W to stay 15⁰C above OAT.
  9. Imaging two rooms in your house, both 3m by 4m, so 12m2. ONE is at the North East corner, with the 4m side running along the North wall. The other is on the diagonally opposite corner, with the 4m running down the West wall. The thermal losses, and gains, could be quite different.
  10. Being at boarding school. 13 other 'young men' all going though puberty. For years I thought all bedrooms smelt of PU adhesive.
  11. Sensible losses. Latent, in thermodynamics, which this is, is when the phase changes. Sensible heat is when the materials heated stay in the same form.
  12. You can't, because you are an insignificant retail purchaser in a high cost country who does not buy anything of significance. But Midsomer will sell you a 400 W module for £200. https://midsummerenergy.co.uk/buy/large-solar-panels/longi-lr5hib-400w That 400 W module would have cost $84 when it left the factory in 2021, the average exchange rate then was 0.7271 GBP. So £115.53. Not much of a mark up considering.
  13. Nothing to do with the global market then. I know you hate anything that shows there is a wider world that the UK is not in charge of. Historical PV prices https://ourworldindata.org/grapher/solar-pv-prices?yScale=linear&time=2000..latest
  14. That is because you don't know what you are doing.
  15. It does seem odd to me, but then I am odd, that people obsess over something that we spend around 1/50th of our time doing. If a DHW system has limitation, learn to live with them, 7 million people with E7 manage it.
  16. As usually, you don't understand the very basic physics. That is the flow rate of the hot water only (in the example I gave) it then gets diluted with cold to make it a usable temperature. So the flow rate from the tap will be higher. And anyway, 10 lt/minute is a pretty good shower, you don't get twice as clean by doubling the flowrate. While I agree with this, for the occasional times that you have to because of higher usage, it is cheaper than having a secondary cylinder. Not much difference, but are you not fitting an ASHP in your place?
  17. I tidy as I go, makes the final clean up at night very easy and quick.
  18. Being tidy improves productivity. In my experience, it tends to be one or two people that make all the mess and slow everyone down.
  19. Cylinders can be reheated right after usage, they don't need to wait until the bathroom is vacated. I would think that most households have the same problem regardless of heat source. If a combi boiler has a flow rate of 10 lt/minute at the desired temperature, it can reheat a cylinder at pretty much the same rate as it can come out the tap. Really down to the power of the system, not the volume stored. Not as if anyone uses hot water when it is too cold bath in i.e. <35°C, so the cylinder is not totally cold i.e. ground temperature ~8°C. As @JohnMo says, if you are really worried, get an inline heater or just fit a couple of immersion heaters. Immersion heaters are the cheap option. 5.5 kW of heating into a 300 lt cylinder will raise it by 20°C in just over an hour. If the flow rate of a shower is 10 lt/minute, that would supply 3, ten minute showers an hour, but in that same hour, more than half the energy would have been replaced, so 5 showers an hour. And that is just for a 20°C replacement rate. Cost to run would be about £3.50, near enough the same as a Costa Coffee, and that only has 0.25 litres of hot water in it. We also should be striving to us less water overall. This year I have reduced my usage by around 50 litres a day, I don't think my life has suffered, or my personal hygiene. Can't say the same for the car, that is pretty grubby, by my succulents in the garden don't seem to care if they have water or not. If you are mainly shower people, rather than bath people, have you considered getting waste water energy recovery. That will save on running costs and reduce reheat times.
  20. Yes, no, definitely not maybe.
  21. May be a bad assumption, it depends on the water volume in your heating system is. Depends on your ASHP, they can calculate energy required from flow, return and OAT temperature difference. I assume you have already had a full, room by room, heat loading calculations done and you know tour pipe spacing for the lowest flow temperature you can satisfy the overall heat load.
  22. (expletive deleted), did I miss something I want Tourette's, then I can legitimately ask to have the swear filter removed.
  23. 'are you an engineer' 'no, I am a (expletive deleted)'
  24. The arithmetic and science, once reduced to the SI system is very similar. They all tend to use kg, metres, seconds and temperature.
