You can be filling a bucket from a tap at the same time as water leaks out of a hole in the bucket, Dear Liza. I think the question is wrong. What do you really mean, or have noticed to make you think this.
The science behind sewage treatment plants
SteamyTea replied to Crunchynut's topic in Waste & Sewerage
Aren't diaphragms one of the things -
I would think so. I find the nicotine and tar stains hold the new paint in place.
I was not looking for fame, just like to know I am still in touch with reality. Getting there in into taphonomy after that.
Then Irfanview Portable.
If you are using a phone, there are applications that will reduce them. I use PhotoCompress (Android) It is probably built into a iPhone as there is nothing on Earth they cannot do, apparantly.
For any latitude there will be an optimal angle that can collect the greatest amount of incidental light (direct beam) over a year. This does not equate to maximum power. Fitting brackets may marginally improve the total energy collected, this is called insolation, but may, if it causes some shading to other modules, or reduces the amount of time the module can face the sun, cause an overall decrease in energy. There is a meme that we should be fitting solar panels to all roofs before we build solar farms on agricultural land. This often touted nonsense shows a lack of understand of basic geometry, economics and engineering practice. Probably why the solar industry does not respond. Hardly worth the effort while they are installing PV at £45/MWh.
Bill Gates, Steve Jobs (if we was alive), and Tim Berners-Lee are all pensioners. C was started in the early 1970s, Python in the 1980s, Java, mid 1990s. Not exactly new any of it/them.
Yes I do. I remember to turn things off when not needed.
It is a standard E7 cylinder, so almost at the base. There is a secondary element at the top, but that was not used. Since I collected that data, I have changed the timings so that rather than heat at the beginning of the E7 window, it heats at the end of it. Mainly did that because for a couple of hours it was loosing heat to the house, and as I like a bath in the morning (decided I actually dislike showers and only use them to get work grub off) I wait till the water stops heating, then draw off a bath full, then they cylinder is at a lower temperature, so less losses. I really should start to monitor it again, maybe with it's own energy monitor as the kWh trace included all usage, so fridge, kettle (I am a very early riser) washing machine etc.
Not trying to be clever or anything, just make sure I was not totally off track when I suggested this. I did not add any detail as I am basically a lazy bastard, and there are others that are much better at calculating this.
Repeat the experiment 20 times. Then run a chi square and a student T test on the results. I suspect the it is a combination of turbulence in the cylinder and thermometer/element/thermostat position.
Potential sagging on cupboard shelving
SteamyTea replied to Paene Finitur's topic in General Joinery
Same problem going on here. I like the ''sagulator" -
Had some sun today, then back to clouds.
Professionals around Cambridge area
SteamyTea replied to JayC's topic in New House & Self Build Design
Good spot, building sites are dusty -
Yes, allowed to rummage in my trousers without getting shouted at as well.
(expletive deleted)ing right, repotted my Black Aeonium Zwartkop without any grief today.
First things first. Get him to take meter readings and update his account, if he is on direct debit, the £200/month may be just bad estimating. Then get him to read the meter every morning for a week. to see what is actually happening. It is quite possibly the legionella/disinfecting heater coming on and just gobbling up juice. Make sure that any immersion heater to the cylinder is off. -
Very alone. There is not enough room to bury a body in that sad excuse for a garden.
Is his water heated by the ASPH?? My DHW bills is around 3 kWh/day for just me. That costs me 45p/day on E7, but if I had a heat pump, on a standard rate electricity, about 35p.
