If it is over 9m2 then you need planning permission. The modules and inverter are rated as kW, battery as kWh. But it really depends as some some inverters have minimum lower power setting i.e. 200W, so they often will not run lights off the battery. There are 2 main types of systems that incorporate batteries. One that puts the batterers on the DC side and the other on the AC side. I think most people go for hybrid inverters that that allow batteries to be charged from the AC side. There is a lot more to an MCS installation than just final signoff. Generally why MCS companies will not sign off systems they have not installed.
About what I used to heat my house yesterday. Are they still allowed to be sold? With electrical equipment there is an upper power rating for standby.
That is about 100 litres of gas. Seems a lot to me.
It is worth remembering why a VCL is fitted. It is to stop humidity condensing on hidden cold surfaces.
What make and is it saffron cake.
Is it take water from the base of the cylinder and returning it to the top? You have a greater temperature drop, over time, at the cylinder base. Can you check the flow direction?
I get upset if I use over 20 kWh/day.
2-Ply Glulam Beams - Nails?
SteamyTea replied to Mulberry View's topic in General Construction Issues
Nails, screws and bolts all work differently. Hand nailing can be a bit of a pain if access is limited. -
Vinyl onto osb. Will the texture show through?
SteamyTea replied to saveasteading's topic in General Flooring
Drill clearance holes and countersink the heads, it will pull down better onto the adhesive. -
Which is based on Physics.
Climate zone is more to do with the land/ocean ratio and altitude.
Welcome And Longitude
Drying and re-insulating a 2.5 year old damp cavity wall
SteamyTea replied to Adsibob's topic in Heat Insulation
- 44 replies
- damp
- cavity wall
Welcome It is about time we had a useful chemist on here again. My knowledge is very limited in the black art and usually involves a bucket and stick.
new year - it was supposed to get better
SteamyTea commented on LSB's blog entry in Little Stud Barn
Condolences on your Brother. Not sure what else to say. -
May be getting another soon.
https://www.wickes.co.uk/Wickes-General-Purpose-Hardboard-Sheet---3mm-x-1220mm-x-2440mm/p/110107 -
I can finally drill! Oh wait. What is the matter here?
SteamyTea replied to Garald's topic in General Joinery
Not really as it is an electronic speed controller. When drilling masonry, you are really chiselling it, unlike drilling an elastic material like steel. You really won't come to any harm with a 700W drill and a 7mm drill bit and n 100 year old brick. -
Thought you might have been. Get the smallest masonry bit you have, drill at top speed, you will find it goes in no problem. Then get the drill bit you actually need, probably 7mm for a 'brown' wall plug, and follow down the original whole. You can always practice against the wall outside in the courtyard. The biggest problem with drilling through plaster is when you hit between brick and mortar, that throws the position off. -
Can she add some hardboard over the OSB, and that will get rid of any worries and give a much better surface to adhere to.
