Part L - Enclosing an existing swimming pool
SteamyTea replied to phillipsmw's topic in Building Regulations
If you test a public pool with a pregnancy testing kit, it comes up positive. But there is not really a chemical that turns the water red if you wee in it. -
Anyone used Alloy Aluminium Splashback?
SteamyTea replied to KitchenPotcher's topic in Wall Tiles & Tiling
Most towns have a steel stockist. Or a national https://www.nationwidestainless.co.uk/ https://www.rightonblackburns.co.uk/ -
There is a silent p in swimming pool. -
I used to work in the health and leisure industry. I cannot remember ever having to heat a pool room. Cool them yes, heat no. How are you going to deal with ventilation? And remember that all metallic fittings and fasteners need to be the correct grade of stainless steel, or other rust proof material. -
Welcome. Depending on the layout, air to air heat pumps (A2AHP) may be a cost effective option. You will still need to find a way to heat your domestic hot water (DHW), but there are several options there. The U-Values toy have been quoted are nothing special, but it does depend on the wall area. If you go for underfloor heating, the amount of insulation under it becomes important as you have a greater temperature difference (∆T). The smaller the house heat load is, the small the problem of heating it is.
Build your own. A decade of hope, followed by decades of regret.
Getting frustrated with heating suppliers.
SteamyTea replied to MikeSharp01's topic in Other Heating Systems
@Surfiejim Seems the course is every month up in Carterton, Oxfordshire. Makes for a long day out. https://www.altoenergy.co.uk/heat-pump-training -
We had an alloy splashback in our commercial kitchen. Was terrible. Go stainless steel if you must go metallic. -
Best fibreglass insulation for under floorboards?
SteamyTea replied to Logan's topic in Heat Insulation
It is the thermal conductivity that is the important bit. The lower the number the better. -
Anyone had a good British Gas heat pump install?
SteamyTea replied to eros_poli's topic in Other Heating Systems
It isn't really the fitting of heat pumps (or any wet heating system for that matter) that is the problem. It is the design of the system, and to be quite frank, you need to double check that yourself. So lots of reading up on them and local weather regimes. -
Does not mean much, you need to know the overall (glass and frame) U-Value of them, and how well they are fitted. All wool type insulation is breathable, so why spend extra on 'natural' sheep's wool. Not really, as it will fit in with And probably renewing/reinforcing some joists. What floor coverings are you going to use? You may find that you need a higher flow temperature, which soon becomes inefficient. Look at creating a cavity and filling will polystyrene beads. There is a myth that old building will be inherently damp, you don't mention the state of gutters, roof, downpipes, ground level. These are probably your biggest source of damp, not lack of insulation or non-lime render (lime vs cement is an on going debate, all I can say is that no one who says that lime is breathable has any numbers to back it up). Really. You getting @Pocster to design it and @Onoff to fit it? Look into some mechanical ventilation and heat recovery. If you build some stud walls and you are pulling up floors, that is the time to think about it. It is a pig to retrofit. And look at closing off all those chimneys.
A long time. Back of a fag packet calculation (will need a white marker now as the packets are black). Current space and DHW ~2865 kWh/year, at current rate of 16p/kWh, £460. If that became 1/4rd of the price (CoP = 4) then £115 energy cost Water is 0.17m3/day, so 62m3/year, water is £1.9338/m3, so £120/year. So 30,000 [£] / 235 [£] = 128 years (house is currently 37 years old) Those are without VAT. If I was a bit sneaky and did not pay for the sewage, then I would save another £200. Sewage is £3.2871/m3 for 95% of usage, Standing Charge is £150.86/year So 69 years. Now I am not sure where the £30k borehole costs come from, but my farming mate had a 60m one done for £1800. They do a lot of drilling down here so even though it is often into granite, the local geology is well understood. (I would not recommend a borehole system for most domestic properties)
I can remember the days, not that long ago, when I put in my new DHW cylinder and you tried to convince me to get a SA. As much as I like the idea of a phase change water storage device, I dislike unproven technology, and the price was, and still is, silly.
Let me know if they do, I may join you on the course. -
Welcome How old is the place, I have had 'Victorian' places, either end of her reign. They were both horrible to work on.
Umm There is a saying in Farming, "if you want to make a small fortune in pig farming, start with a large one".
New homes boarded up in Cornish village in planning row
SteamyTea replied to Alan Ambrose's topic in Housing Politics
I just had a look at my local council website and found some data about social housing in Calstock. https://www.cornwall.gov.uk/housing/housing-intelligence/ Seems that in April 2022, there was 8% social housing. I think that is not too bad for a small place. St. Ives and Pensilva is the same. Camborne, one the poorest parts of Europe is 15%, similar to Porthleven (a posh place they like to think) at 16%. Interestingly, St. Just, almost at the end of the country, has 33% (837) social housing. The county, as a whole (pun intended) is 8%. As for second homes, there is still a lot of ignorant bollocks spoken. The country as a whole has 11% second homes (household spaces with no permanent residents), 5% as according to the below map.. But the distribution is very clustered. Not many second homes in the middle bit, the part that is environmentally scared from 3 hundred years if mining and agriculture. I am still looking for the places that claim they have "80% holiday homes that are only used for 2 weeks of the year". -
As above. Regardless of what people say and think, we are going 'all electric', it makes long term sense for many reasons.
Rather than look at the floor area £.m-2, why not compare the differences on the total surface area £.m-2. That reflects the amount of materials/work much more accurately.
Difficult one this. Polyurethane is made up of many urethane molecules. This changes the structure and may affect how well it bonds to different materials and the type of surface finish. I suspect that most sold are actually polyurethane, but the lazy marketing department have misnamed them. I have a parquet wood floor, a very cheap one. I used a brush/roller on, single part, polyurethane floor lacquer. Has been brilliant. As it was 20 years ago, I can't remember who made it and don't have the tin anymore.
2 x 100m or 1 x 200m borehole
SteamyTea replied to ronaldgibbons's topic in Ground Source Heat Pumps (GSHP)
We do down here. Cornwall has pioneered DRH generation, still doing it. The local swimming pool was meant to be geothermally heated, £1.3m later they put a heat pump in. But that is not really relevant to domestic heating. As others have said, GSHPs are either ASHPs, taking advantage of local weather, or WSHPs, relying on deeper ground water. @ronaldgibbons Your floor insulation is going to be important. Most building companies are happy to say their designs meet building regulations. Not that expensive to exceed them where it really matters.
