Besidethewye Posted January 22, 2019 Share Posted January 22, 2019 We have an island that will have an induction hob in it. Going around the circle of extraction (recirculating rather than venting) and not sure where to stop. The house is passive with MVHR and an extract in the kitchen ceiling about 1.5m to the side of the hob location. We've mainly had houses with no extract/hood and never worried - but they have always been leaky in comparison (cold and old). I was going to leave a cable and space in the ceiling so I could fit a ceiling mounted unit if we need it. But wondering about either a suspended recirculation unit or integrated hob unit with down draught. I don't want to fill the MVHR up with grease if we can help it - and we don't do a great deal of frying - but someone might or our new diet might switch to chips.... We have friends who built a passive house recently - started with no extract but came back to get one - but their MVHR looks a bit odd to me - one vent in the open plan kitchen diner that's maybe 20 feet from the hob (and only one in the whole room - which I assume, but don't know, is extract rather than supply). I am sure this loop has been gone round a few times but couldn't find much with my searching. Appreciate any experience. Link to comment Share on other sites More sharing options...
ProDave Posted January 22, 2019 Share Posted January 22, 2019 Yes recirculating hood with carbon filter. As well as fitting a cable, but some dwangs (noggins) across the ceiling where it is going so you have something to fix to. 1 Link to comment Share on other sites More sharing options...
Bitpipe Posted January 22, 2019 Share Posted January 22, 2019 We have a recirculating extractor hood over the hob, does a good job but does get greasy inside so is cleaned regularly. Vents to ceiling level within the room. The hob sits opposite the wall ovens so in the ceiling mid way between them is a MVHR extract. We have one other in the kitchen for general extract. Our hood did not have the right connections to wire it directly into the MVHR (which does have a cooker hood boost terminal), we could have put a current sensor on the feed to trigger it but tbh the built in humidity sensor generally kicks in or I just hit the boost button in the utility. I've popped off the cover of that MVHR extract and it's not at all greasy inside but is a bit dusty - more so than the bathroom extracts but I expect that is because there are in a damper and therefore less dusty environment. Do you ever need to clean your extract ducts? Not even sure how I'd go about that... Link to comment Share on other sites More sharing options...
ryder72 Posted January 22, 2019 Share Posted January 22, 2019 A recirculation hood to trap grease is a good idea. While the venting hob options are dearer, you do extract at point of source so very effective. The MVHR deals pretty well with odours so this I wouldnt worry about. Link to comment Share on other sites More sharing options...
Besidethewye Posted January 22, 2019 Author Share Posted January 22, 2019 Thanks all - much appreciated. Link to comment Share on other sites More sharing options...
scottishjohn Posted January 30, 2019 Share Posted January 30, 2019 (edited) I asked same question of blauberg agent in uk when talking about a centralized mvhr system for new build his suggestion was to accept small loss when in use and have it separate direct extraction to outside with a flap type exit . better than blocking up the mvhr filters and coating ducts internally over time with gunk just what I have been told you make your own mind up I know what I will do when i get that far Edited January 30, 2019 by scottishjohn 1 Link to comment Share on other sites More sharing options...
Besidethewye Posted January 31, 2019 Author Share Posted January 31, 2019 Thanks Scottishjohn - I share your worry about keeping the MVHR clean. Hopefully a recirculating system would do the trick without opening another route to outside. I am past the point of putting any more holes in the walls! Link to comment Share on other sites More sharing options...
Jeremy Harris Posted February 1, 2019 Share Posted February 1, 2019 FWIW, we have no problem at all with the MVHR or ducting getting dirty. I cleaned/changed our MVHR filters last week, and as usual the fresh air intake filter was very dirty, but the house extract filter just had a very light coating of dust, so I just cleaned it with a vacuum cleaner and put it back. I fitted an OSB panel and additional wiring behind the ceiling plasterboard above our hob, so it's pretty easy to retrofit a cooker hood, but we've found that we don't need a cooker hood in practice, as the kitchen MVHR extract terminal seems to do a very good job of drawing cooking smells etc away from the rest of the house. One thing I did that probably helps this is fit an additional fresh air supply terminal in the ceiling outside and above the kitchen door. This ensure than fresh air is supplied as a sort of "air curtain" outside the kitchen, which seems to stop any cooking smells from escaping. Link to comment Share on other sites More sharing options...
dpmiller Posted February 1, 2019 Share Posted February 1, 2019 you don't do much stirfry though Jeremy. 1 Link to comment Share on other sites More sharing options...
Jeremy Harris Posted February 1, 2019 Share Posted February 1, 2019 3 minutes ago, dpmiller said: you don't do much stirfry though Jeremy. No, that's true, in fact we rarely fry anything, which probably makes a significant difference. Link to comment Share on other sites More sharing options...
Gone West Posted February 1, 2019 Share Posted February 1, 2019 @Besidethewye We have our MVHR kitchen extract around 2m from our hob and have fitted a recirculating extractor hood above the hob. Although we don't fry food we have planned ahead for when we no longer live here. Link to comment Share on other sites More sharing options...
Besidethewye Posted February 2, 2019 Author Share Posted February 2, 2019 I thought I had a plan and now I am not so sure! We have extracts about 2m from the hob one way and another in the utility about 3m the other but a possible route out of the kitchen and into the corridor/upstairs drawn by the extract in the toilet.....we don't fry a great deal though the better half does note that my repertoire in the kitchen is dominated by stir fries of various and unrepeatable mixtures. My aversion to a) having to make modifications later and b) finding gunk in the extract pipework which I can't see how we would ever clean out makes me think putting a recirc hood in now would be easier and my wish not to keep burning money unnecessarily suggests put the mounting in and move on.... I'll check with the boss for the definitive answer. As they keep saying by the time I get onto my third house I might have it all down to a T Link to comment Share on other sites More sharing options...
scottishjohn Posted February 2, 2019 Share Posted February 2, 2019 23 minutes ago, Besidethewye said: I thought I had a plan and now I am not so sure! We have extracts about 2m from the hob one way and another in the utility about 3m the other but a possible route out of the kitchen and into the corridor/upstairs drawn by the extract in the toilet.....we don't fry a great deal though the better half does note that my repertoire in the kitchen is dominated by stir fries of various and unrepeatable mixtures. My aversion to a) having to make modifications later and b) finding gunk in the extract pipework which I can't see how we would ever clean out makes me think putting a recirc hood in now would be easier and my wish not to keep burning money unnecessarily suggests put the mounting in and move on.... I'll check with the boss for the definitive answer. As they keep saying by the time I get onto my third house I might have it all down to a T I looked at price of one of those recirculting extracts that cone up out of an island over £3k- I, won,t be doing that it will be a direct to outside job with flap on outside grille Link to comment Share on other sites More sharing options...
Cpd Posted February 2, 2019 Share Posted February 2, 2019 1 hour ago, scottishjohn said: over £3k- I, won,t be doing that it will be a direct to outside job with flap on outside grille Seems crazzy expensive ! I will be renting my cottage out in the summer (what year I don’t know.....) and I know most of my guests like to have a holiday fry up when they are staying. I have wasted so much time going back and forth with what to do ! I don’t want gunk in my ducts and a mixture of dust and fat sounds like a disaster waiting to happen. I was planning on recirculating with an OVER SIZE hood to try and catch as much as possible but there is no way I would have a spare 3k...... maybe I need to pipe in a direct to outside extraction and use that until I can afford a recirculating hood..... but 3k...... impossible. Link to comment Share on other sites More sharing options...
scottishjohn Posted February 2, 2019 Share Posted February 2, 2019 7 minutes ago, Cpd said: Seems crazzy expensive ! I will be renting my cottage out in the summer (what year I don’t know.....) and I know most of my guests like to have a holiday fry up when they are staying. I have wasted so much time going back and forth with what to do ! I don’t want gunk in my ducts and a mixture of dust and fat sounds like a disaster waiting to happen. I was planning on recirculating with an OVER SIZE hood to try and catch as much as possible but there is no way I would have a spare 3k...... maybe I need to pipe in a direct to outside extraction and use that until I can afford a recirculating hood..... but 3k...... impossible. I,m sure there are cheaper ones that do not hide in island and only appear when you want to use it -I stated that one as an example of how silly some the prices can be a quick look https://www.tlc-direct.co.uk/Main_Index/Cooker_Hood_Index/Luxair_Hood_Index/Luxair_Recirculating/index.html £880-£1000 Link to comment Share on other sites More sharing options...
PeterW Posted February 2, 2019 Share Posted February 2, 2019 If you want a quick and simple solution then fit a carbon foam filter block inside the extract vent - they are usually used for fish ponds but what they do is trap the grease and just wash it out every so often. Should be no more than £10. One question I would ask though of the people worried about cleaning the ducts on MVHR.... when was the last time you cleaned your extractor hood pipework ..???? I know a lot of people who change the filters but nothing else, and even with a filter due to the direct extract route these get very mucky yet we all seem to ignore it ..?? 2 Link to comment Share on other sites More sharing options...
Jeremy Harris Posted February 2, 2019 Share Posted February 2, 2019 I managed to modify the carbon filter on our old cooker hood by just removing the grilles either side of it and re-filling the core with activated carbon granules, intended for use with fish pond filters (they are cheap and easy to buy from places like eBay). Worked a treat, and if you wanted to really save money then you can wash and bake the used granules to reactivate them. 1 Link to comment Share on other sites More sharing options...
scottishjohn Posted February 2, 2019 Share Posted February 2, 2019 (edited) most peoples ducting will be much shorter than any mvhr system though Edited February 2, 2019 by scottishjohn Link to comment Share on other sites More sharing options...
Alex C Posted February 9, 2019 Share Posted February 9, 2019 We have a recirculating extract over the hob that works really well. We also have an mvhr extract about a meter set back from the recirculating hood extract. The flow rate of the mvhr is many times lower than the extract hood, but over time removes any smells and the extract hood removes grease from the air. We have a 30 year old rental apartment with constant extract above the cooker with no filters. The amount of grease this has collected over time and has stuck in the duct is disgusting and really shows the importance of something to trap the grease and not just rely on the mvhr to extract . Link to comment Share on other sites More sharing options...
Cpd Posted February 9, 2019 Share Posted February 9, 2019 1 minute ago, Alex C said: We have a recirculating extract over the hob that works really well. Do you have a Make and cost of this please ? It’s something I will need in the future and don’t want to buy a lemon when the time comes. Also how big / wide is your hob compared to the hood. Link to comment Share on other sites More sharing options...
richi Posted February 9, 2019 Share Posted February 9, 2019 @JSHarris do I recall you added an ozone generator? If so, do you still use it? Link to comment Share on other sites More sharing options...
Alex C Posted February 9, 2019 Share Posted February 9, 2019 (edited) 1 hour ago, Cpd said: Do you have a Make and cost of this please ? It’s something I will need in the future and don’t want to buy a lemon when the time comes. Also how big / wide is your hob compared to the hood. It is an elica that was very expensive, but as we have an open plan kitchen living space I wanted one that looked good as well as being effective. https://elica.com/GB-en/hoods/meteorite-islandI'm sure it is possible to get ones that functions just as well for less money, although cheaper ones do tend to be more noisy. We have an 800 wide hob and wanted a 1200mm wide hood so that narrowed choices right down. Plenty of people use the ceiling recessed ones above island hobs, but with a high ceiling these are never going to be so effective. The standard for these seems to be the Westin oneshttps://www.westin.co.uk/our-hoods/ceiling-hoods/westin-stratus/.These were specced by all the high end kitchen companies I visited. Edited February 9, 2019 by Alex C Link to comment Share on other sites More sharing options...
Jeremy Harris Posted February 9, 2019 Share Posted February 9, 2019 2 hours ago, richi said: @JSHarris do I recall you added an ozone generator? If so, do you still use it? I have a portable ozone generator that I used to use a bit at the old house to get rid of lingering cooking smells. It works very well, just plug it in, close the door and come back half an hour later and there's no trace of any smells (kills all the bugs in a room too...). I've not felt the need to use it in the new house, mainly as the MVHR is pretty effective at getting rid of any lingering cooking smells. We do still have a small ozone generator that sits inside the fridge, and activates periodically to remove smells. Seems to work well, especially if there are any pongy cheeses in the fridge. 1 Link to comment Share on other sites More sharing options...
Stones Posted February 9, 2019 Share Posted February 9, 2019 We use a small ozone generator to neutralise cooking odours. It certainly helps, especially if running whilst creating the odours. This is in addition to a recirc hood, and MVHR on boost. If more is required (e.g. when griddling steak) we'll open windows on opposite sides of the house and use the pressure differential to do quick air change. 1 Link to comment Share on other sites More sharing options...
Sue B Posted March 17, 2019 Share Posted March 17, 2019 I have always put the cheapest extractor hoods I could find into kitchens as I never remember to use the things. Then in the last build, we had the hob on a penisular with a breakfast bar behind and we needed the extractor hood for building regs. So I bought one of the things that rises out of the worktop. It was great and caused no end of amusement. Not sure it worked particularly well and from memory was over £2k but I do love a gadget. It could be set to extract outside or to recirculate and we chose the extract out route. The main reason for choosing this type of extractor was that Peter is forever bashing his head on anything and everything. Most island cooker hoods are within range (albeit with a bit of effort) of his head, he is not very tall, just creative when it comes to hurting himself. Add that to the weight on the ceiling - in that house I was concerned about that additional weight in a central part of the ceiling which had a very wide span - a rising extractor seemed sensible. I can see that the price has come down now and there is one on here for just over £1k at the moment (10% off with save10) voucher) https://www.theappliancedepot.co.uk/brand-new-de-dietrich-dhd1500dg-86cm-dark-grey-premium-downdraft-extractor?gclid=EAIaIQobChMIrs22gvOI4QIVir3tCh0X4g5kEAQYAyABEgKYWvD_BwE So it seems likely we will be using the same type of system again. 1 Link to comment Share on other sites More sharing options...
