1 minute ago, newhome said:
Will have a watch - cheers. Of course you need it for 3 days. Who would think otherwise? :D. Hubby wanted a Tesla Model X but far too expensive! They are supposed to bringing the Model 3 out "shortly" followed by the Model Y with a fab electric range which from an affordability perspective as well as range should bring them back into view for a much larger consumer group! Now that the Gov subsidy has been cut the almost 40k price of the PHEV is way too high in my view. I won't be buying another unless the price drops and the electric range is improved.
I think the model I have hired lists at about £150k, :o Its the only chance I'll ever have to drive one so yes 3 day is essential (not long enough in my eyes)
  • Like 2
  • Sad 1
Not tonight Faye I'd rather play with a Tesla???
And I'm thought weird for taking my missus to Dungeness nuclear plant on honeymoon! :)
  • Haha 1
  • Confused 1
1 hour ago, newhome said:
Yeah but James May is a bit of a twat and a dick petrol head like him is probably against all renewables too ......
My dad taught him at school :ph34r:
4 minutes ago, Declan52 said:
They done a review of one of the telsas on the grand tour and it looking amazing.
that's the same one I'm getting, a 6/7 seater that is pulling the pants down of most supercars over 1/4 mile AND it has celebration mode xD
Think of all the heart felt messages you can put on the display like Clarkson did.
It was very impressive even he really liked it. Just the £150k price tag that was a slight issue!!
9 minutes ago, Construction Channel said:
supposedly the thing can drive itself so i might be able to do both ;)
And have a drone following for some unforgettable footage! :)
4 minutes ago, Construction Channel said:
you laugh, the drone can track and follow by itself as well so it might well be an option :D
Believe me I knew that when I said it. Looking forward to seeing the footage!
  • Haha 2
My rather cute, blonde, single female neighbour has asked me to fix this.
Said it has stopped vibrating.
She is picking it up later tonight.
(She is really a redhead but has the decency to dye it blonde).
This has gone so far off topic it is now silly :D
1 hour ago, SteamyTea said:
Pretty poor really.
You could measure the thickness, find out the material and then work out the thermal losses.
Before I secondary insulated my DHW cylinder, I was loosing more than I was using.
Oh and don't believe the manufacturers claims, the testing regime is, to say the least, a bit odd.
How did you go about adding secondary insulation? Just sheets of PIR or an exotic mould filled with expanding foam?
I'd worry it might squash my old cylinder and cause it to leak.
Lots of ex girlfriends undies knowing Nick :S
They're probably still wondering where they're gone. :/
And no, you cant make this any worse, either of you.
8 minutes ago, Nickfromwales said:
including a CRB
Been checked out, I am safe to work with children and vulnerable adults.
I do pretend that the courts have said that no ones children are allowed within 500 meters of me, but usually gets misunderstood.  Then I get my lights punched out.
I will probably stop posting when the new terms and conditions come out.
Lined the cupboard walls with 100mm of PU sheet, then filled in the gaps around the around the cylinder with mineral wool.
Leaving an airgap at the bottom for the cable (cause I am a good boy).
Does the immersion ever nuisance trip / overheat stat kick out?
Redhead? The forensics suggest the collar and cuffs don't match... :)
You beat me to it! :D @SteamyTea I hope she wiped it before handing it over! :D Tell her the Silk Epil has better reviews ;)
  • Haha 1
Just now, Nickfromwales said:
@newhome
Digressions are a part of everyday life here so dont worry, it'll all be ok in the end. ;)
I'm cool with it - I caused many of them! :$
Cause not.  On 'proper' fuses, the ones with wire in them.
Being the lower element, the temperature rise is very modest, and I limit the on time to less than 3 hours (after careful measurements).
Yes all the time. Used to do it every time I used it when it got the water to a fairly decent temperature. I used to have to reset it every time I used it. When the boiler engineer came out he said he had 'changed the settings' so it would no longer trip but since he came out the boiler has worked ok so I haven't used it since. Used it every day for about 8 weeks at one point!
Ignore this - thought you were asking me - not cuppa boy
Edited by newhome
I better offer her the use of my Gillette Mach3, the blade is having its monthly swap out tomorrow.
11 minutes ago, Onoff said:
Redhead
Born in Angola, so all very strange.
Though I tell people I am 6'6", West Indian and very strong :D
If you have any hot wax it may suit her needs better ;)
