On 17/03/2026 at 18:32, Big Jimbo said:
@SteamyTea Will you still do me a Dirty Donna, if i am ever down your way ?
Donna Donna still got no knickers on er.
(I can't look at Christmas reindeers without saying that out loud when children are about)
1 hour ago, JohnMo said:
That maybe the issue (haha) - technician, not an engineer.
1 hour ago, SteamyTea said:
Chartered Engineers are what are really needed.
had zero idea how to manage drawing revisions.
The problems usually arises 'on the shop floor', not in the drawing/engineering office.
Engineers not needed at all. 😉
A long long time ago in what feels like a galaxy far far away,  I used to run document control for projects building anything from oil rigs and oil refineries to pharmaceutical plants all over the world. The engineers used to come crawling to us to ensure the right drawing versions were in the right place and the right time, especially when we got to construction drawings and sub-contract tender and issue. Nowadays, unless you've got good prior experience, some companies like the one I worked for ask for a Masters in Library Science for senior roles doing this.
On 16/03/2026 at 19:16, flanagaj said:
Would you still check even though it was set out with a total station?
In case it helps you to feel better, we had a full topographical and lazer scan of the existing building to provide base dwg files as most of this was staying in place, then had a measurement survey by an architectural technician and again by an architect. I had to admit I thought we had it covered until a Polish brick layer kindly informed me that the back of the existing house was 120mm longer than the front. Cue a run to the phone to stop production of the curved glulam beams all ordered at the same length. In the end the glulam company did a fantastic job of manufacturing 3 different length curved beams for the main structure. The only pain for me was laying the metal standing seam roof onto a not square roof and hiding that it's not quite square! As lesson learned in not demolishing and starting again, but I do wish professionals could measure properly 🙄
Maybe @craig can shed some light on this, he has people out measuring I think.
My guy (arranged by our ground workers) came with drawings loaded into his computer, tied into GPS, then using another bit, just picked the points of one by one, even told me exactly how much higher the site was to the plan. Marked out the foundations, once foundations were done, came and marked out for the blocks. Spent an hour or so at site in total. Technology working.
Check measured it all and couldn't find an issue and foundations are pretty complex, compared to anything else I've seen.
Now thats both interesting and reassuring.
Ya think?
My last project (Passive House), was a ****ing nightmare. Every opening was in the region of 5mm to 30mm out in height/width (100mm inner block, 120mm xps, 100mm compacfoam, 30mm cavity, 100mm outer block). So every opening was a shambles, the cavity which was 30mm, was if you were lucky 30mm at the bottom, and up to 60mm at the top. Most openings the cavity ranged from 10mm to 70mm at the bottom.
Measure? Are you joking? Build? are you joking? It's very, very rare things are spot on and folk wonder why the tolerances on things are big.
A Passive House care home I worked on with a very large developer. The building was in the wrong position by 20mm, throwing out all the brick work for the facade, all the floor levels were wrong (5 stories), resulting in mat wells at all doors. I wish I had a magic wand.
A "Grand Designs The Street" project, resulted in the window having to be adjusted (on air) because the kit tolerances were maxed out and coupled window frames were maxed out, meaning the 20mm tolerances in width we had for the opening no longer existed and the units were now too big.
Edited by craig
12 hours ago, JohnMo said:
My guy (arranged by our ground workers) came with drawings loaded into his computer, tied into GPS, then using another bit, just picked the points of one by one, even told me exactly how much higher the site was to the plan. Marked out the foundations, once foundations were done, can and marked out for the blocks. Spent an hour or so at site in total. Technology working.
They are good. What did he charge per visit? Do you have to have 3 visits including initial topo of site?
Architect did the topo as part of the initial planning. Cost me nothing for the GPS mark out, the ground workers included in the costs they quoted me, GPS is part of the base scope.
There's no such thing as a free lunch you're always paying someone to do it. I get your point though if groundworkers quoted you a package with it included.
Every time ive built ive got away with an os map on the planning and heights being marked on elevations. Never needed a topo upto now so have always marked out with lines and profiles. I accept its probably not cost effective on a more complex layout though. Particularly if there's other paid work you could be doing. I suppose like all self build its a trade off of time for£
Good professional measurers can, and do.
Some people charge money and think they can do it. Once they've been charged consequential costs a few times, they'll stop offering it.
Hence back to my mantra.. after they've gone, check the fundamentals with tapes and a level, however primitive  and mainly stand back and consider if it looks right.
Yeah, but like with just about everything we see on here at BH, we have a magnifying glass on the poor experiences of self-builders which shows it's incredibly difficult to find good professionals in just about every area of domestic building in the UK. E.g. I paid 3 sets of professionals and all three made fundamental mistakes and it was a humble bricklayer who knew how to use a tape measure and square properly in the end. And then the glulam manufacturer sent out a surveyor to confirm measurements before commencing production. All good then.
Yes, totally. I got laughed at when I was seen with my own home made water level fixed to a datum point on my steel frame with more than 25m long tubing, going round the house to check my levels on the rebuilt brick walls, wall plate and glulam ring beam. Why not use a lazer level they said and I showed them than it some critical areas there was no line of sight and a water level was more accurate because of it. In the end, I think I had a deviation on one corner to corner level of 3mm thanks to this. It was brilliant also for measuring trench depths and topographical measurements as you don't have the issues with sight of lazer in sunshine, even when you use a green lazer and sensor. I still have it coiled away for the landscaping to come.
I've never known a faulty one. The other huge advantages are  in being a one person operation and bypassing obstructions.
I think it's cheap to buy one  to reduce amusement.
On 18/03/2026 at 10:02, craig said:
Ya think?
And yet....  and yet... houses do get built.
I think this thread is another data point underscoring the aphorism that;
Systems and people show themselves for what they really are when -not if- things go wrong
I work at a place that refuses to have systems in place.
The rule seems to be to use any exceptions as the normal practice.
It's a (expletive deleted)ing disaster.
Took me 2 years, bollockings and general tantrums to get a drip tray emptied every day. Takes about 20 seconds to do it.  The reason given for not doing it was generally 'it was not full yesterday'. (expletive deleted)ing overflowing onto the floor now though, isn't it.
And it accounts for the curvature of the earth.
How big is this house 🤯
  • Haha 2
I tend to go with adapt and overcome.
Our patio doors started going in today.... and the threshold levels were wrong, or incompatible...it doesn't matter except that they didn't fit.  That's with me and mine being perfect, remember.
It's sorted now, due to collaborative working...and us paying a daywork guy to sort it instead of the intended work.
It will always happen.
The rule seems to be to ....
I learned that the hard way too.
For me the rule has become: work with people who raise my game: as well as force me to think hard, but laugh harder.
Amen.
If, whilst a room full of people are turning a drama into a crisis, you can’t tell everyone to be quiet and take control, then the jobs doomed.
The number of times I’ve been brought in for “disaster” management (by accident) is insane; I mean I wasn’t there to do this but I simply spotted a major feck up that everyone was oblivious to and pointed it out to the clients, who showed the ‘builders’, both of whom then asked me how the hell can it be put right??
I firstly point them back to the architect and SE, who both either ignored the problem or failed to spot it (whilst the job was on a screen), and they usually just shrug their shoulders or try to blame someone else. Then I sort it, and the world continues to revolve.
After one house was mid-construction (ICF) I had to create 3 plant rooms out of thin air, and both architect and SE were as much help as a deaf mute. SE was utterly obtuse to be honest, a completely unhelpful cock. Shan’t be passing his details on anytime soon…. 👎
This is why some people manage or consult, some people draw things but cannot build them, and others hit things until they fit. Opportunities to save money, value-engineer, make improvements without significant investment etc can only be done at the pre-construction level, so getting good advice very early on is priceless.
Also very important to employ the “two heads are better than one” method, and never be afraid to ask someone to look at what you’re looking at, for a simple second opinion; very simple and effective for times where you can be spinning one plate too many and be missing the trees and the woods. @flanagaj is now bringing in the troops to support with the pour, and after the dust has settled I’d bet a round of drinks it’ll be agreed that discussing it here first, and acting on good advice, was indeed the right thing to do.
Recently a groundwork crew were busy making very good progress on a rectangular foundation, when my client said to them “you’re building my house the wrong way round!”.
The issue was quickly resolved, but they then said the drawings never came with a compass or a topo overlayed, so they literally had zero information as to where the house should be facing, and it wasn’t the first time that this had happened…. :/. Yikes!!! :S
These feck ups happen at all levels, so it’s defo true that it’s not how you messed up, but how you immediately take responsibility and ownership, and how quickly you can turn things around; even better is when you can do this without breaking into a sweat.
The fundamental thing here is knowing your own limitations, as having balls bigger than your brain is not going to serve you well.
This in a nutshell and if you don’t know. Ask.
