flanagaj Posted July 29, 2025 Posted July 29, 2025 (edited) Does anyone have any experience with Openreach, eg, getting a new connection to your property.  I registered with the developer portal, uploaded a site plan .... I then received a call from an Indian call centre telling me that they have been unable to locate my site (no idea how) or the planning grant. I then simply received an email telling me that my application had been cancelled. Should I be going through a third party for getting my connection, or did others do exactly what I have been trying to do?  When I login to the developer portal, the registration has vanished and there is absolutely no evidence that I ever submitted one. Edited July 29, 2025 by flanagaj
nod Posted July 29, 2025 Posted July 29, 2025 Been there TWICE We where told that no fibre was available in our area Even though the poll that supplied both neighbors is in front of our build Got there in the end 11 months The problem is that you speak to someone different each time and have to start all over again 1
torre Posted July 29, 2025 Posted July 29, 2025 It seems to depend very much on who you speak to. We also had to re-register. The quotes seem a bit arbitrary too - first quote we had for an urban infill plot was over £4500. This was between two properties that each already had fibre to the home from a pole just across the road! (If your quotes are above £2k building control can't require you to install) 1
Russell griffiths Posted July 29, 2025 Posted July 29, 2025 Starlink dish, your build will be 50% up before bt get to you. 1
flanagaj Posted July 29, 2025 Author Posted July 29, 2025 19 minutes ago, Russell griffiths said: Starlink dish, your build will be 50% up before bt get to you. You have maybe just become a life saver with that reply! I didn't even consider that option and will potentially mean we can move into our static onsite. I work remotely, so need data connectivity and 4G /5G is not existent on site.
Alan Ambrose Posted July 29, 2025 Posted July 29, 2025 Yeah, although it should have been the simplest install with a pole in the verge outside boasting fibre - OR are the slowest of all our utilities. They don't even seem to have any kind of scheduling system: I've heard 'I should have some news next week'Â about a dozen times now. Â UKPN are the most cumbersome - the scale of the resources they waste is impressive. 1
BotusBuild Posted July 29, 2025 Posted July 29, 2025 (edited) Summary if you dont want to read it all - contact EE to request new broadband, let them deal with Openreach.  I applied to the broadband supplier, Plusnet first but then switched to EE. Both were told it is a new build. I provided postal and What3Words addresses. In both instances, an Openreach dork(s) came out to survey which in both cases involved me telling them where the relevant pole was already, where they needed to install a new pole, where they would be putting the box on the outside, and the inside, which conduit they would use, and I would trench from the base of the new pole to the house. Plusnet wanted to pass on over £1100 of Openreach install fees, so I took some advise from the site and applied to EE instead who are covering the Openreach fees. I will be paying the £20-something per month for 2 years for broadband. See this thread for more details https://forum.buildhub.org.uk/topic/44113-openreach-taking-the-proverbial-for-tree-lopping/  Edited July 29, 2025 by BotusBuild Added thread link 3
flanagaj Posted August 4, 2025 Author Posted August 4, 2025 So Openreach have come back and the contribution fee is only £567 + VAT, but along with the offer is a contract that is 35 pages long. Now, I am not sure whether I am jumping ahead of myself here and we will need to wait until the house is actually constructed before I can get fibre installed. I assume that unlike electricity or water, there is no concept of a temporary connection for fibre and as a result it is too early to get Openreach involved?
Russell griffiths Posted August 4, 2025 Posted August 4, 2025 Run the duct for the fibre into the plot, run enough cable to reach the new house, but run it to the site hut or caravan, then  just redirect it to the house when finished. 1
Alan Ambrose Posted August 5, 2025 Posted August 5, 2025 (edited) >>> UKPN are the most cumbersome - the scale of the resources they waste is impressive.  For anyone who’s interested - UKPN had 5 people at the plot & 3 vans for most of the day to connect and run one 5m cable into the duct we had already installed. Impressive, bravo.  Interestingly, it was labeled TT earth only or somesuch and they said they would move it to PME at a later date. I was expecting to use a TT earth and then simply switch from their already installed PME earth at the right time. Fantastic, the promise of more paperwork, expense and delay to look forward to. Edited August 5, 2025 by Alan Ambrose 1
flanagaj Posted August 5, 2025 Author Posted August 5, 2025 On 04/08/2025 at 20:02, Russell griffiths said: Run the duct for the fibre into the plot, run enough cable to reach the new house, but run it to the site hut or caravan, then  just redirect it to the house when finished. Ok. Does the cable have to be run in a duct or is it simply buried like an armoured electrical cable?
Russell griffiths Posted August 6, 2025 Posted August 6, 2025 14 hours ago, flanagaj said: Ok. Does the cable have to be run in a duct or is it simply buried like an armoured electrical cable? Mines all ducted. 1
saveasteading Posted August 6, 2025 Posted August 6, 2025 A fibre cable is very thin and not strong. So don't put it anywhere likely to be damaged. From the box intp the house the cable is even skinnier. Mine is overhead from a roadside pole to the house, then pinned along the wall. 1
Alan Ambrose Posted August 7, 2025 Posted August 7, 2025 OR supplied BT standard grey ducts for ‘free’. Loads of it, more than twice what we needed. Standard sizes are 50 & 90mm from memory. 1
BotusBuild Posted August 7, 2025 Posted August 7, 2025 OR just put our fibre cable in from one pole to the new pole, down into a trench we dug to the house and the external box. From the bottom of the pole they installed a small ducting (~15mm external diameter, black with a yellow trace) in the trench through which the fibre is fed. We were told we can fill the trench now. 1
Roger440 Posted August 8, 2025 Posted August 8, 2025 On 29/07/2025 at 13:37, flanagaj said: You have maybe just become a life saver with that reply! I didn't even consider that option and will potentially mean we can move into our static onsite. I work remotely, so need data connectivity and 4G /5G is not existent on site.  I ruled out starlink as its not supported. If you have any issues (which i would as im dumb with this kind of stuff) theres no one you can contact.  But i could get 4G so didnt have to overcome that hurdle.   1
Alexphd1 Posted August 9, 2025 Posted August 9, 2025 Im round the twist with open reach. This build has taken years and originally accepted a free connection from open reach 6 years ago. They dug up road and the local open reach guy said he would drop of ducting. Everything happy. This connection would have been dial up so was just to get a line in for future, I had no intention of actually using it. I tired phoning/emailing him to chase him up over the years but no luck. Cellular poor here so we have had starlink but this has slowed down considerably over last year (they probably want me to upgrade to new hardware). Surprisingly out the blue openreach installed fiberoptic a few months ago and now I tried to pursue old application..... I'm getting nowhere. There's no physical number to contact and it's just send a email and I get a phone call 2 weeks down the line with the same outcome. I will ask my supervisor and get back to you. I am going to try contacting EE for broadband and see how they get on. Will report back.
Temp Posted August 9, 2025 Posted August 9, 2025 I can sympathise. I think we applied for a line through BT who arranged for OR to do the work. BT called weekly to say their engineers were "working on it" but I could still see the wire we left at the bottom of the pole and knew it hadn't been touched.  Eventually they stopped calling so I called them, only to be told it was all finished and working. The girl wouldn't accept my assertion that I could see the wire was still unconnected.  So next step was to ask them to test the line, which they did and decided it was faulty. I tried to explain that it hadn't been connected but they wernt having any of it. The computer said it was all done so that was it. In the end I agreed to them sending a fault engineer which they said would cost £75 if the "fault" was in my house. I gladly agreed to that.  The old boy that turned up insisted on testing the line at my master socket and wouldn't listen to me telling him I knew exactly where the "fault" was.  In the end he made a few call and told someone to send a team out and we were up and running a week later. What a shower.
FuerteStu Posted August 9, 2025 Posted August 9, 2025 My copper line contract ran out 3 months ago. Been waiting 2 months for fiber to be fitted. They keep sending an engineer to connect the internal without installing the fiber to the house...  I'm not holding my breath, neighbours have also been waiting since may 1st for their fiber install.  It's a joke. 1
flanagaj Posted August 16, 2025 Author Posted August 16, 2025 On 09/08/2025 at 19:01, FuerteStu said: They keep sending an engineer to connect the internal without installing the fiber to the house... Sorry, but that made me 😂
Alan Ambrose Posted August 18, 2025 Posted August 18, 2025 I talked to the 'Patch Manager' in Suffolk today. After 8 months he's raised some new process obstacles and can't explain the story I've been given by their FBC (Field Based Coordinator) so far. He says there's lots of impenetrable red tape (I paraphrase) and that they can't deliver a service into a kiosk on site but only when a house has actually been built. I said that (a) that was the proposition they were given from the start, (b) if that was the case, why does their 'FBC' keep telling me 'I expect to have more news in 2 weeks' and (c) if that was the case, why does their process documentation not describe that? He's gone away to think. Â Goodness they make this hard work... 1
Alan Ambrose Posted August 19, 2025 Posted August 19, 2025 Wow, I was contacted by the OR 'Patch Manager' today who said:  "Unfortunately, treating your cabinet as a plot and bringing a residential FTTP line into it is not a viable option. My suggestion would be to enquire with your CP about an Ethernet line or utilise a dongle until the plot is built and ready to be called off, at which point we can install the FTTP line."  My reply was "Openreach knew exactly what we were planning from January ’25, so it is unacceptable after 8 months to suddenly inform me of a new policy. As I understand it, you don’t have any explanation for why this policy has suddenly been discovered and communicated. Please point me to where this policy is publicly documented."  Goodness they are a waste of space. 1
Roger440 Posted August 19, 2025 Posted August 19, 2025 At this point id be straight on to the CEO's office.  Im finding the CEO office option quite succesful at resolving stuff with big corparates.  So far, Fedex, DHL, Parcelforce (theres a theme here) Openreach in the past,  The directors of Fedex should be in jail.  Â
Alan Ambrose Posted August 29, 2025 Posted August 29, 2025 FYI let me report back. I have recently emailed OR's 'CEO's office' and had a number of long conversations with someone from the 'Executive Complaints and Escalations team'.  He has consulted 'the experts' i.e. the guys I have been communicating with so far and determined that they're correct. My feeling is that I'm not talking to a 'Complaints and Escalations team' so much as a delay, deflect and deny team.  In my case the issues are:  + running the fibre into a kiosk. (My other services are installed into kiosks already). This was originally agreed and now OR are now reneging on that.  + not installing the fibre and lighting it up anytime soon.  OR now maintains that as a matter of policy (a) it can only install into a dwelling which is ready for occupation and (b) the ONT must be inside the house. Somehow it had forgotten about those policies up until mid-August.  Now we won't finish the house until at least next summer so that means no fibre until then. That's 'non optimal' as I badly want to be able to work our of the site hut for the next 9 months and without proper internet that's not really possible. My CAD package, for instance, more or less requires continuous fast access to its various servers. And we have installed OR's duct and a kiosk as agreed which OR seems now refuses to use. That install took quite some time and expense.  This is actually the second loop with the Complaints guy - the 1st time he suggested ordering a second fibre and using the site hut as an address. I suggested that going round the process a second time with the same timescale (8 months already) and result (i.e. none) was not a welcome prospect or one that I imagine would lead to an actual solution (i.e. the install of fibre).  If I thought that UKPN or Essex and Suffolk Water were slow, inefficient, expensive and hard to deal with - I take it all back. Openreach wins the prize by a country mile.  Â
FuerteStu Posted August 30, 2025 Posted August 30, 2025 Have you talked with other suppliers like Virgin?  After months of farcical problems with OR, I'm now with V. Less that 3 weeks to install and it's been a dream by comparison
